  3. [App-Beta] Announcements
  4. New beta! v4.3.0 (project sync)
39 Posts 19 Posters 445 Views 9 Watching
  • Stanisław Stanisław
    @Corjan-Meijerink It is a really goos job, congratulations and thanks!
    Is there a way to mark every newly created route synced by default?
    I did a quick test, the route has been synced and works fine but there is no map preview on the initial screen, can it be improved?
    #21
    @Stanisław If you enable the sync all, this will also ensure all your newly created routes will be synced.
    To load the map, an internet connection is required at this point.
    Therefore we added a pretty custom background and simply draw the shape of the route (when you're offline) 😉 If that doesn't give you enough info, just start the navigation and those offline maps will be used!
    Stanisław 1 Reply Last reply
      #22
      @Corjan-Meijerink I aswered to myself directly after posting the message, I can set it also for a folder so all new routes will be synced then. Thanks!
      Staszek
        @Dave-J-0 It is indeed something different.
        Resume navigation immediately continues where you were when you stopped it (apparently before reaching the finish).
        Navigate will just start all over as if it's a fresh start.
        Regardless, I've changed something in this flow 😉
        @Corjan-Meijerink Brill thank you. Sync is working brilliantly for me. More testing later.
        Map styles is great and they look good on the phone. That said, they may need more contrast or vibrancy for CarPlay; I will see later.
        Ducati Multistrada V4 Rally
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        Google Pixel 6 Pro
          @Corjan-Meijerink, Great update. It usually is, but this one is very special! 😉
          One small tip concerning the sync mechanism. I think a lot of users (like me) have many folders they seldomly use, and only few that get visited frequently. It would be great if the "sync all" feature could be available on a "per folder" basis. But then again, we already established that the memory impact of hundreds of routes is not really big, so for now I will go with the overall "Sync All" feature. Thanks for that!
            Ladies and gentlemen! 🎉
            It's been a while and believe me, it has also been quite some work.
            A massive shoutout to Joost is well deserved 🙂 He works in the dark to serve the light! And he definitely brings to light to all MRA users with this update. After a lot of technical coding ⌨ we are proud to present this smashing 4.3.0 update: project Sync! 😏
            Sync all your routes
            Sync? What is sync? According to the oxford dictionary:
            in (or out of) sync working well (or badly) together; in (or out of) agreement.
            With this update, the app will sync well with the website.
            Meaning that all your routes will be magically synced across both platforms 😮 💥
            You can select to sync all your routes or choose an individual route to be synced.
            When a route (or all for that matter) is marked as syncable, any changes made to that route in the app, will be uploaded to the website. Or when the route is modified on the website, it will be automatically updated on your phone 😏
            By doing so, all your routes will be available in the app all the time and most important of all, they are up to date 🎉
            Therefore the downloads folder now no longer contains your own routes.
            Groups / events / friends are not synced or available offline by default. You will still need to download these yourself and yes, they can be found in your downloads.
            Conflict handling
            What if you made changes in the app and on the website? How do we select the right one to save? We don't! You do 😉
            Conflicts are automatically detected and you are forced to resolve these in the app.
            Restyling information screen
            To facilitate the offline availability of all your routes, the information screen has been modified too!
            A cleaner look and besides that the following options have been added:
            • Share link to route
            • Show QR code for easy access
            • Mark route to be synced
            • Delete
            Map styles navigation
            Yippee-ki-yay, motherf***er! 😃
            This one will make a lot of people very, very happy!
            The HERE map lacked some detail. Sad but true 😞
            A weird development how all major map suppliers changed their colour scheme to be less rich in contrast.
            Head over to the map styling section and be amazed! We offer 3 different colour themes and 5 editions! Are you oriented on logistical roads, we got your back! 😏 Want to use the old colour scheme? Try out "Wong" 😉
            Bonus points to the person that discovers the favourite band of me and Joost.
            Improvements generated routes
            Did you ever generate a nice route? Did you ever want to save / share that? I guess both apply to you but you could never achieve the second 😢
            An issue that is no more!
            Generate a route and with the touch of a button, you can share the same configuration to your buddy. As this is a QR code, we expect the person that scans it, to be in the same location as you 😉
            If not, just save the route! Then you can share the route and it will work too.
            Minor changes
            • Improved Spanish translations thanks to active MRA user Ramon C.L. ❤
            • You can now switch between imperial and metric directly from the app
            • HERE SDK updated to newest version
            Wrapup
            If this isn't a great update, I don't know what else we can do!
            Hopefully you all enjoy this update. There are even more little, nifty details for you to discover. We are looking forward to all your feedback over the coming days. Hopefully we will be able to release this to the public before the end of this month.
            Cheers,
            Corjan 👋
            Ruud Schouten
            Ruud Schouten
            Ruud Schouten
            @Corjan-Meijerink super! Planned a day-tour for tomorrow so nice test opportunity 👍😄
              Conflict handling
              • Delete
              Minor changes
              Wrapup
              Cheers,
              Corjan 👋
              #26
              Copy: Bonus points to the person that discovers the favourite band of me and Joost.
              My tip:
              • I tap „Standart“ is better because motorways and expressways are red.
              LG on the go
              • CD130
                Another cool update!! Very happy with the new map colors!
                Small tips/feedback:
                1. After opening the overview with all routes I get the message "Synchroniseren van bibliotheek". Then this disappears and the image jumps. Because of this jumping I have already pressed the wrong line a few times.
                2. I have to get used to the layout of the new overview of the routes. It looks a bit different than the rest of the app, but that is getting used to it I think. I don't know how it can be better either 😘
                Maybe you can do something with this feedback. Thanks for the update!!
                • CD130 CD130
                  @CD130,
                  1. I see what you mean. However on my phone the sync is really short if there is nothing to update. But when the syncing is done the routes are shift up a bit indeed. It hasn't bothered me yes, but I see what you mean. Maybe the message can be place over the list instead of on top of the list.
                  2. Hmmm, not really sure what has changed to be honest.
                    @Arno-0 This seems to always have been the issue.
                    I've fixed it for the next build!
                    Arno 0
                    Arno 0
                    Arno 0
                    @Corjan-Meijerink Thanks 👍
                      Conflict handling
                      • Delete
                      Minor changes
                      Wrapup
                      Cheers,
                      Corjan 👋
                      @Corjan-Meijerink The Android update is in the Play Store
                      • Arno 0
                        Arno 0
                        Arno 0
                        @Corjan-Meijerink Wat is de werking van de “voertuigbeperkingen” in de Kaartstijl? Dank.
                          @Marinus-van-Deudekom If I change the map style on my phone I can see it changing in the settings but when I leave setting nothing seems changed and the old map is still what I see.
                          @Corjan-Meijerink I'm I missing something
                          • Arno 0 Arno 0
                            #33
                            @Arno-0, Die instelling bepaalt vanaf welk type voortuig je de beperkingen-laag in de navigatielaag ziet. Zet je hem uit, dan zie je nooit beperkingen. Zet je hem op auto, dan dan zie je hem bij routes die gemaakt zijn met het auto-profiel, camper-profiel en-vrachtwagen-profiel. Zet je hem op camper, dan zie je hem bij het vrachtwagen en het camper-profiel, maar niet bij het auto-profiel.
                            Je stelt dus eigenlijk het lichtste voertuig-profiel in waarbij je die beperkingen wilt zien.
                              @Marinus-van-Deudekom, those settings are about navigating with the HERE maps. Start a route and you will see the difference 😉
                                @Con-Hennekens thnkx Con
                                Corjan already how to do it. 🙂
                                • richtea999
                                  #36
                                  A bit late to the party, but...
                                  Whilst riding over the past 3 days in Wales (your favourite right, Corjan?), one of the group made his routes available via Friends. As mentioned above, you can't sync, so we all downloaded the routes the night before. No problem - all three days appeared and could be opened.
                                  On opening the app the next morning the Downloads view was empty on the friend's phones. We tried this two days running - with the same result of Downloads being cleaned out, so we were forced to re-download every morning before setting off.
                                  It would a real problem if we were out of coverage because only the route owner could lead the ride.
                                  Or are we misunderstanding how Sync and Downloads interact?
                                  • richtea999 richtea999
                                    #37
                                    @richtea999, That really surprises me! I checked and have at least one route from a friend in my downloads folder. That one may well be from before the new sync function. I cleared the folder out and put some new routes in from different friends and groups. I all check tomorrow if I can see a likewise behavior.
                                    EDIT:
                                    Hmm... while doing the above, I already found a big problem...
                                    After I downloaded some routes, always ONLY the downloads from the last routemenu session are visible in the download folder. As soon as you re-renter the routes menu, all items in the downloads folder are cleared. I have not seen this earlier, because all routes from before the sync update seem to survive these unintended clean-ups...
                                    I will tag Corjan, but I know he is having vacation. I just don't know how to tag his colleagues directly. @Corjan-Meijerink, you will want to forward this one! 😉
                                    Thanks @richtea999 for your feedback!
                                    • richtea999
                                      #38
                                      Now at home, and having experimented a little more, the simplest way to lose your downloads is as you say - just re-open Routes after having downloaded your friend's route.
                                      That cleans the Downloads out.
                                      We must have carried on playing with other routes after downloading. My 'downloads lost over overnight' description is a red herring, as they say!
                                      They disappeared immediately Routes was opened again, but we didn't go back and look, I suspect.
                                        @richtea999 Fixed in the release (I've heard) 😉
                                        Arno 0
                                        Arno 0
                                        Frappawotsit
                                        Frappawotsit
                                        Ruud Schouten
                                        Ruud Schouten
                                        Stephen Rowland
                                        Stephen Rowland
                                        • Hide warnings on the map
                                        • Map Layers
                                          Martin White
                                          Martin White
                                          Michael 2v
                                          Michael 2v
                                        • Bollard trouble
