  4. MRA on Carpe Iter, map heading north?
19 Posts 12 Posters 6.0k Views 3 Watching
  • Seppi Offline
    Seppi Offline
    Seppi
    I am using the MRA since some days (full version) on my new CI with R1250GS.
    As I am obviously old school, I‘d like to see the map always facing north.
    Like Google maps or many other routing apps allow.
    Is there any way to set this up on MRA while routing?
    BG Frank
    • Seppi Seppi
      BG Frank
      Corjan Meijerink Offline
      @Seppi a north up mode is on our backlog 🙂
      Huibertus Robert Bühlmeier 2 Replies Last reply
        Huibertus Offline
        Huibertus Offline
        Huibertus
        @Corjan-Meijerink sorry maar wat betekent “Backlog”?
        Hans van de Ven MR.MRA RetiredWingMan 2 Replies Last reply
        • Huibertus Huibertus
          @Huibertus
          ToDo lijst 😉
            RetiredWingMan Offline
            @Huibertus planned future enhancement ... no implementation date.
            Huibertus 1 Reply Last reply
              Huibertus Offline
              Huibertus Offline
              Huibertus
              @RetiredWingMan Oh 😂 😂 thanx
                Robert Bühlmeier Offline
                Robert Bühlmeier
                @Corjan-Meijerink Hi, I'm sadly noticing that north right map navigation is not on your priorities.
                Please put north facing map on prio 1.
                Personally I hate these all time turning Maps while driving....
                Actually I'm leaving the TomTom platform and want to use DMD2 in the future, but it's not possible to use myroute app properly, because this north right issue.
                -2
                • Robert Bühlmeier Robert Bühlmeier
                  @Robert-Bühlmeier said in MRA on Carpe Iter, map heading north?:
                  I guess everyone thinks his own suggestions need to be prio 1... 🤣 🤣
                  know that your suggestion is not much asked for.
                  • Corjan Meijerink Offline
                    I can confirm that as of the 4.1.3 update we will support a "north up" mode 🙂
                    This will complete the list as follows:
                    • Dynamic (default) with rotation, tilt & auto zoom
                    • Topdown with rotation, no tilt, & fixed zoom
                    • North up with no rotation, no tilt & auto zoom
                    Con Hennekens tony_r LennyO 3 Replies Last reply
                      @Corjan-Meijerink, Great addition! I suppose whenever there is an auto zoom possible, it can also be disabled in the settings?
                        @Con-Hennekens yes!
                          tony_r Offline
                          tony_r Offline
                          tony_r
                          Just read your announcement about map North-Up while navigating being implemented. That's good news for me. Next week I'll have an opportunity to see it functioning in practice (next to other nav-tools).
                          At the moment I'm only looking at it under 'indoor use' and operating the 'compass needle' button does indeed switch the map to 'North-Up' while having navigation activated, so far so good.
                          I assume that the update had already been installed automatically, didn't quickly find a version number yet.
                          Notes (still from behind the table):
                          1. When using the map zoom +/- buttons the '<North-Up' setting becomes disabled (however not always, it seems) and needs to be selected ON again.
                          2. When zooming via 'pinching' the map orientation also can turn. I think that should be prevented and the map should stay locked in North-Up position.
                          3. By the way, I seem to miss a map scale indication (at least temporarily) visible on screen.
                          • tony_r tony_r
                            @tony_r 1 & 2 indeed are by design 🙂
                            3 that is correct 😉
                            Glad you got the update installed automatically
                            tony_r 1 Reply Last reply
                              3 that is correct 😉
                              tony_r Offline
                              tony_r Offline
                              tony_r
                              @Corjan-Meijerink ![
                              During a 4 day tour I observed the navigation behaviour of MRA, in particular the new option to keep the map 'North-Up'. That functions fine.
                              However I believe to have noticed that the zoom level keeps going back to a deep 'zoomed-in' map scale, something like 1 : 15000. The zoom level does not keep the selected level as set using 'pinching on the map' or +/- buttons.
                              The font of the turn-distance indication (see below pic) is too small for convenient reading at a glance under driving condition.
                              I liked the way how RMA picks up the route again after deviating from it and the option to keep the original route visible on the map.
                              It seems that a route cannot initially be calculated without internet connection, as also indicated by pop-up messages. Once calculated navigation works with the installed local map and local route data.
                              However a few times the navigation went wrong (cannot calculate the route and once the position indicated on map remained some 500 meters lagging the real position). I don't know if turn indications also came too late. Restoring internet connection for a moment solved such problems.
                              On days with permanent internet connected there were no issues and data consumption was between 75 MB and 150 MB per day.
                              All together RMA left a positive impression with me and probably I will use it more often to get better knowledge about it.
                              Your information about 'by design' I don't really understand yet.
                              What are the advantages of it ?
                                LennyO Offline
                                LennyO Offline
                                @Corjan-Meijerink Hello, Corjan!
                                Please advise where in the App do you control North up or any other options you have listed?
                                Also, how about having a compass rose added? Would be a great help to most of us!
                                Thank you!
                                • LennyO LennyO
                                  Thank you!
                                  Marinus van Deudekom Offline
                                  @Lenny-O click on the compass sign in the right below corner to change the camera view. A pop up will tell you witch view is selected
                                  • Harold s Offline
                                    Harold s Offline
                                    Harold s
                                    Northup is finished after recalculation or ooming in or out. How can I avoid this and correct the map quickly into northup again?
                                    • Harold s Harold s
                                      @Harold-s said in MRA on Carpe Iter, map heading north?:
                                      Northup is finished after recalculation or zooming in or out.
                                      I cannot reproduce the recalculation part.
                                      While zooming, the cameraposition is changed to Top-down mode.
                                      After pressing the compass, the position returns to where it came from.
                                      • Gkc Offline
                                        Gkc Offline
                                        Gkc
                                        Same issue with a Carpuride device from an iPhone : Northup finished.
                                        Huibertus
                                        Huibertus
                                        Harold s
                                        Harold s
                                        Gkc
                                        Gkc
                                        tony_r
                                        tony_r
                                        Robert Bühlmeier
                                        Robert Bühlmeier
                                        Seppi
                                        Seppi
                                          Crispey
                                          Crispey
                                        • Questions and suggestions
                                          Mike wiruth
                                          Mike wiruth
