  4. gpx 1.1 vs 1.2
gpx 1.1 vs 1.2
23 Posts 10 Posters 13.1k Views 6 Watching
  • Andy Beviere Andy Beviere
    @Hans-van-de-Ven-MR-MRA
    Hi Hans,
    Many thanks for your reply but unfortunately in my-case this is incorrect, if I send a route from MRA to Tread and onto the XT2 over the air only the via points are shown and the unit changes the route between the via points, obviously this could be my error but believe me I’ve tried and tried…
    Just to reiterate this is file transfer over the air and my issues are when the route is viewed on the unit not on MRA or Tread.
    Thanks again,
    Andy.
    MartinW
    MartinW
    MartinW
    @Andy-Beviere said in gpx 1.1 vs 1.2:
    It's not the unit (XT2); the Tread app causes the problem.
    GPX 1.2 is similar to the basecamp format: You have your VIA points, and the route segments in between are shaped with a lot of "hidden shaping points" (gpxx:rpt extensions):
    When transferring a GPX 1.2 with USB to your XT2, these hidden points are preserved, but when using the Tread App, these points are filtered out.
    So, for your case (XT2, transfer with Tread), GPX 1.1 is the only useful choice.
    (By the way, it's not an issue with an XT(!), as the Drive App (not Tread) transfers the GPX to the unit, which preserves the hidden points).
    Andy Beviere 1 Reply Last reply
    • MartinW MartinW
      Andy Beviere
      Andy Beviere
      Andy Beviere
      @Martin-Wilcke
      Hi Martin yes totally agree, its when the route goes from the Tread app to the XT2…
      Many thanks,
      Andy.
      • Skellum Skellum
        Hi Hans,
        Thanks again,
        Andy.
        Hi Andy,
        Not sure if you have seen this earlier post from Steve Jarrell that really explains how 1.2 works and why he feels it is better to use than 1.1
        https://forum.myrouteapp.com/topic/2734/gpx-1-1-vs-1-2-simple-explanation
        Hope it helps
        Tony
        Andy Beviere
        Andy Beviere
        Andy Beviere
        @Skellum
        Ooooh Thanks Tony… will have a read!
        Thanks,
        Andy.
        MartinW
        MartinW
        Carl Lee
        Carl Lee
        Andy Beviere
        Andy Beviere
        Skellum
        Skellum
        Sam Ellis
        Sam Ellis
        Alasdair Denton-Miller
        • Béta to no-béta
          Parantapa
          Parantapa
          John Matthews 0
          John Matthews 0
