  3. [App-Beta] Announcements
  4. New beta! 4.3.4 (369) - massive navigation improvements
43 Posts 16 Posters 446 Views 7 Watching
  • CD130
    Nice update, thank you!! 👏👏👏
    Question, I would like to pause the navigation (and the track) during, for example, a tank stop or a visit to a restaurant. I don’t want the MRA app to charge my battery unnecessarily during the break and keep hearing instructions coming out of my pocket. What is the best way to do that with the current app? Placing the app to the background is not enough, is it? So choose to stop navigation? That is very inconvenient, because you always have to restart the route. Or can that be done very quickly? Is a “pause navigation” button might be useful?
    Corjan Meijerink RetiredWingMan 2 Replies Last reply
      Hi everyone! 👋
      It has been over a month since the 4.3.3 beta was started 😮
      The wait has been worth it for sure as we have been cracking our heads to improve the core of our app. Obviously it's nice to create fun features but after all we are a navigation app so it also makes sense to improve the navigation itself 😉
      A lot of fundamental aspects have been improved beyond imagination 🎉 With this update, the app will become your default go-to navigation app! I am extremely proud of the work Joost and I have accomplished 💪
      Track navigation
      Yes, it existed. With that, most was said.
      Generate a scenic route or roundtour and away you go!
      Diverting from the route or losing an internet connection would result in major issues 😞
      Now not anymore! 🎉 💥
      Track navigation works completely offline! When you go offline (either by choice or chance) the track navigation will continue working and recalculating! There might be minor differences compared to the online calculation but you are warned about that. Besides that, the original calculation will always remain visible 😉
      When you divert from your track, you will be redirected to the nearest logical point on the track. Yes, you might be sent back (depending on the location) but eventually (or immediately) you will be sent to another logical point on the track. Do you want to navigate to another section of the track? Just long press near the point where you want to rejoin! 😏
      Do you prefer navigating routes as track? Leave the already existing setting as you have it and away you go! 🎉 This works similar to the GPX 1.2 format on your Garmin.
      This means that even while navigating a track, you can skip your viapoints 💥 How amazing is that! Because you are navigating a track, shapingpoints are obviously not included. After skipping a viapoint, the fastest route is calculated to the next viapoint 😃
      When loading a track, you can now also change the setting to start from the nearest point on the track!
      Long pressing near the point where you want to continue your track, also works before starting the navigation!
      With this update, track navigation has been elevated to a level you could not have imagined. To be brutally honest, I have ridden a lot of routes as tracks and this might become my preferred method of navigating 🙂
      Dynamic routing
      Whenever you're going from A to B, you often get into traffic and a faster route becomes available. When you've enabled traffic optimisation we will now continuously search for faster routes! 🎉
      After accepting the new route (which will happen when you don’t decide within a certain time) you will still see the original route.
      Traffic warnings
      For all types of navigation, it is interesting to know if you are driving into traffic or pass an accident. Now that we are introducing the dynamic routing as explained above, it makes a lot of sense to also warn about traffic related events on your route.
      We will inform you about:
      • Traffic flow delays (significantly queued traffic)
      • Traffic incidents (accidents, closed lanes etc)
      • Road work (known construction)
      You can choose the enabled categories yourself from the settings.
      When enabled we will show an icon on the map, update the line to show the length of the delay and push a visual / audio warning.
      If a faster alternative route is available, that will automatically be suggested too! 🎉
      Destination reached
      The amount of discussion on this topic on the forum has been incredible. Since the release of the app, people have different preferences regarding what the app should do when arriving at your destination.
      Now the app will prompt to stop navigation after reaching it.
      The default setting is that navigation will stop.
      You can disable this behavior. In that case, when no choice is made, it will continue navigating as it currently does.
      Updated settings
      Check out all the updated settings and play around!
      Most changes are within the functional settings 🙂
      Automatic recalculations
      Garmin people will love this too! You can now turn off the automatic recalculations. This will force you to drive back to your route by yourself 😉 We will show the original route (as we always do) and stop actively guiding you back.
      Stop tracklog when stopping navigation
      You can now make the tracklog pause when you stop navigating automatically. Saving is always up to you 🙂
      Scaling improvement
      Some people had very small icons / lines (especially on high resolution CarPlay / Android Auto devices) while using the app. We've improved the scaling behavior of these elements on different screen sizes. Besides that, in CP / AA the shown speed limit and current speed is increased in size for those big displays.
      Visual settings CarPlay / Android Auto
      When you disable some visual elements from the settings, these are now also applied in CP / AA. Relevant ones are:
      • Speed limit
      • Visual warnings
      • Lane instructions
      Position indicator size
      You can now also increase / decrease the size of the position indicator
      Minor improvements
      • Better camera animations regarding tilt
      • Back button behavior Android on home screen
      • More waypoint information on skipping / resuming
      • Position indicator not off screen when rotating phone anymore in some situations
      • Improved shown original route data
      • Slight changes to automatic waypoint skip algorithm
      • Zoom level freedrive in CarPlay / Android Auto
      What's next?
      Well most of all, gathering your feedback and checking if everything works as expected. Besides that, the end of the year is approaching so not sure how much more massive things we will do before that 😉
      In this (and the last) updates we really try to focus on the core of the app. Previous updates had a lot of stability improvements and this one improves the navigational core of the app. My guess is, we will focus on any issues before releasing this and improving the stability further 🙂
      Cheers,
      Corjan
      Navigate route as track, this is the best solution incl. the new settings .. 👍
      Thank you, I'm very interested in testing it, but first in the car 😉
        Wow, you've been really busy the last month, well done.
        Can you please explain what the difference is now when I choose a route to navigate or a track?
        @Jörgen
        To drive a planned route with via points now as a track with via points and to set the automatic recalculation to off beforehand. So the picture remains much clearer to stay on the planned path even if there are disturbances on the track.
        This can now be done via the navigation settings / functions 👍
          @Jörgen not very much! The route calculation uses the individual waypoints and when placed correctly is the same as the track.
          The track however really uses the data how the route originally created 🙂
          The improvement is really to ensure that the navigation of any route or track you drive is perfect! A lot of users get a GPX file from tour operators which is a track. This then leads to unexpected results but not anymore! 🎉
          Try it yourself and notice how it feels the same 😉
          Dave J 0 1 Reply Last reply
          • CD130 CD130
            @CD130 that’s easy: stop and resume is the way to go and works perfect 🙂
            • Nick Carthew
              @Corjan-Meijerink I’m looking forward to testing Stop navigation on destination reached and Pause tracklog automatically a great addition to an already very capable navigation app.
              I’m assuming that with these new features, I can put the bike away, go inside and take my bike gear off, make a coffee and then save the tracklog?
              Whereas before, it always seemed like a rush to stop navigation and tracklog and then save.
                @Nick-Carthew that’s entirely correct! 🙂
                Do make sure the destination can actually be reached for it to stop. Otherwise it will still trigger when a recalculation happens extremely close to this destination 😉
                  @Corjan-Meijerink Really liking the changes but I have been trying some different settings with routes that I have to run as tracks. Where I have a circular route, the track is very different to the route. An example for this route and is similar to a number of these training routes I use for Advanced Riding with the same problem although this is probably the worst example:
                  As a route:
                  Waypoint order as expected:
                  Change to route as track:
                  The track display showing the start now at the end with nothing else (white planned route):
                  Waypoint order has now changed:
                  Not what I was expecting and thought I should highlight here.
                  Ducati Multistrada V4 Rally
                  iPhone 18 Pro
                  CHIGEE AIO-6 LTE
                  Google Pixel 6 Pro
                  Corjan Meijerink 2 Replies Last reply
                  • CD130 CD130
                    @CD130 I stop navigation when I stop for a break. I also pause the tracklog. When I'm ready to head out again I resume navigation. The tracklog automatically starts again.
                    • Dave J 0 Dave J 0
                      As a route:
                      @Dave-J-0 does not seem too strange to be honest. You’re not near the start and it seems te finish is closest to you. Try turning off “start nearest point on track” or simply longpress anywhere on the first section of the track.
                      Waypoints only include the viapoints with the original number (as changing that into order would make you loose sense of the viapoint numbering).
                      Edit: after further investigation, the behavior is indeed not logic and is improved in a new beta / the release 🙂 Thanks @Dave-J-0!
                      • Richard 18
                        Richard 18
                        Richard 18
                        Great stuff.
                        Thank you everyone at MyRoute for the hard work you put in and being so open with the whole development process.
                        Richard
                          @Corjan-Meijerink said in New beta! 4.3.4 (369) - massive navigation improvements:
                          This was ‘off’ for the missing loop which is why I thought it strange. If I select this on then the full loop appears to be correct and shown.
                          Aware that the ‘route as track’ will only show vias but if i select ‘waypoints’ then i receive a white box:
                          Should this not show the info for the vias?
                          Great work, love what the MRA Team are doing.
                          iPhone 18 Pro
                          CHIGEE AIO-6 LTE
                          Google Pixel 6 Pro
                            This sounds fantastic. My compliments for what you have done again.
                            I hope to be offered the new Beta version soon. Unfortunately, it is not yet available for Android.
                            Dit klinkt fantastisch. Mijn complimenten voor hetgeen jullie weer verricht hebben.
                            Ik hoop de nieuwe Beta versie snel aangeboden te krijgen. Helaas is deze voor Android nog niet beschikbaar.
                            • Stanisław
                              Just installed on IOS. Does it mean that we are able now to plan route using tomotom routing in the planner and then navigate by track having info about waypoints etc? I would be great!
                              Staszek
                              Corjan Meijerink Nick Carthew 2 Replies Last reply
                              • Dave J 0 Dave J 0
                                As a route:
                                @Dave-J-0 I've improved this in a next beta update / the release 🙂
                                • Dave J 0 Dave J 0
                                  @Dave-J-0 Thanks for sharing, fixed this too! 🙂
                                  • Stanisław Stanisław
                                    @Stanisław that's indeed correct however I'm slightly unsure why you'd want to do this 😉 Unless it's to use the TomTom scenic routing options and then preserve those by driving as track.
                                    Stanisław 1 Reply Last reply
                                      @Stanisław No, the app does not use the planning map from TomTom.
                                      If you want to use the TomTom planning map, use the Compare route with HERE tool to ensure that your TomTom route is followed accurately by the HERE map.
                                        @Corjan-Meijerink Tomtom in general is better for paved roads then Here, I used it for years and I liked it. Maybe it is not so important in case of well planned trips but can be an interesting option. I will test it for sure - thank you!
                                        Staszek
                                          @Nick-Carthew In case of track based navigation we could say that we can use the road planned in the MRA planner using Tomtom/Openstreet maps algorythm, moved to the MRA navigation as a track - am I wrong?
                                          Staszek
                                          Stephen Rowland
                                          Stephen Rowland
                                          Richard 18
                                          Richard 18
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
