  4. Route does not follow the actual Tom Tom map
13 Posts 4 Posters 3.2k Views 3 Watching
  • Kenneth de Mirandaundefined Offline
    Kenneth de Miranda
    Hi, Ive generated a few routes for an upcoming road trip. I'm using the web routeplanner in an Chrome browser on my MacBook Pro. Im using the TomTom Maps since ill be using the route on my BMW Connected Ride Navigator. Now i've notisced that some parts of the route does not follow the actual TomTom map. The RP's are correct, if i create a RP on the actual map road, the name of the road is corect but the plotted line remains off.
    Any ideas as to what is happening here? Thanks in advance!!
    • Kenneth de Mirandaundefined Kenneth de Miranda
      @Kenneth-de-Miranda if you select the TomTom overlay map you will see the route line follows the road.
        Kenneth de Miranda
        @Nick-Carthew Thanks!! So now i feel a bitlike an idiot 🙂
        But how come, when i created the route and used the TomTom map it appearenly kees using the Here map... o wait...maybe because thats my standard Map? You can change that to TomTom correct? But thanks mate!!
          @Kenneth-de-Miranda Your planning map is the TomTom map. You can set that as your default planning map by clicking: Always use this map for new routes.
          The planning map is the map that makes all of the calculations.
          The overlay maps do not affect any route calculations. Think of the overlay maps as clear sheet with extra information that you lay over the planning map.
          The system will remember the last overlay maps as that you used.
          • silberfuchs67undefined Offline
            silberfuchs67
            May be I have the same issue. I am planning all my routes in the route planner with TomTom maps as I am also using the CRN. Opening the Navigation map the route uses Here Maps …. where do I have to change this?
            • silberfuchs67undefined silberfuchs67
              @silberfuchs67
              The planning maps are in the blue menu bar, if you do not see the blue bar, all of the same options can be seen after clicking Page menu.
                silberfuchs67
                wrote on last edited by silberfuchs67
                Hi Nick, thanks for your support. It seems that I had exactly this issue …. thanks!
                  silberfuchs67
                  I just understood that MRA Next has only Here maps to navigate. In case my routes are planned for BMW CRN the planning needs to be done with TomTom maps. If I want to use the Navigation App in parallel I would like to know how to handle this difference ? Thanks for the support.
                    @silberfuchs67 When planning your route using the planning map from TomTom, turn on the Compare route with HERE tool. This will show an additional green route line (the HERE route) place enough route points so that the green line from HERE follows the black TomTom line.
                    When you navigate this route with MRA Navigation Next, because it has not been planned on the HERE map, the app will navigate it as a track so you will need to be online.
                      silberfuchs67
                      Hi @Nick-Carthew Thanks for explanation and your quick support!
                        @silberfuchs67, What @Nick-Carthew says 😉 . I just want to add, that after you equalled the routes with the compare tool, you can easily switch your route to the HERE map and navigate the route as rout (not as track). This makes no difference for TomTom users, since the routes are equal, and they usually import the route with a GPX.
                          @Con-Hennekens A good point well made 👏🏼
                            silberfuchs67
                            @Con-Hennekens Thanks for this great hint!
                            silberfuchs67
                            Kenneth de Miranda
                              Gerard Wullinkundefined
                              Gerard Wullink
                            • MRA 5.2.1 - 486 CarPlay Display Issue When route started on iPhone
                              GT JWRundefined
                            • Updated beta! 5.2.1 (486)
                            • Unknown symbol
                              Leike Lodiersundefined
                            • Hoogte meters in Navigatie
                            • MRA en Garmin GPSmap 60CSx
                            • Navigation Next versus Routeplanner
                              Ron 33undefined
                              Ron 33
