  4. Bluetooth device key mappings work but also change map view.
13 Posts 6 Posters 2.7k Views 5 Watching
  • Rob Kelley
    Rob Kelley
    Rob Kelley
    Hi
    Using Android
    I'm trying to use a cheap bluetooth controller to remotley zoom in and out, I use a key mapper app to map buttons from the device to specfic actions, it was working but since I last updated the OS it's not working as expected.
    The Zoom does work when I press the remote but it also changes the view to Top Down, I press the + button on the remote, the map zooms in and then it changes to Top Down view, zoom out (minus) works fine.!
    This shows the key mappings, I have also tried = instead of + but same result.
    Any ideas?
    Thanks
    GSA1250
    HD Street Glide
    HD Sport Glide
    XT500 x 2
    Guzzist 2 Replies Last reply
    • Rob Kelley Rob Kelley
      Hi
      Using Android
      Any ideas?
      Thanks
      @Rob-Kelley please, which key mapper App are you using?
      Rob Kelley 1 Reply Last reply
      • Guzzist Guzzist
        Rob Kelley
        Rob Kelley
        Rob Kelley
        @Guzzist it’s just called ‘Key Mapper’ https://play.google.com/store/apps/details?id=io.github.sds100.keymapper&pcampaignid=web_share
        GSA1250
        HD Street Glide
        HD Sport Glide
        XT500 x 2
          Hi
          Using Android
          Any ideas?
          Thanks
          @Rob-Kelley @Corjan-Meijerink
          Hy Rob, Corjan has changed something with automated zoom last time. I'm in contact with him, to get setting preferences also for remote controller "Remote 2" from DMD - because many others and I'm are using it. He promised to work on.
          In meantime, I use "WunderLINQ" as preference in input settings. But this isn't working correct - but is the best option currently.
          By your message, I was motivated to check MyRoute-App (Vers. 4.3.6.-382) at my device (T865-X from DMD) again. The result is similar to your observation:
          • Map in Top down:
            zoom in (+) works correct
            zoom out (-) works correct
          • Map in North up:
            zoom in (+) works, but changes map orientation to top down
            zoom out (-) no action!
          • Map in Dynamic style:
          My preferences during navigation in map layer for zoom is: off!
          I can understand - for users which don't use remote controller - some automation for zoom is welcome and benefitcial. But by using a remote controller, it's much much more secure and user friendly to do zoom manually by remote! For this, the option to set zooming "off" in the preferences is made for - in my opinion. But it doesn't work as expexted.
          May Corjan is co reading here - or we should risea ticket...
          • Guzzist Guzzist
            • Map in Top down:
            • Map in North up:
            Rob Kelley
            Rob Kelley
            Rob Kelley
            wrote on last edited by Rob Kelley
            @Guzzist said in Bluetooth device key mappings work but also change map view.:
            • Map in Top down:
            • Map in North up:
            thanks for testing this and yep that's my experience as well, hopefully a fix will be soon.
            GSA1250
            HD Street Glide
            HD Sport Glide
            XT500 x 2
              • Map in Top down:
              • Map in North up:
              Rob Kelley
              Rob Kelley
              Rob Kelley
              @Rob-Kelley I've just created a support ticket.
              GSA1250
              HD Street Glide
              HD Sport Glide
              XT500 x 2
                Full control over zoom level with a bluetooth controller is only possible with the top-down mode.
                  Rob Kelley
                  Rob Kelley
                  Rob Kelley
                  @Corjan-Meijerink oh, any plans to change this so it can be done in dynamic mode?
                  GSA1250
                  HD Street Glide
                  HD Sport Glide
                  XT500 x 2
                    @Rob-Kelley no, cause then it isn't dynamic anymore 😉
                    Rob Kelley Lluis Arasanz Con Hennekens 3 Replies Last reply
                    -2
                      Rob Kelley
                      Rob Kelley
                      Rob Kelley
                      @Corjan-Meijerink I get what you mean but I don’t agree.
                      My Zumo, in dynamic mode, allows me to zoom in and out and will then go back to dynamic view after a short period.
                      GSA1250
                      HD Street Glide
                      HD Sport Glide
                      XT500 x 2
                        It would be great if zoom in and out use the same view as Dynamic (aka 3D view). also as TomTom do.
                        Really it can't be deployed?
                        Best Regards!!!!
                        • BMW F750GS
                          @Corjan-Meijerink, you could perhaps consider the + and - zoom buttons to correlate to the App's system setting that defines the standard zoom correction, if used in dynamic mode. More dynamic than that it will never be 😉
                          Sad to see downvotes to you honest reply though...
                          But you have enough votes to compensate 🤣
                          Stanisław 1 Reply Last reply
                            @Con-Hennekens I agree, it could be an elegant solution for this problem without changing the internal algorithms in dynamic mode. The question is whether it can be changed effectively without breaking the ride.
                            Staszek
                            Rob Kelley
                            Rob Kelley
                            • Statement on map spinning
                              1.6k
                            • Electric Car Travel Mode
