  4. MRA on Carpe Iter, map heading north?
19 Posts 12 Posters 6.8k Views 3 Watching
    I can confirm that as of the 4.1.3 update we will support a "north up" mode 🙂
    This will complete the list as follows:
    • Dynamic (default) with rotation, tilt & auto zoom
    • Topdown with rotation, no tilt, & fixed zoom
    • North up with no rotation, no tilt & auto zoom
    MotoCon tony_r LennyO 3 Replies Last reply
      @Corjan-Meijerink, Great addition! I suppose whenever there is an auto zoom possible, it can also be disabled in the settings?
        @Con-Hennekens yes!
          tony_r
          tony_r
          tony_r
          Just read your announcement about map North-Up while navigating being implemented. That's good news for me. Next week I'll have an opportunity to see it functioning in practice (next to other nav-tools).
          At the moment I'm only looking at it under 'indoor use' and operating the 'compass needle' button does indeed switch the map to 'North-Up' while having navigation activated, so far so good.
          I assume that the update had already been installed automatically, didn't quickly find a version number yet.
          Notes (still from behind the table):
          1. When using the map zoom +/- buttons the '<North-Up' setting becomes disabled (however not always, it seems) and needs to be selected ON again.
          2. When zooming via 'pinching' the map orientation also can turn. I think that should be prevented and the map should stay locked in North-Up position.
          3. By the way, I seem to miss a map scale indication (at least temporarily) visible on screen.
          • tony_r tony_r
            @tony_r 1 & 2 indeed are by design 🙂
            3 that is correct 😉
            Glad you got the update installed automatically
            tony_r 1 Reply Last reply
              3 that is correct 😉
              tony_r
              tony_r
              tony_r
              @Corjan-Meijerink ![
              During a 4 day tour I observed the navigation behaviour of MRA, in particular the new option to keep the map 'North-Up'. That functions fine.
              However I believe to have noticed that the zoom level keeps going back to a deep 'zoomed-in' map scale, something like 1 : 15000. The zoom level does not keep the selected level as set using 'pinching on the map' or +/- buttons.
              The font of the turn-distance indication (see below pic) is too small for convenient reading at a glance under driving condition.
              I liked the way how RMA picks up the route again after deviating from it and the option to keep the original route visible on the map.
              It seems that a route cannot initially be calculated without internet connection, as also indicated by pop-up messages. Once calculated navigation works with the installed local map and local route data.
              However a few times the navigation went wrong (cannot calculate the route and once the position indicated on map remained some 500 meters lagging the real position). I don't know if turn indications also came too late. Restoring internet connection for a moment solved such problems.
              On days with permanent internet connected there were no issues and data consumption was between 75 MB and 150 MB per day.
              All together RMA left a positive impression with me and probably I will use it more often to get better knowledge about it.
              Your information about 'by design' I don't really understand yet.
              What are the advantages of it ?
                @Corjan-Meijerink Hello, Corjan!
                Please advise where in the App do you control North up or any other options you have listed?
                Also, how about having a compass rose added? Would be a great help to most of us!
                Thank you!
                • LennyO LennyO
                  Thank you!
                  @Lenny-O click on the compass sign in the right below corner to change the camera view. A pop up will tell you witch view is selected
                  • Harold s
                    Harold s
                    Harold s
                    Northup is finished after recalculation or ooming in or out. How can I avoid this and correct the map quickly into northup again?
                    • Harold s Harold s
                      @Harold-s said in MRA on Carpe Iter, map heading north?:
                      Northup is finished after recalculation or zooming in or out.
                      I cannot reproduce the recalculation part.
                      While zooming, the cameraposition is changed to Top-down mode.
                      After pressing the compass, the position returns to where it came from.
                      • Gkc
                        Gkc
                        Gkc
                        Same issue with a Carpuride device from an iPhone : Northup finished.
                        Huibertus
                        Huibertus
                        Harold s
                        Harold s
                        Gkc
                        Gkc
                        tony_r
                        tony_r
                        Robert Bühlmeier
                        Robert Bühlmeier
                        Seppi
                        Seppi
                        • Audio cuttet via Bluetooth
                          Haug
                          Haug
                          35.5k
                        • One crash today
                        • Download club route folders
                          peha
                          peha
                          Mosimann
                          Mosimann
                        • Elektrisch rijden
                          John mq
                          John mq
