  4. How to Navigate Route as a Track?
38 Posts 11 Posters 7.5k Views 7 Watching
  • LennyO Offline
    LennyO Offline
    Hello, folks!
    In the 4.3.4 release I read that you can navigate Route as a TRack, but how exactly do you do it?
    Where do you make that choice?
    Thanks!
    • Volker Lattauer Offline
      Volker Lattauer
      I have the same question. If I pick an existing route with Via and Shaping points, where do I tell my android to navigate as a track ?
      My understanding, so far, was, that tracks do not have waypoints other than Start and Finish.
      You say one can proceed to the next logical point on the track - how can that happen when there are no points?
      • LennyO LennyO
        Hello, folks!
        Thanks!
        Rob Verhoeff Offline
        @Lenny-O Go to the nav-settings in the menu.
        Menu (top left) > Settings (profile icon top right) > Navigation setting > Functional. See picture below. You can choose to disable 'Automatic recalculations'. In that case you have to navigate back to the track yourself if you deviate. Set toggle to green to allow track navigation for routes.
        • Nick Carthew Nick Carthew moved this topic from [Web] Problems, Bugs and other Issues on
        • LennyO Offline
          LennyO Offline
          Thank you, Rob!
          That helps!
          Though I would think that it may be way more convenient to make that decision on the individual Route level. Current way makes it sort of "Global".
          I mean that once you call the Route on the screen, just before you start Navigating, would be nice to choose how you want to do it, as a Route or as a Track.
          Also, will the voice guidance work when navigating Route as a Track?
          Herko ter Horst Rob Verhoeff 2 Replies Last reply
          • LennyO LennyO
            Thank you, Rob!
            That helps!
            Herko ter Horst Offline
            @Lenny-O said in How to Navigate Route as a Track?:
            Yes, it will.
            Thomas Neumeyer 1 Reply Last reply
              Yes, it will.
              Thomas Neumeyer Offline
              Thomas Neumeyer
              @Herko-ter-Horst Sorry for the maybe dumb question. I can not change the settings. The selection switches are grey.
              LennyO Corjan Meijerink 2 Replies Last reply
              • LennyO LennyO
                Thank you, Rob!
                That helps!
                This is how it used to be! Now, you just flip the toggle. Why would you want to ride a route as a track one day and as a regular route the next? In fact, I think I’ll soon be using route navigation less and switching entirely to track navigation. I’ll create the route in the planner, and when you start navigating, you can be sure you’re following your route exactly as you planned it.
                • LennyO Offline
                  LennyO Offline
                  Thank you, Herko and Rob!
                  Rob, I don't know if I would always want to ... did not try it yet.
                  But what are we losing if we switch to the Track navigation vs Route navigation?
                  There has to be something... πŸ™‚ Comments on via points? Pictures? IDK...
                  BTW, is this option Membership Level related?
                    LennyO Offline
                    LennyO Offline
                    @Thomas-Neumeyer check the version of the app you have. Maybe you need to reload? Also, are you signed in?
                      Corjan Meijerink Offline
                      @Thomas-Neumeyer they cannot be changed while navigating πŸ˜‰
                      Open the settings when you aren’t driving!
                      LennyO Thomas Neumeyer 2 Replies Last reply
                        LennyO Offline
                        LennyO Offline
                        @Corjan-Meijerink Corjan, does the option to navigate a Route as a Track have anything to do with the Membership Level?
                        Thanks!
                        Rob Verhoeff Corjan Meijerink Con Hennekens 3 Replies Last reply
                          Thomas Neumeyer
                          @Corjan-Meijerink I was sitting on the couch πŸ™‚
                          • LennyO LennyO
                            Thanks!
                            @Lenny-O I presume you have a subscription to the navigationpart, so no...
                            • LennyO LennyO
                              Thanks!
                              @Lenny-O no, definitely not πŸ™‚
                                @Thomas-Neumeyer, that maybe, but you started the navigation module πŸ˜‰ In cannot be changed while navigation is running.
                                • LennyO LennyO
                                  Thanks!
                                  @Lenny-O, no, it does not. Its a just an extra feature of the existing subscription πŸ˜‰
                                  • Martin Kjell Offline
                                    Martin Kjell
                                    Maybe I'm doing it wrong. But if I deviate from the route (as a track) with some shaping points, it still wants to reroute me back. I was stubborn and after around 10 km it told me it skipped that waypoint. Is it expected behavior. Tomtom for instance just tells me closest way back to the track in case I deviate.
                                    • Martin Kjell Martin Kjell
                                      @Martin-Kjell, Yes that's expected behaviour, if you keep being stubborn and don't follow the suggestion... πŸ˜‰ What you need to do in such a case, is long-press your own chosen point of re-entry. Then it will guide you to there, insead of back to a point you obviously don't want.
                                      Martin Kjell 1 Reply Last reply
                                        Martin Kjell
                                        @Con-Hennekens Ok Thanks! But reading the manual states that shaping points will be ingored during "route as a track". And Waypoint (via points) is never ignored. A bit contradictaional to me, or (trying to be humble) I'm probably misinterpreting the instructions. In other words, route as a track does not seem to ignore shaping points.
                                        E.g. I would like to point out a route with say for instance 10 shaping points. But circumstances like weather, change of mind, road work etc. makes me pick another route and needed to ignore shaping point #4. Since Ive passed it I would no longer be interested in that one since it's just a shaping point. But MRA "Route as a track" tries to guide me back and after a few tries gives up. For me, theres no difference from normal route. What am I missing? Eager to learn and understand.
                                          But it does. Instead of leading you back to a shaping point, it leads you back to the track. Depending on the density of your shaping points and the layout of the roads, the difference can sometimes be not so obvious.
                                          The way you describe sound perfectly logical. Navigation will lead you back to the track, sometimes that can be through a previous route point, but that does not mean it took it into consideration. Since MRA is a scenic navigation app, it tries to have you drive as much of the preplanned route as possible and only skipps parts of it after multiple redirections.
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          coupe_vs
                                          coupe_vs
                                          Martin Kjell
                                          Martin Kjell
                                          Volker Lattauer
                                          Volker Lattauer
                                          • The slow death of Zumo...
                                          • Welke instelling
                                            1.1k
                                            Carl Lee
                                            Carl Lee
                                          • Rejoining routes
                                            Terry Cox 0
                                            Terry Cox 0
                                            Karl-Heinz Schwendner
                                          • New Zealand Touring Group
