  4. Minimum tablet requirements for MyRoute App
29 Posts 9 Posters 10.4k Views 6 Watching
  • Lee Parker 1undefined Offline
    Lee Parker 1
    I currently use a Samsung Galaxy Tab A8 for navigation with MyRoute App.
    It has 4g ram and 64g storage.
    Is 4g ram enough for MRA. Mine seems quite slow. I have no other apps open while navigating and really have very few apps even loaded on the tablet.
    What is the minimum requirements for proper function of MRA.
    I may consider changing to an IPad. What would the minimum requirements be for a IPad?
    Lee
    Jörgenundefined Albert van den Elsenundefined 2 Replies Last reply
    • Lee Parker 1undefined Lee Parker 1
      Lee
      Jörgenundefined Offline
      @Lee-Parker-1 iPad on motorbike? Not a good idea.
      It is not made for outdoor and vibration.
      I use an Oukitel RT3 nearly two years and it is still working.
      Makroundefined Adrian Avramundefined 2 Replies Last reply
      • Jörgenundefined Jörgen
        Makroundefined Offline
        Makro
        @Jörgen It's actually an interesting subject, how various tablets perform.
        I use a Samsung Galaxy Active tablet 3. It works, but performance isn't impressing. I think this mostly depends on the device's CPU.
        From what I have read, even the newer Active 5 performs equally.
        Likely nobody has compared GPS applications on a number of tablets.
        Best regards, Makro
        • Makroundefined Makro
          @Makro There is a new Oukitel RT3 Pro available (I think below 200€) with a newer Android version, I have no Idea if it is better in performance. Mine is Ok for now and it works fine. I sometimes use two apps in split screen mode and ha´ve no problem.
            Stanisławundefined Offline
            @Jörgen I have just bought RT3 pro, how to get split screen, could you advice me?
            Staszek
            Jörgenundefined Gaetano 9undefined 2 Replies Last reply
              @Stanisław Hi, swipe your finger slowly upwards from the bottom, stop halfway and tap on the three dots to the right of the app you have just opened and select split screen. Then select the other app to be displayed.
              Makroundefined Stanisławundefined 2 Replies Last reply
                Makro
                For those using Samsung like me, if anyone should be interested, then split screen can be enabled using finger draw.
                https://www.samsung.com/ph/support/mobile-devices/how-to-use-swipe-gestures-with-multi-window/
                But also in another way: open the list of recent apps, click the app icon and select the split screen option.
                This may or may not work on Oukitel
                Best regards, Makro
                  @Jörgen Thank you, it works!
                  Staszek
                    Gaetano 9undefined Offline
                    Gaetano 9
                    @Stanisław said in Minimum tablet requirements for MyRoute App:
                    Hi, I ask you a favor, could you give me the measurements of the screen and the total size? H, L, in cm? Thank you very much, I want to take it too but I have to see if it fits under the windshield.
                    • Gaetano 9undefined Gaetano 9
                      @Gaetano-9 https://www.devicespecifications.com/de/model-display/94505b63
                      Gaetano 9undefined 1 Reply Last reply
                        Gaetano 9
                        @Jörgen said in Minimum tablet requirements for MyRoute App:
                        Very kind, thank you!
                        On amazon they give exaggerated measurements.. I think I'll take it immediately.
                          @Gaetano-9 I can confirm these values from the link, just measured manually 🙂
                          Staszek
                          • Gaetano 9undefined Offline
                            Gaetano 9
                            Ok.. took measurements... The Pad is too big, it doesn't fit under the windshield and in any case for a motorbike I don't find it very proportionate. I opted for a 6.6" Rugged Smartphone, definitely better and highly visible. It's also easier to find brackets. After all, on a motorbike, we go to look at the world and not at a screen. 😊
                            I will definitely have fewer problems with My Route on my motorbike. 🤙
                              Adrian Avramundefined Offline
                              @Jörgen what kind of mount are you using ? Thanks !
                              Adrian
                                @Gaetano-9 said in Minimum tablet requirements for MyRoute App:
                                Nicely said !
                                Adrian
                                  @Adrian-Avram a self made DIY.
                                    Lee
                                    Albert van den Elsenundefined Offline
                                    @Lee-Parker-1 Hi Lee,
                                    I'm driving with a TFT Carpuride W702B.
                                    It has a lot of nits, is waterproof, and can absorb vibrations.
                                    This TFT screen has built-in Apple CarPlay and Android Auto and works perfectly in combination with MRA.
                                    iPhone 15,
                                    Carpe Iter Tablet V4C
                                    Sena 20S EVO headset
                                    Harley Davidson Road King M8
                                      Gaetano 9
                                      Here is my final configuration. Instead of the Zumo I put this cell phone, so I eliminated Android Auto that with MyRoute, on a motorcycle, was not the best. Now MRA is perfect.
                                        @Gaetano-9 Which phone do you use now?
                                          Gaetano 9
                                          @Jörgen ... I took this one, "OUKITEL G1", without too many expectations but very satisfying. The resolution is not pushed and allows me to use gloves without any problems
                                          Stanisławundefined
                                          Makroundefined
                                          Makro
                                          Gaetano 9undefined
                                          Gaetano 9
                                          Lee Parker 1
                                            Big Al 1undefined
                                            Big Al 1
                                          • Segmentation
                                            Lenny Oundefined
                                            Lenny O
                                            RetiredWingManundefined
                                          • Onbekende fout, 3 problemen
                                            Klompenmaker1undefined
                                            Klompenmaker1
                                            Thomas Neumeyerundefined
                                            Thomas Neumeyer
                                            1.7k
                                          • Route opslaan op Pc vanuit telefoon MRA app
