  4. When uploading routes….
3 Posts 3 Posters 749 Views 2 Watching
  • Richard 18undefined Offline
    Richard 18
    wrote on last edited by Richard 18
    The default tab is to upload a route.
    More often than not, I prefer to upload a track, particularly when it has come from a third party, not least as I am unlikely to ride the route exactly as the third party did.
    Is there a possibility to give the user the upload option default to ‘track’?
    Thank you.
    • Richard 18undefined Richard 18
      Thank you.
      Brian McGundefined Offline
      Hi @Richard-18 I also think the upload dialog window can be a bit of a pain to use.
      Often all I recieve is a gpx file with no clue if it is a route or a track.
      My issue is that the only way I can find out with MRA which it is, route or track, is to go the though the file picker process & then be told the gpx is not a route.
      I then have to close the Upload window & repeat the whole process again selecting Route-Track.
      If it was simply possible within the Upload window to swap/choose between Route or Track after the file picker process it would be a bit easier to use
      It is a small issue but one I have repeated hundreds (thousands) of times hence the pain 🤕
      Normally navigate "Routes as Tracks" in Offline mode with Offline Maps
        @Brian-McG, I agree. Usually I import the route as well as the track so that are 2 uploads where 1 could suffice. I do this so I can confirm the route to the track, and make changes where needed.
        1 - upload file
        2 - windows shows contents of file (route, tracks, POI, can all be multiple, technically)
        3 - select the items to process into MRA (no matter the type)
        4 - press "Process" to get them into MRA
        Richard 18undefined
        Richard 18
        • New enlarge fuelstation icon gone to soon or not?
          Bouke Entundefined
        • No altitude on Android Auto screen
          Lluis Arasanzundefined
        • Altitude does not match
          7.6k
        • Seasonal closures affect not only seasonal road closures (mountain passes and the like) but also closures due to roadworks. This is why the route takes you through the closure even during planning, even though Here is actually aware of it.
          ginoginoundefined
          ginogino
        • 5.1 update lost speed up in the corner
