  4. Can't change language settings
38 Posts 6 Posters 17.7k Views 3 Watching
    @Nick-Carthew @Marinus-van-Deudekom No that's not what I meant for sure!
    This is what I meant: https://support.google.com/android/answer/12395118?hl=en
    Marinus van Deudekom Floris J 2 Replies Last reply
      @Corjan-Meijerink thnkx for that cristal clear answer
      • Dirk Kevin K.
        Dirk Kevin K.
        Dirk Kevin K.
        Good morning in the morning 😊
        here the same Problem, some settings (language, units of measurement, travel mode) are not taken into account in the app.
        Not important for me as I only tested it.
        On Web Ok
        In App not Ok
        iPhone 15 Pro (iOS 18.4.1)
        iPad Pro (iPadOS 18.4.1)
        MyRoute-APP (5.1.0 - 462), All-Lifetime)
        Honda NC750S DCT / Carpuride W502 / Garmin XT
        BMW F800R / Carpuride W702B / Navigator VI
        SENA 50S / Cardo Packtalk Edge
        • Dirk Kevin K. Dirk Kevin K.
          On Web Ok
          In App not Ok
          @Dirk-Kevin-K initially when logging in, the settings are synced. TravelMode / distance notation can be altered in the app regardless of the website.
          Language of the app can be changed on the OS itself
          Dirk Kevin K. Corjan Meijerink 2 Replies Last reply
            Dirk Kevin K.
            Dirk Kevin K.
            Dirk Kevin K.
            @Corjan-Meijerink Sure?
            Measurement Yes
            Language No 😧
            Logout / Reboot / App Start / LogIn . . .
              @Corjan-Meijerink said in Can't change language settings:
              Language indeed not - that is determined by the OS.
              I'll see if I can add a settings for that.
              Floris J 1 Reply Last reply
                Floris J
                Floris J
                Floris J
                @Corjan-Meijerink Daar had ik ook al gekeken, maar de MyRouteApp ondersteunt dit niet want hij staat niet in het lijstje.
                Dirk Kevin K. 1 Reply Last reply
                • Floris J Floris J
                  Dirk Kevin K.
                  Dirk Kevin K.
                  Dirk Kevin K.
                  @Floris-J
                  If you haven't found the voice prompt setting yet. 😌
                    @Floris-J
                    Floris J
                    Floris J
                    Floris J
                    @Dirk-Kevin-K thanks. Had ik al wel gevonden, maar die passen zich ook automatisch aan naar de taal van Android.
                    • Floris J Floris J
                      Dirk Kevin K.
                      Dirk Kevin K.
                      Dirk Kevin K.
                      wrote on last edited by Dirk Kevin K.
                      #23
                      @Floris-J
                      You can change this manually, red circle, after that i can hardly understand anything. πŸ˜‚
                        @Floris-J
                        Floris J
                        Floris J
                        Floris J
                        @Dirk-Kevin-K Hahaha, ja dat klopt, maar dan gaan ze dus bijvoorbeeld Engels praten met een Nederlandse stem of Duits praten met een Engelse stem enzo πŸ˜„
                        Ik wil gewoon m'n telefoon op Engels laten staan en alles in de app op Nederlands in kunnen stellen, maar dat kan dus blijkbaar momenteel niet.
                        Klusje voor de ontwikkelaars πŸ˜‰
                          Floris J
                          Floris J
                          Floris J
                          wrote on last edited by Floris J
                          #25
                          @Corjan-Meijerink Adding a language setting in the app would be great, thanks πŸ™‚
                          • Floris J Floris J
                            @Floris-J done πŸ™‚
                            4.3.1 will have it. Supported from Android 13 and higher.
                              @Floris-J done πŸ™‚
                              Floris J
                              Floris J
                              Floris J
                              @Corjan-Meijerink Wow, dat is snel. Kan ik mss alvast helpen met testen?
                              • Floris J Floris J
                                @Floris-J zal eind deze week gereleased worden.
                                Begin vd week beta πŸ™‚
                                  Floris J
                                  Floris J
                                  Floris J
                                  @Corjan-Meijerink ik wacht in spanning af πŸ˜‰
                                  • Floris J Floris J
                                    @Floris-J iOS heeft de instelling wel gekregen - Android helaas nog niet 😞
                                    Dirk Kevin K. Floris J 3 Replies Last reply
                                      Dirk Kevin K.
                                      Dirk Kevin K.
                                      Dirk Kevin K.
                                      Thanks and checked 🀑
                                        Floris J
                                        Floris J
                                        Floris J
                                        @Corjan-Meijerink 4.3.1 voor Android is volgens mij ook nog niet gereleased.
                                          Floris J
                                          Floris J
                                          Floris J
                                          @Corjan-Meijerink net 4.3.1 geΓ―nstalleerd maar het zit er indd nog niet in.
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Floris J
                                          Floris J
                                          • BΓ©ta to no-bΓ©ta
                                            Parantapa
                                            Parantapa
                                            John Matthews 0
                                            John Matthews 0
