  4. Distance to next fuel station
10 Posts 7 Posters 669 Views 5 Watching
  • Chris Hallundefined Offline
    Chris Hall
    I checked out the latest Navigation update - always hoping that there is the OPTION (note - I said an option only, not by default, for those that don't want it) to display on the main navigation screen, the distance to (at least) the next two fuel stations along the route. I mean - how hard can it be? There is mass of screen space available.
    This year we had 9 riders on tour to Spain - ranging from a Ducati Streetfighter (range 90 miles), to a BMW F900XR (range 220 miles).
    I don't plot the location of the fuel stations on the route as we split up into different riding groups each day.
    When a rider says he needs fuel, I'm not going to stop at the side of the road with 6 others to locate next one.
    Adrian Avramundefined Guzzistundefined Con Hennekensundefined 3 Replies Last reply
    • Chris Hallundefined Chris Hall
      Adrian Avramundefined Online
      @Chris-Hall i also miss that. TomTomGo has that option..
      Adrian
      Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
      Torrealarconundefined 1 Reply Last reply
        Torrealarconundefined Offline
        Torrealarcon
        @Adrian-Avram And Sygic too
        • Torrealarconundefined Torrealarcon
          Stanisławundefined Offline
          Maybe a good solution would be to add a special screen with list of next few stations after clicking the next station icon? Adding a waypoint would require two clicks (or a long press) instead of one but it would give more information to the rider.
          Chris Hallundefined 1 Reply Last reply
            Chris Hall
            @Stanisław Thanks for the suggestion.
            I would prefer not to tap anything. My TomTom Rider shows the distance to the next two fuel stations on the side-bar which is always visible. MRA Next screen has masses of unused screen real estate that isn't used. I'd prefer it to show the next three as there are often two close together.
              Guzzistundefined Offline
              @Chris-Hall said in Distance to next fuel station:
              ...hoping that there is the OPTION ... to display on the main navigation screen, the distance to ... the next ... fuel station along the route...
              Sorry, I don't understand your need really - so may I'm wrong.
              But If you want to see next fuel station alongside your route, while navigating:
              • it appears currently on main screen while navigating automatically - if you are close enough to (see black icon at left side of navigating screer):
              • on/near your displayed route, you can see also a orange icon of fuel stations. But this will be displayed only, if you activate it in settings (three dots icon, at right side down in main screen):
              • To change this setting, tap on 3-dots-icon (this will open the settings page):
                select "functional"...
              and in next screen, activate "search for fuel stations along route":
              Good luck 😉
                In my opinion there is no need to do that. Just fill up, unless you know for sure you can go as far as the ones filling up now. No one should need to refuel earlier than the ones filling up right now (usually the ones with the shortest range).
                @Stanisław said in Distance to next fuel station:
                That is not a bad idea at all. It is just important to know that every calculation takes time. It will probably not be "instant" information.
                I disagree. MRA is not limited to tablets. It must work on regular phones too.
                @Guzzist said in Distance to next fuel station:
                This in not about the "first" fuel station but about the "next" one (or the second one on the route). People tend to make decisions about "will we take this one", or "we have enough fuel to skip this one and take the next".
                • Guzzistundefined Guzzist
                  Good luck 😉
                  @Guzzist to make a "to tank or not to tank" decision it would be good have distance to more than one station displayed. As there is not too much free place in the main screen, I proposed a separate window for it.
                  @ Con Hennekens
                  Yes, it would have to be calculated on the flow, after clicking the icon. A few seconds shouldn't be a problem.
                    @ Con Hennekens
                    @Stanisław ok, understood now - and agreed. A solution like "tap on black fuel icon" to get a list of nexts fuel stations in route direction (inc. distance calculation) would be appreciated.
                    Currently, it could be estimated on screen by zooming out/pan the map - then you can see more of the orange icons of fuel stations. But I understand, this is time consuming and only raw estimation.
                    LRundefined 1 Reply Last reply
                      LRundefined Offline
                      LRundefined Offline
                      LR
                      Außerdem wäre es schön, wenn es auch in AA zu sehen wäre.
                      Gruß
                      Stanisławundefined
                      LRundefined
                      LR
                      Chris Hallundefined
                      Chris Hall
                      Torrealarcon
                      • Silverfox H1+ long-press
                      • Nieuw tablet, hoe kom ik aan de beta versie
                      • Why is there a 2. Route line
                      • Link webshop bug
                        Nomko Nomdenundefined
                        Nomko Nomden
                      • Ervaring na 8 daagse reis in Thüringen/Thüringer Wald
                      • 12 Tage in den Seealpen mit MRA und es war eher NICHT gut..
                        UwBundefined
                        UwB
                        1.7k
                      • Improvement suggestions after long trip - and a single bug
                        EMW-motorriddersundefined
                        EMW-motorridders
                      • Statement about OSM issues
