  3. [App] Announcements
  4. New update! (4.3.6) - offroad waypoints
32 Posts 11 Posters 19.0k Views 3 Watching
    Hi all! 🙂
    It is time for a new update! 🎉
    This version is all about the support of offroad waypoints!
    Offroad waypoints
    Within the online MRA Routeplanner you can very conveniently mark some waypoints as "offroad". The main idea behind this is to skip a section of road that is unknown to the selected routing engine (HERE / TomTom / OSM). Ideal to avoid roads marked as closed (either seasonal or long term damaged) or things such as ferries.
    The app had no idea how to work with these "offroad" waypoints and just treated them as normal ones. Causing the route to be different than planned 😞
    As of now, the app does support the offroad waypoints! 😏
    In the planner you can edit any route you like and mark any waypoint as offroad! Just as in the website.
    If you then choose to navigate a route with offroad waypoints, you will see straight lines on the offroad sections. Just as planned! 😃
    These sections will be made extra clear with a nice dashed line.
    While navigating over an offroad section, some things are however different:
    • No visual instructions
    • No audio instructions
    • Possible loss of ETA information
    • Automatic recalculations disabled
    You don't need them anyway, as you're offroad.
    Android Auto / CarPlay do not support the disabling of some visual elements. This can result in a slightly suboptimal experience when on an offroad section.
    As offroad waypoints rely on track navigation under the hood, you do need to be online for an optimal experience. When offline, you will receive an appropriate warning 😉
    By introducing this feature in the app, we now support all the crucial features that the website has 🎉
    Compass changes
    A lot of users were unaware what the selected camera mode was. Not entirely their fault as the icon remained the same and you did not receive any other confirmation.
    Now when tapping the compass, the icon will change based on the selected mode. Also, you will receive a short textual confirmation of the selected camera mode.
    Bluetooth controller changes
    • Support for Remotek firmware version 2.x
    • Fixed issue with BMW Carpe Iter controller
    Minor fixes
    • iPad export option
    • Manual day / night changes from CarPlay / Android Auto changed the base map style incorrectly
    • Missing pause icons
    • Not showing the same warning multiple times
    Minor changes
    • Added a loader in the in-app planner
    • Not including current location when calculating routes that are far away
    • Showing original route just before starting navigation (not only while navigating)
    • Open route from RouteXpert library or activity feed by tapping the image
    • Flow for starting routes created in a map other than HERE
    Android specific changes
    • Hide the notification bar and on screen navigation buttons when navigating
    • Support for more "intents" ensuring MyRoute-app is displayed more often as supported app to navigate with (such as with DMD2)
    What's next
    That's it for now!
    We are currently working on a complete rework of the home screen of the app 😏 Expecting a release of this somewhere in March.
    The idea behind this is to improve the visual appearance of the app, less clicks for the user, smoother transition to navigation and offline availability of the home screen maps too.
    Cheers,
    Corjan
    cvlmtg
    cvlmtg
    cvlmtg
    just curious: why do you need to be online to navigate a track? what's the "optimal" experience?
    CD130 Corjan Meijerink MotoCon 3 Replies Last reply
    • cvlmtg cvlmtg
      @cvlmtg Good point, many off-road routes in the mountains, for example, do not go together with mobile data... Offline use is the only option.
      • Erik 35
        Erik 35
        Erik 35
        Super hoe jullie toch steeds weer bezig zijn met het verder verbeteren en uitbreiden van de Next App.
        iets waar wij als Eindgebruikers heel blij mee zijn .
        Vraagje
        In de grote update die jullie voor Maart gepland hebben is de snelheidsmeter in het scherm tijdens het rijden zonder te navigeren daar nu ook in meegenomen ?
        dat is echt iets wat ik nog steeds mis
        It's great how you are always working on further improving and expanding the Next App.
        something that we as end users are very happy with.
        Question
        In the major update you have planned for March, the speedometer on the screen while driving without navigating is now also included?
        that's really something I still miss
        • cvlmtg cvlmtg
          @cvlmtg that's unfortunately a technical limitation from HERE's side 😞
          I have requested offline support for track navigation! Not sure if or how soon they will honour that request.
          • Erik 35 Erik 35
            Vraagje
            Question
            @Erik-35 Dank voor de mooie woorden!
            Dat is nog in overweging. Anders gaat het zeker daarna wel komen.
            • cvlmtg cvlmtg
              @cvlmtg said in New update! (4.3.6) - offroad waypoints:
              @Corjan-Meijerink already explained. I'd just like to add that the availability of an internet connection is mostly important at the start of your route-as-track, especially if recalculation is disabled. The track that matches your route gets fetched from the online platform. If that is not possible, the app imitates a track based on your route, but that is less precise, and you can see the track cutting edges sometimes.
              I assume that when once the track is fetched online, losing internet connection is no big deal. So most often, hopefully hotel wifi will be good enough at the start of the route. If I am completely mistaken, hopefully @Corjan-Meijerink will correct me 😉
                @Con-Hennekens No not really 😉
                Starting online and then going offline won't work result in issues.
                However once you are offline there only needs to be the slightest deviation of the route to require internet for optimal experience. Even when recalculations are disabled and you rejoin the track, internally stuff is recalculated. Hence you'd ideally have internet.
                MartinW MotoCon 2 Replies Last reply
                  MartinW
                  MartinW
                  MartinW
                  Good to know!
                  I understand that the recalculation, which requires an internet connection, always affects the route, i.e. the ‘blue line’.
                  However, the track (or the initially calculated route when navigation route-as-track) is independent; the ‘white line’ remains visible in its original state, even without an internet connection, because it is stored locally on the device.
                  Is this correct?
                  • MartinW MartinW
                    Good to know!
                    Is this correct?
                    @Martin-Wilcke That is correct!
                    MartinW 1 Reply Last reply
                      MartinW
                      MartinW
                      MartinW
                      Excellent!
                      No matter what, you can still follow the track on sight.
                      I can't wait to try the new ‘Offroad Waypoints’ feature in MRA NN. It will make planning and navigating even longer, non-routable sections so simple.
                      You have developed an incredible solution that provides track/route-as-track navigation combined with offroad capabilities, which I have never seen in any other navigation software.
                      Well done!
                      • MartinW MartinW
                        Excellent!
                        Well done!
                        @Martin-Wilcke Thanks! 🙂
                          #21
                          @Corjan-Meijerink said in New update! (4.3.6) - offroad waypoints:
                          No not really
                          Thanks for this correction. It is difficult (for me 😉 ) to understand that a track that has already been cached is being disregarded when a route (not track!) to the nearest trackpoint is calculated (which probably should not be done if recalculation is disabled anyway). Especially, like you mentioned to @Martin-Wilcke, the white line (thus the original track in this case) is not changing. I am clearly missing something 😉
                            No not really
                            MartinW
                            MartinW
                            MartinW
                            I certainly haven't completely understood everything yet, but I know how track/route-as-track navigation basically works. If you like, we can share our thoughts.
                            Here is a good example (posted initially by @UwB), the "Maira-Stura Kammstrasse" in the Alps:
                            https://www.myrouteapp.com/en/social/route/10444583?mode=share
                            The part between VP 2 and 5 is routable with OSM/TT, but not with HERE:
                            The route is stored internally in MRA so that the calculated path is completely modelled (I don't know how this works technically; it's probably similar to Basecamp with hidden SPs).
                            In MRA NN, the route is therefore displayed in its original shape both in the preview and after opening.
                            When it is started for "route-as-track" navigation, it is treated as a track and is not recalculated - not at the beginning or during navigation (white line).
                            However, a new route (blue line) is calculated, which follows the track as closely as possible. If the route deviates too far from the track, it is displayed in this area as the crow flies, and no information (turn instructions, ETAs, distances) is shown during navigation.
                            I suspect the issues discussed here arise when you rejoin the route at VP5. The actual path does not have to be re-determined in terms of "re-routing", but something may have to be "re-calculated" to show the adjusted ETAs and distances (and maybe turn instructions as well) - even if "auto-recalc" is turned off.
                            Do you agree so far? What are your thoughts?
                              Hi all! 🙂
                              Offroad waypoints
                              Compass changes
                              Minor fixes
                              Minor changes
                              What's next
                              That's it for now!
                              Cheers,
                              Corjan
                              Erik Plaggenborg
                              Erik Plaggenborg
                              Erik Plaggenborg
                              @Corjan-Meijerink Which issues exactly did you fix?
                              Because there where a few. The extra bar-buttons didn"t react properly and trying to go trough the menu the [ENTER] by moving the wonderwheel to the right didn't work.
                              Neverteless i still am impressed by al the updates and improvements you guys make.
                              Garmin XT3
                              Samsung S25+
                              • peha
                                peha
                                peha
                                Thank you for fixing this! It eliminates an annoying bug I encountered numerous times. And I can confirm this is no longer the case. 😊
                                  Hi all! 🙂
                                  Offroad waypoints
                                  Compass changes
                                  Minor fixes
                                  Minor changes
                                  What's next
                                  That's it for now!
                                  Cheers,
                                  Corjan
                                  @Corjan-Meijerink Today was a test drive day, using Android Auto. When I pauzed the route, because of a fuel stop and the system came back on line The scree of Android Auto didn't show the map any more. The directions, speed and ETA were displayed. The audio was still working. I had to reboot the system to get the map visible again.
                                    @Martin-Wilcke sounds correct indeed! Why exactly a straight line is drawn between 2 and 5 is a mystery to me. It should approach the track where possible.
                                    My guess is that HERE really does not have a any suitable road in that area causing it to not calculate anything in that area.
                                    When rejoining at 5, it will all work as expected again and you can indeed manually follow the white line.
                                    • Erik Plaggenborg Erik Plaggenborg
                                      @Erik-Plaggenborg See this one: https://forum.myrouteapp.com/topic/8303/bmw-carpe-iter-control-hub-select-function
                                      Erik Plaggenborg 1 Reply Last reply
                                      • MartinW MartinW
                                        @Martin-Wilcke, like Corjan already stated, it sounds about right. I don't think however this has to do with the online/offline track issue. We should probably keep this thread on-topic though.
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          @Corjan-Meijerink This would be great if those features are working now. If have contacted you earlier with these little mallfunction.
                                          Garmin XT3
                                          Samsung S25+
                                          MartinW
                                          MartinW
                                          peha
                                          peha
                                          Rob Kelley
                                          Rob Kelley
                                          Erik 35
                                          Erik 35
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          cvlmtg
                                          cvlmtg
                                            Marten Wiersma
                                            Marten Wiersma
                                          • Trains like Ferries?
                                          • Opstarten app in Android.
                                            Beemerfrankie
                                            Beemerfrankie
