  4. Strange behaviourr and Route effed up
12 Posts 5 Posters 2.8k Views 3 Watching
  • Erdna Erdna
    Cheers,
    during my tour last weekend I again had the feeling that something is not working as intended.
    First: route in MRA Routeplanner is other than what comes out of Navigation Next.
    Here´s an example, yellow line is what NN was supposed to do. Actual waypoints come from the tracklog:
    I understand that traffic, road blocks, etc. can have the route changed when starting navigation. But: deviation from the plan can mean lots of extra time needed to reach the end. IF you reach the end...^^
    In this specific scenario, NN totally effed up between waypoints 34 and 36, led me into no man´s land until at some point I reached a dead end (WP 36 and I am clearly not on the Autostrada^^):
    I then ignored any directions and tried to get back somewhere with AC and cold water to restart Navigation (WP 39/40).^^
    Intended Route: https://www.myrouteapp.com/de/social/route/9348458?mode=share
    Tracklog: https://www.myrouteapp.com/de/social/track/611251?mode=share
    What did I do wrong in planning or what am I missing? I have a couple more situations like this tracked and can provide on demand.^^
    Note: since I experienced problems with skipped waypoints in the past I followed advice to use less waypoints. In this case, it didn´ t go well.^^
    Fossibot F101 Pro, Android 14
    NN 4.1.3 - 312
    Offline Nav, online only to load the route
    Cheers from Austria,
    André
    @Erdna The first thing I notice is that, if I use your originally planned route, there are no other waypoints scheduled between waypoint 3 and 4. You leave the route calculation to Navigation Next. Just past waypoint 3, I see a roadwork icon (see picture). Could the app have thought it couldn't proceed further and devised an alternative route? I would have definitely placed more waypoints (shaping points) between 3 and 4.
    The same applies to the section where you say the app completely lets you down. Why not choose to add more shaping points? By doing so, you don't leave the determination to the navigation engine but keep control yourself!
    GT JWR 1 Reply Last reply
      @Rob-Verhoeff perfect example of why the developers need to increase the size of icons to make them visible/discernable, and to reduce the width of the blue route line, which tends to cover up the much thinner yellow & red lines when route traffic shows up. 👍
      • Erdna Erdna
        Cheers,
        NN 4.1.3 - 312
        André
        Erdna
        Erdna
        Erdna
        I am a little bit confused.^^
        I had another issue with skipped waypoints and was advised to use less waypoints. That´s what I tried here, because it didn´t really matter.
        But: I should be able to rely on the route and when checking early in the morning, Routeplanner showed what I pictured. Route started with NN a few moments later should not be differing that much in my opinion. If there´s roadworks, Routeplanner and NN should have the same result, shouldn´t it?
        • Erdna Erdna
          @Erdna It's my assumption that it does! Regarding your comment about the number of waypoints, I use as few as possible, but as many as necessary to ensure that my proposed route is actually followed. This means that I often place at least one waypoint (shaping point) on every road I want to travel on.
          • Erdna Erdna
            Cheers,
            NN 4.1.3 - 312
            André
            @Erdna, It looks to me that due to external circumstances the GPS placed you on a road on which you were not. Blindly following instructions in such a case can lead to strange locations. I assume that the road below on the left in your picture was the road intended by the route? They are very close to each other, so a small error in GPS reception is not very unlikely.
            Erdna 1 Reply Last reply
              Erdna
              Erdna
              Erdna
              @Con-Hennekens said in Strange behaviourr and Route effed up:
              @Con-Hennekens I was curious where that path would lead, so I followed it. I am an experienced rider and calculate risk of being stuck, but I´m also an explorer. Sometimes one has to turn around and sometimes you´ll have great experiences... 🙂
              The road below on the left is an Autostrada, and that´s the least where I want to be while touring.^^
              The planned route would have the Autostrada on my right side. GPS mismatch may be, but it must have happened long before I reached that point.
              MotoCon Erdna 2 Replies Last reply
              • Erdna Erdna
                @Erdna said in Strange behaviourr and Route effed up:
                So actually it is not a malfunction, but a feature 🤣
                  @Con-Hennekens a dusty feature... 🤣
                  • Leike Lodiers Leike Lodiers
                    @Leike-Lodiers, like curvy roads: dusty roads 😉
                    • Erdna Erdna
                      Erdna
                      Erdna
                      Erdna
                      In case somebody is interested how that CBF1000 got there:
                      https://youtu.be/dmQKjqH4-qE
                      • Erdna Erdna
                        @Erdna very nice trip beautiful roads... 👍🏻👍🏻💪🏻
                        Erdna
                        Erdna
                        • Béta to no-béta
                          Rob Draaisma 0
                          Rob Draaisma 0
