  4. Zooming in CarPlay & Android Auto
37 Posts 17 Posters 25.1k Views 8 Watching
  • Fridjof
    Fridjof
    Fridjof
    @Corjan-Meijerink , selecting waypoint of AA screen not working, phone OK
    yesterday i did a nice ride in our area, prepared a route like a brezel, used the route as a track with all waypoints (~every 2 km) .
    at an unwantedt shortcut with rerouting active the ride went craczy and at the end mra quits, after restarting the route with deactivated rerouting I schoud start from poit 1 instead of point 29 infront of me, I tried to shortcut to the point by pressing the point om the AA Screen, nothing changes only the map where paned, by doing the same on the phone it works a expected and the restart of the Track / route work well.
    is this a known problem, can you reproduce it?,
    best regards,
    Fridjof
      @Fridjof Well, you by design from Android Auto (and CarPlay) not select anything on the map by tapping 🙂
      This is a user distraction while driving so not permitted.
      Fridjof 1 Reply Last reply
        @Arno-0 The solution to this is simple but at first I didn't know either: in the window where you have zoom and centring options, click again on the icon you used to open this zoom window. If you do this, MRA reverts to the Dynamic setting in which it automatically zooms again. If you wait until this window closes itself, MRA stays in "top camera" mode with fixed zoom and is thus not switched back!
        De oplossing hiervoor is simpel maar ik wist het eerst ook niet.
        In het venster waarin je zoom en centreer optie hebt nogmaals op het icoon klikken waarmee je dit zoom venster geopend hebt. Als je dit doet keert MRA terug naar de Dynamische instelling waarin hij weer automatisch zoomt.
        Als je wacht tot dat dit venster zichzelf sluit, dan blijft MRA in de modus "bovenaf camera" met vaste zoom en wordt dus niet terug geswitched!
        @white-mouse unless I misunderstand what your saying (and I don't think I am), this did not work for me either. I can use the +/- to zoom in or out as desired, which then stayed on that zoom level unless adjusted again. A click on the icon that opened the zoom level did absolutely nothing.
        I'm with all the others on this issue - if zoom (among other things) does not work properly on CarPlay, the Next App is unusable to me.
        Seems every update takes 3 steps forward and 2 steps backward - a lot of past issues that were solved seem to come back - like zoom, wapypoint skipping, online vs offline, unable to calculate, etc. Seems like each update overwrites a previous fix. 😞 đŸ€·
          Fridjof
          Fridjof
          Fridjof
          what is your solution to deal with this situation / problem?
          regards
          Léon Hassing 1 Reply Last reply
          • Fridjof Fridjof
            regards
            Léon Hassing
            Léon Hassing
            Léon Hassing
            @Fridjof Is your finding related to the subject of this thread: Zooming in Carplay/Android auto?
            • LĂ©on Hassing LĂ©on Hassing
              Fridjof
              Fridjof
              Fridjof
              @Léon-Hassing
              zooming is one of the needed on screen interactions on the dash AA or CP screen,
              when MRA offers a feature to go dirct to a further point to shorten a route or skip some points on the phone screen while in a driving session with AA, I like to have this option also on the AA screen,
              while driving I ca change the APP, skip or pause mp3 files, having a phone call, but no manual option to solve a scrambled route operating the AA Screen, why i can zoom and pan the map, but not selecting a given way or shaping point for reroutind the loaded route?
              • Fridjof Fridjof
                @Léon-Hassing
                #34
                @Fridjof, this basically comes down to Apple and Google limitations. They don't allow a lot of interaction in their apps. So the use of AA/CP comes with limitations. That is why many people prefer a native device.
                  Yes, AA/ACP has limitations.
                  For navigation apps, the biggest limitions i encounter are when you start a route or select a destination. These functionality is to limited in AA/ACP (in general).
                  But when the route is on your screen, then the limitations are not really limitations at all. Because when the navigation does it's job, then there is no need to touch the screen.
                  I am a fan of AA. Nice big built-in screen and a clean interface.
                  • David Rudgley
                    David Rudgley
                    David Rudgley
                    I used MRA Navigation Next at the weekend through my AA Capuride W702 which was mostly a good experience. The only issue I have been getting is how the map is displayed on the Phone App is different on the AA device. The tilt and dynamic zoom doesn't look right whereby I don't get the same degree of 'look ahead' on AA compared to the phone screen. I have adjusted the Map Layer, Default Zoom correction and Tilt correction both at max (+2.0 and +15) which seemed to work for me. I have compared with TomTom Go and Google Maps and they don't suffer the same display difference between Phone and AA.
                    MRA Gold Planner + App + Navigation Next user
                    Android Pixel 10 Pro Fold
                    TomTomGo as backup
                    KTM 1290 Super Adventure S
                    Quad Lock + Phone + Carpuride W702
                    2026 Kawasaki Z900 RS
                    Beeline Moto II
                    • David Rudgley David Rudgley
                      @David-Rudgley its also different between CarPlay and Android Auto. Car Play has more tilt and looks much better !
                      Adrian
                      đŸ“±Samsung S24 Ultra with MyRoute-APP (GOLD Lifetime)
                      đŸïžHonda NC750X (2021) with AA/CarPlay by CHIGEE Aio-5
                      Edwin_M
                      Edwin_M
                      David Rudgley
                      David Rudgley
                      Arno 0
                      Arno 0
                      Léon Hassing
                      Léon Hassing
                      silberfuchs67
                      silberfuchs67
                      Fridjof
                      Fridjof
                      bluetuz
                      bluetuz
                      Gaetano 9
                      Gaetano 9
                        Alderweireld Rudi 0
                        Alderweireld Rudi 0
                        Hanza 0
                        Hanza 0
                      • Weather as a service
                        Andy Smith 5
                        Andy Smith 5
                      • Lane view in Android Auto
                        denWINNE
                        denWINNE
