  4. Power consumption
Power consumption
13 Posts 10 Posters 2.9k Views 5 Watching
  • Joro Offline
    Joro Offline
    Joro
    I'm in the Cevennes with my motorbike and test the different Navi-App with my iPhone.
    1 Point is notable: The power consumption of the myRoute App with Apple Car-Play is much higher than the other Navi-Apps like Calimoto, Scenic, TomTom, or Google Maps.
    Any plan to optimize? Otherwise I need a charging device for a whole day on my bike 😞
    Cookie On Tour Andy W GT JWR JP d 4 Replies Last reply
    • Joro Joro
      Cookie On Tour Offline
      Cookie On Tour
      @Joro I see the same here on iPhone even without Apple Car-Play, just using the app and my iPhone in my car. Sometimes even having the iPhone at the charger my battery capacity is used faster than recharged 😞
      Joerg
      (Cookie-On-Tour.de)
      • Joro Joro
        Andy W Offline
        Andy W Offline
        Andy W
        @Joro said in Power consumption:
        There was a message about this last year saying they were working on it but I don't recall seeing a further update from MRA.
        https://forum.myrouteapp.com/topic/4062/battery-usage-high?_=1726158954609
        Andy
        • Joro Joro
          GT JWR Offline
          GT JWR Offline
          @Joro well known issue, and reported many, many times. The unfortunate part is that it is a HERE issue, and the developers don't seem to be able to garner much attention with them - so it appears we are stuck until they do. The issue has been around for over a year now.
          • Lluis Arasanz Offline
            Hi All,
            Even in my car with CarPlay, and iPhone connected through cable (and charging by this cable) device alerts that Charging facility is disabled by high temperatutre on device.
            iPhone really gets too much heated and I must put it in front of air conditioned air flow.
            This does not happens if I do not use Car Play.
            Best regards
            • BMW F750GS
            Cookie On Tour 1 Reply Last reply
            • Joro Joro
              JP d Offline
              JP d Offline
              JP d
              @Joro my bike charger stopped working due to rain and my battery went from 100 to 10 in under an hour... Luckily I have my sat nav.
              • Lluis Arasanz Lluis Arasanz
                Hi All,
                Best regards
                Cookie On Tour
                @Lluis-Arasanz I have the same but without using Apple Car Play, but when I use wireless fast charging, powered by cable I don't have it.
                Joerg
                (Cookie-On-Tour.de)
                • Joro Offline
                  Joro Offline
                  Joro
                  Thank for your feedback.
                  Also the heat with the high power consumption will be a problem if you are on the road in warmer areas 😞
                  Without fixing this issue the usage of the App wouldn't make sense for me as my trips are to long for the power consumption. It’s a pity because the App has potential...
                  Walter Inacker 1 Reply Last reply
                  • Joro Joro
                    Walter Inacker Offline
                    Walter Inacker
                    I see it the same way 🤔
                    • RainerT Offline
                      RainerT Offline
                      RainerT
                      Hello,
                      I've noticed that my old Nokia 7.2 has never had any problems with excessive power consumption or overheating. No problems even on a 3 hour trip last weekend. Nor on a 5-hour tour at an air temperature of 25-27° beforehand.
                      All new smartphones have fantastically good graphics.
                      These are then sent to the display at very high refresh rates of up to 120Hz.
                      In addition, the entire display is constantly moving while driving, unlike with videos, where only the changed areas are displayed. And then at 24 - 60 Hz.
                      Perhaps it makes sense to set the refresh rate to the minimum and the resolution as well.
                      Both are possible on my Pixel 9, which I don't currently use for motorbike navigation.
                      I'm curious to see if this eases the situation.
                      Hallo,
                      es fällt mir auf, dass mein altes Nokia 7.2 noch niemals Probleme mit zu hohem Stromverbrauch oder Überhitzung gezeigt hat. Auch auf einer 3 Stunden Tour am letzten Wochenende keine Probleme. Ebenso nicht auf einer 5 Stunden Tour bei 25-27° Lufttemperatur davor.
                      Alle neuen Smartphones haben eine traumhaft gute Grafik.
                      Die dann noch mit sehr hohen Refresh-Raten bis zu 120Hz aufs Display gesendet werden.
                      Dazu wird das gesamte Display beim Fahren ständig bewegt, anders als bei Videos, bei denen immer nur die geänderten Bereiche dargestellt werden. Und dann mit 24 - 60 Hz.
                      Vielleicht ist es sinnvoll, die Refresh-Rate aufs Minimum einzustellen und die Auflösung ebenfalls.
                      Beides ist auf meinem Pixel 9 möglich. das ich aktuell nicht für die Motorradnavigation nutze.
                      Ich bin gespannt, ob dies die Situation entspannt.
                      Hallo,
                      Ik heb gemerkt dat mijn oude Nokia 7.2 nooit problemen heeft gehad met overmatig stroomverbruik of oververhitting. Geen problemen, zelfs niet tijdens een 3 uur durende trip afgelopen weekend. Ook niet tijdens een tocht van 5 uur bij een luchttemperatuur van 25-27° vooraf.
                      Alle nieuwe smartphones hebben fantastisch goede graphics.
                      Deze worden vervolgens naar het beeldscherm gestuurd met zeer hoge verversingsfrequenties tot 120 Hz.
                      Bovendien beweegt het hele scherm constant tijdens het rijden, in tegenstelling tot video's, waar alleen de veranderde gebieden worden weergegeven. En dan met 24-60 Hz.
                      Misschien is het zinvol om de verversingssnelheid op het minimum in te stellen en de resolutie ook.
                      Beide zijn mogelijk op mijn Pixel 9, die ik momenteel niet gebruik voor motornavigatie.
                      Ik ben benieuwd of dit de situatie verlicht.
                      • RainerT RainerT
                        Hello,
                        Hallo,
                        Hallo,
                        @Rainer-Treichel said in Power consumption:
                        These things have been been extensively tested at the beginning of the app project, and it made (almost) no difference, to everybody's surprise. My guess at the time was that the rendering engine does not honour the refresh rate setting of the device it runs on, but goes max capacity all the time. But if it was that simple, they would have found it by now... 😉
                        • Graziano 0 Offline
                          Graziano 0 Offline
                          Graziano 0
                          I also noticed a power consumption issue, but only when I am navigating online. If I set to offline navigation (all the rest unchanged) the consumption falls a lot, to a very reasonable level.
                          • Joro Offline
                            Joro Offline
                            Joro
                            as I wrote it is tested with a iPhone and compared with the other Navi App in the Apple Universe. In this framework the power consumption is very high. In the Android Universe it's might be different but that not the point for this post.
                            It doesn't make sense to optimize a iPhone for a single App. It should work out of the box on a similar level.
                            As a toureguide I don't have time to fiddle arround with the navi. It must function reliably.
                            JP d
                            JP d
                            RainerT
                            RainerT
                            Cookie On Tour
                            Cookie On Tour
                            Graziano 0
                            Graziano 0
                            Andy W
                            Andy W
                            Joro
                            Joro
                            Walter Inacker
                            Walter Inacker
                              Peter Burch 1 0
                              Peter Burch 1 0
                            • No location in Android Auto ! App unusable !
                            • How do I remove an old device?
                              Bruno 7
                              Bruno 7
                            • New update 5.2.1
                              1.8k
                              Jan Willem Wemekamp
                              Jan Willem Wemekamp
