  4. Using other offline maps
8 Posts 4 Posters 351 Views 3 Watching
  • Rob Kilbourneundefined Offline
    Rob Kilbourne
    Hey all,
    Got a quick question. I've recently got a DMD T-665 so that I can finally be Garmin free 🙂
    Obviously it comes with DMD2 software, but mainly I want it so that I can use MRA and I want it to have offline maps.
    So, to my question - is it possible to point MRA towards using the DMD2 offline maps (or vice versa). It seems daft to have 2 sets of offline maps on the device (not to mention the PITA that is updated all the maps twice), but also, the DMD maps are on the device and the MRA maps are on the SD card.
    So is there some way to point MRA so that it reads the maps on the device (the DMD maps) as their base maps?
    Cheers
    Bob
    • Rob Kilbourneundefined Rob Kilbourne
      Hey all,
      Cheers
      Bob
      @Rob-Kilbourne Unfortunately that is not possible!
        Rob Kilbourne
        Fair enough, thanks for the quick response. Don't suppose it'd work the other way either - pointing DMD to MRA maps?
          @Rob-Kilbourne DMD uses the OSM and MRA the Here map.
          On that T865X tablet there's space enough on the intern memory that you can load both map sets in the intern memory of the tablet. And on top of that you can insert an SD card on witch you can save the DMD maps. I've done the same and in the settings of the tablet made MRA my default. If I put the tablet in the harness in opens with MRA. I'm a very happy camper 🙂
          Samsung S20FE mounted on a Quadlock and using Android Auto in my car
          Rob Kilbourneundefined 1 Reply Last reply
            Rob Kilbourne
            @Marinus-van-Deudekom Fair enough, maybe that's the way forward, although DMD apparently doesn't play nicely with maps on the SD card. Also, I've got the phone one, not the tablet, so half the onboard storage to the tablet. Maybe I'll give that a go, though
            Cheers
            Rob
              Cheers
              Rob
              Guzzistundefined Offline
              @Rob-Kilbourne said in Using other offline maps:
              ...I've got the phone one, not the tablet, so half the onboard storage to the tablet. Maybe I'll give that a go, though...
              If you would have place enough on the cockpit or handle bar - the tablet (T865-X) would be the better choice because of 1000 nit instead 600 nit in T665. And the bigger screen, means better readable city- or street names 😉
              Marinus van Deudekomundefined Rob Kilbourneundefined 2 Replies Last reply
              • Guzzistundefined Guzzist
                @Guzzist the new T865X should be 1300 nits 😁
                  Rob Kilbourne
                  @Guzzist and the phone is 800 nits and the tablet just would not fit - maybe on the Stelvio, but not on the Triumph
                  Rob Kilbourne
                  • Routepunten overslaan zonder reden
                    1.8k
                  • MRA User map
                  • Future Developments
                  • Points of Interest (POI) Questions
                    Leike Lodiersundefined
                  • Mute / Silence / Ignore A Whole Forum Category / Section
                  • Change Subscription Country
                  • Routes van vrienden bekijken
                  • Indicator arrow drifts all over the map.
