  4. Map showing me off route in fields!
26 Posts 10 Posters 306 Views 5 Watching
  • Arno 0 Arno 0
    I'm in France now with my camper and have had this problem every day I use MRA. At the start theree is no problem but then suddenly the showed position is flying over the map. The problem occurs both on my Android tablet and on my IPhone but not always at the same time. I use always use both now as a backup for eachother. Navigation instructions continue without any problems. Clicking on the compass does not help. It is very frustrating because I already missed the correct roads a number of times and with a camper it's not always easy to turn.
    Vince Hyde
    Vince Hyde
    Vince Hyde
    @Arno-0 I'm just back from France and had the same, fine going down the main roads but when you come off at a roundabout it just floats around making you guess where to go and then it gets back on the route but it's way off your real position, I just gave up and went google maps
    • Michael Rhys Michael Rhys
      Map showing location off route.
      On a recent trip through France the map showed me off route rather than following it. It had me riding through fields when I was actually on the road and trying to follow the route. I stopped turned phone 9off/on restarted app to no avail. I checked Apple Maps to make sure it wasn’t the gps in the phone not working but that showed me in the correct place.
      I have screenshots but can’t seem to attach them.
      @Michael-Rhys
      Okay, I didn't have that problem at all, but I think I drove offline most of the time because there was hardly any network up on the Nassfeld Pass, and I probably did it that way for the rest of the time at Lake Garda and the way back because it worked better for me, and then I stopped getting messages. Offline / Online...
      It might have been like that once, but it's cleared up if you press the compass briefly.
      Okay, ich hatte das Problem gar nicht bin aber glaube ich die meiste Zeit Offline gefahren da oben auf dem Nassfeldpass kaum Netz war , und habe es dann wohl auch für die restliche Zeit Gardasee und Rückweg so gemacht weil es für mir besser ging, es kommen dann auch keine Meldungen mehr. Offline / Online..
      Einmal wars vielleicht so, klärt sich aber wenn man einmal kurz auf dem Kompass drückt
      • Frappawotsit Frappawotsit
        @Michael-Rhys I’ve just spent 10 days around Germany, Switzerland and Austria and have had exactly the same problem. The next turn direction and distances were correct but the position on the map was often not on a road and sometimes the map was a blank screen altogether.
        @Frappawotsit said in Map showing me off route in fields!:
        Me too often got those blank maps regularly on multiple locations and days. Usually first I got what is seen in the video below, and if I let it struggle some time it changed into the blank map.
        https://photos.app.goo.gl/EVwUMfA2GFybPG346
        Restarting the the route seems too kill the frantic problem, for a while.
        G.Grote Ganseij 1 Reply Last reply
          G.Grote Ganseij
          G.Grote Ganseij
          G.Grote Ganseij
          @Con-Hennekens Last weekend I drove online in Groningen and Friesland, at first the triangle was exactly according to the location and at one point it runs about 100 meters behind very annoying, what went well are the notifications that came reasonably on time at a turn. After restarting the problem was gone for a while. Another additional point is that the app now uses a lot of power more than it can charge, later I switched to offline and I could continue with that, slowly charges.
          • G.Grote Ganseij G.Grote Ganseij
            @Corjan-Meijerink :
            Hast Du das Problem schon erkannt, es scheint im Online zu entstehen. Im Offline konnte ich es nicht feststellen.
            Ab Nassfeldpass dann zum Gardasee und ab da zurück bis Münster war ich wohl immer Offline unterwegs 👋😉
            Hoffe dein Urlaub war eine Erholsame Route
            Have you already noticed the problem? It seems to occur online. I couldn't find it offline.
            Hope your vacation was a relaxing one
            From Nassfeldpass to Lake Garda and from there back to Münster I was probably always offline 👋😉
            Stilfio
            Michael Rhys Con Hennekens 2 Replies Last reply
              @Corjan-Meijerink :
              Stilfio
              Michael Rhys
              Michael Rhys
              Michael Rhys
              @Hubert-Thoring I agree, I think the issue is when you are online, but I also have offline maps downloaded. So it should be able to revert to those when a signal is lost.
              Vince Hyde 1 Reply Last reply
                Back from vacation soon 😉
                We’ve got the issue noted and will investigate!
                Michael Rhys 1 Reply Last reply
                  Vince Hyde
                  Vince Hyde
                  Vince Hyde
                  @Michael-Rhys I only ride off line with the maps and routes downloaded and I had the issue
                    @Corjan-Meijerink :
                    Stilfio
                    @Hubert-Thoring said in Map showing me off route in fields!:
                    I could, see the earlier posted movie 😉
                      @Con-Hennekens ;
                      Ist das ein Carplay Gerät, wo du es aufgenommen hast ❓ bei meinem Handy im Offline kenne ich sowas nicht.
                      Probiere mal das ganze bei Offline lieber Con, Du weißt doch dabei sparste dann auch noch Akku 👋
                      Is that a Carplay device where you recorded it? I don't know of any such thing on my phone when it's offline.
                      Try it offline dear Con, you know you'll save battery that way 👋
                        @Con-Hennekens ;
                        Nein das ist mein Handy. Und das ist schon offline lieber Hubert 😉
                        Und ich habe auch kein Batterie Problem 😉
                          @Con-Hennekens : oh das Problem liegt dann wohl ehr bei der verwendeten Hardware. Mein iOS Handy iPhone Xr läuft ohne Probleme
                            #22
                            @Hubert-Thoring, I don't have most of the problems that are posted in this forum. I don't start by blaming their hardware. Fact is that on the same hardware this problem was not there before. Besides this, I have never seen any behaviour like this in gMaps, which I use regularly too. So my guess still is a software problem.
                              Michael Rhys
                              Michael Rhys
                              Michael Rhys
                              @Con-Hennekens I wish I could post screen shots. I think I am getting closer to identifying the issue. The problem seems to be related to the mode. If the mode is always north or the zoomed out mode things seem fine. If the mode is the one that auto zooms in then it is a disaster. I have screen shits from the 3 different modes will upload them when I return home I am still on my tour. But after 2300miles I have to say that the auto zoom mode works less than 30pct of the time. You really need to resolve this before pushing the beta to production.
                                Michael Rhys
                                Michael Rhys
                                Michael Rhys
                                @Corjan-Meijerink I have been unable to add screen shots here. However I was able to create a support request referring to this thread. On that request I was able to upload screenshots I hope they help. The issue is happening a lot.
                                  @Michael-Rhys I’ve replied to you there 🙂
                                    @Michael-Rhys, it is not me pushing anything, but:
                                    screen shits
                                    this sums it up really nice... 🤣
                                    Vince Hyde
                                    Vince Hyde
                                    G.Grote Ganseij
                                    G.Grote Ganseij
                                    Arno 0
                                    Arno 0
                                    Michael Rhys
                                    Michael Rhys
                                    Frappawotsit
                                    Frappawotsit
                                    • Strange translation
                                      10.6k
                                    • Shared toggle switch
                                    • Undo/Redo tool is hidden
                                    • Crazy routing
