  4. Input Settings, Turned off v Standard
6 Posts 3 Posters 638 Views 2 Watching
  • Rob Kelleyundefined Offline
    Rob Kelley
    Hi
    I've been looking at the App input settings, mine is set to 'Turned off', the next option is 'Standard', the manual says 'Choose here whether you use standard input or BarButtons.. etc'.
    'Turned off' isn't mentioned in the manual, what's the difference between this and 'Standard'?
    Thanks
    GSA1250
    HD Street Glide
    HD Sport Glide
    XT500 x 2
    • Rob Kelleyundefined Rob Kelley
      Hi
      Thanks
      @Rob-Kelley If you’re not using Bluetooth buttons to control the app, Turned off is the setting you need.
      Rob Kelleyundefined 1 Reply Last reply
        Rob Kelley
        @Nick-Carthew Thanks but what is Standard for?
        GSA1250
        HD Street Glide
        HD Sport Glide
        XT500 x 2
        Nick Carthewundefined Corjan Meijerinkundefined 2 Replies Last reply
          @Rob-Kelley Standard Bluetooth buttons I guess. I use a SilverFox Controller so my setting is on SilverFox.
            @Rob-Kelley standard is the most common configuration that could work if you are using another device which is not listed there 🙂
              Rob Kelley
              @Corjan-Meijerink Thanks.
              GSA1250
              HD Street Glide
              HD Sport Glide
              XT500 x 2
              Rob Kelleyundefined
              Rob Kelley
              • Please allow more characters in the Note field...
              • Route Export Share
              • Suggestion: convert route to route-track from within MRA Routeplanner
                2.1k
              • Groepen - Bibliotheek - Rijden, Fietsen en te voet geeft de routes gemaakt in Motormodus niet weer.
                BertMundefined
              • MRA running on DMD
                silberfuchs67undefined
                silberfuchs67
              • POI Size
              • Distances between waypoints
                Tony 13undefined
                Tony 13
                1.3k
