  4. This is driving me mad!
6 Posts 4 Posters 1.3k Views 3 Watching
  • Paul Johnson 5undefined Offline
    Paul Johnson 5
    I'm pretty experienced but this has me stumped.
    I'm trying to get MRA to allow me to plan this route:
    This is what I get despite many attempts with via or shaping points:
    Changing the base map to TomTom however makes the weird detour go away:
    Here's the MRA gpx in case anyone cares to have a crack:
    link text
    Thanks.
    • GT JWRundefined Offline
      Check to see if you have Seasonal Road closures selected.
      Paul Johnson 5undefined 1 Reply Last reply
      • GT JWRundefined GT JWR
        Paul Johnson 5
        @GT-JWR Hi. Thanks. I already checked that and it makes no difference - in any case MRA lets me go down the road in one direction but not the other.
        • Paul Johnson 5undefined Paul Johnson 5
          Brian McGundefined Offline
          @Paul-Johnson-5 your link takes me to a google drive access request
          if you make the route public in MRA & share the link I think its much easier for people to find the issue
          it looks like for whatever reason part of the road around your waypoint 5 is designated as one way on the Here map
          if you believe the one-way restriction is in error, you can edit the map at https://mapcreator.here.com
            Paul Johnson 5
            @Brian-McG
            Brian - I think that explains it; I'm pretty sure the map has an error in it then.
            Thanks for looking at it and your point about making the map public is duly noted.
            • RainerTundefined Offline
              RainerT
              A quick and dirty solution ist to declare this part to off-road. So it is a straight line and there is no walking/driving around.
              RT
              RainerTundefined
              RainerT
              GT JWRundefined
              Paul Johnson 5
                Axel Härtlundefined
                Axel Härtl
              • Here kaart
                CD130undefined
              • Basecamp-Kurviger Overlay!
                CD130undefined
              • Voeg bij de routepunten de straatnaam en gemeente toe.
                Nomko Nomdenundefined
                Nomko Nomden
              • Waypoint met foto
                Robinekeundefined
                Robineke
              • Default POIs
              • back to old situation with 2 apps
                Lex.Kloet.RXundefined
                Lex.Kloet.RX
