New update! (4.3.0) Project sync
Hi all!
This week, we got a lovely update for MyRoute-app coming your way
A massive shoutout to Joost is well deserved
He works in the dark to serve the light! And he definitely brings to light to all MRA users with this update. After a lot of technical coding
we are proud to present this smashing 4.3.0 update: project Sync!
Sync all your routes
Sync? What is sync? According to the oxford dictionary:
in (or out of) sync working well (or badly) together; in (or out of) agreement.
With this update, the app will sync well with the website.
Meaning that all your routes will be magically synced across both platforms
You can sync all your routes or choose an individual route to be synced.
When a route (or all for that matter) is marked as syncable, any changes made to that route in the app, will be uploaded to the website. Or when the route is modified on the website, it will be automatically updated on your phone
By doing so, all your routes will be available in the app all the time and most important of all, they are up to date
Therefore the downloads folder now no longer contains your own routes.
You also can't download your own routes as you were used to. Just sync them and you are ready to go!
Groups / events / friends are not synced or available offline by default. You will still need to download these yourself and yes, they can be found in your downloads.Conflict handling
What if you made changes in the app and on the website? How do we select the right one to save? We don't! You do
Conflicts are automatically detected and you are forced to resolve these in the app.
Restyling information screen
To facilitate the offline availability of all your routes, the information screen has been modified too!
A cleaner look and besides that the following options have been added:
- Share link to route
- Show QR code for easy access
- Mark route to be synced
- Delete
Map styles navigation
This one will make a lot of people very, very happy!
The HERE map lacked some detail. Sad but true
A weird development how all major map suppliers changed their colour scheme to be less rich in contrast.
Head over to the map styling section and be amazed! We offer 3 different colour themes and 6 editions! Are you oriented on logistical roads, we got your back!
Want to use the old colour scheme? Try out "Wong"
Map configuration
We all enjoy styling / customising the map. More settings have been added!
- Allow showing elevation differences in map (only for explore & topographic)
- Change width / opacity of the displayed lines
- Change scaling of POI icons shown on the map
- Larger range of allowed zoom / tilt adjustments
Elevation difference? Is that noticeable?
Oh hell yeah!
(old / 3d / 2d). I mean, just look at it
Improvements generated routes
Did you ever generate a nice route? Did you ever want to save / share that? I guess both apply to you but you could never achieve the second
An issue that is no more!
Generate a route and with the touch of a button, you can share the same configuration to your buddy. As this is a QR code, we expect the person that scans it, to be in the same location as you
If not, just save the route! Then you can share the route and it will work too.Minor changes
- Improved Spanish translations thanks to active MRA user Ramon C.L.
- GPX files can be uploaded to MRA simply by opening them with the app
- You can now switch between imperial and metric directly from the app
- Fixed issue where some users could not use the search
- Fixed issue that caused people from Luxemburg to not be able to save their tracklog
- General textual improvements
- Added information popups to complicated settings
- HERE SDK updated to newest version
Wrapup
If this isn't a great update, I don't know what else we can do!
Hopefully you all enjoy this update. After this update we will do another iteration concerning the app stability. Minor new features will also be added such as automatically starting your route at the nearest marker or locking your screen
Cheers,
Corjan@Corjan-Meijerink Great work
Verry happy with the hard work you all did
This is a really nice one. The devs outdone themselves!
Great job by the team. The sync works brilliantly and with such little effort by the user. It just works. Awesome.
Great work, the app becomes better and better.
Unfortunately, I hit a definite problem:
https://forum.myrouteapp.com/topic/7752/synchronization-in-the-latest-app-update-a-problem
Hi all!
- Delete
Map configuration
Oh hell yeah!
Wrapup
Cheers,
Wow, that sounds really good. Update wasn't available yesterday evening here in Germany, but now it is. Phone is already downloading
Greetings
Thomas -
Really great new functions. Also the different views for the maps. Now you can finally see the roads well with Here Map. The synchronisation is also great, but it would be an advantage if you could apply it to individual folders. I also have a lot of routes online, synchronising them all would be too much of a good thing
@Parantapa said in New update! (4.3.0) Project sync:
Just try it! It will only take 2 minutes or so, and after that, ONLY changes to existing routes, and new routes are synced!
Rob Verhoeff referenced this topic on
I am a big fan of MRA, both for the web and the app, I think the team does an amazing job.
Today I noticed that with the new app version 4.3, the width of the lines was not reflected on Carplay: I was using both the app and carplay at the same time, and on the app the lines were wide (as I set the width line parameter to x1.25) but on Carplay they were thin, just as before the update.
Is this a Carplay limitation or is this not implemented on Carplay version yet ?
Ron
iPhone 15 with iOS 17.6.1
Carplay on BMW 430i
Carplay on Innovv N1 Pro (moto) -
Ron
Carplay on BMW 430i
Carplay on Innovv N1 Pro (moto)@Ronny-Schenkels-0 Should work on CarPlay!
Maybe it did not synchronise immediately. Probably it will work as expected when reconnecting to CarPlay again.Thanks for the kind words
You automatically get a route from a foreign group whose member you are also synchronized with your own mobile phone so that it is also immediately available offline ...
Currently, this does not seem to be offered:
Two steps:
Open route in group
Download Route
Route then first start
If no net and that happens in the mountains what is then?
App was accidentally stopped during a break
Route from download load / Start ?? Would be cumbersome
For security for users in the group:
- Do I really have to go cumbersomely through the route lab in the morning and "use" the route means copying ... so it is then synchronized for offline????
We had the problems somehow in Slovenia.
VG
Two steps:
Open route in group
Download Route
VG
@Hubert-Thoring said in New update! (4.3.0) Project sync:
If you go drive routes that are not in your own library, you need to add them to your downloads, just like with your own routes before the sync update. You can then start those routes from the downloads folder, just like it always was.
No, just add them to your downloads.
@Corjan-Meijerink In the app you can now easily switch between your private routes/tracks and the routes/tracks of Friends, Groups and Events. What I don’t like is that when you switch from routes to track or the other way around, you always go back to your private routes/tracks. For me it would be more logical if you can switch between routes/tracks in the same folder (Private, Froends, Groups or Events).
This update is really awesome, great job done!
The new map styles and configurations look especially good, but sometimes I'd like to use the OSM map layer for planning. Are there any schedules for including the existing layers (OSM, TomTom, etc.) in the planner as well?
@Martin-Wilcke Those are not expected
Thanks for the kind words! -
Thanks for the kind words!@Corjan-Meijerink
Are there any particular reasons for different map sets for browsing and planning? Or will the app finally end up with HERE maps only? -
Are there any particular reasons for different map sets for browsing and planning? Or will the app finally end up with HERE maps only?@Martin-Wilcke the OSM and TomTom map are available in the web module (Gold abo only) but in the end for navigating you must convert such a route to the Here map because Next uses Here and Here only
@Marinus-van-Deudekom
Yes, I know. However, my question is not about different routing engines but about different map layers. -
BMcG referenced this topic on
@Peter-Schiefer
Agreed.
But to clarify: I'm not comparing the web planner with the app planner. It's about the different map layer sets within the app.
Several map layers are available in "browse/view" mode, including OSM, HERE and TomTom.
In "edit/planning" mode ("MRA Routeplanner"), however, we have one map layer (HERE) with various style options: Vulf, Wong, Dart and a bunch of "edition" options (explore, topo, satellite, etc.)
I'd like to know if this will be harmonised and, if so, in which way. -
@Peter-Schiefer
Agreed.
I'd like to know if this will be harmonised and, if so, in which way.@Martin-Wilcke : My experience with this is, plan no matter with which map and at the very end HERE takes over when routing.
With too few route points, it is not the app that is surprised but the driver.
HERE is the machine base the rest is for better overview.
That's how I understood it.
It was noticed:
HERE in the web planner
HERE in the app
Somehow don't seem to be the same as that was just my impression, but can also be due to the now very many setting options ....
VG
Waar dient dan nu de download map nog voor dan als we voortaan sync'n
