  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 4.2k Views 3 Watching
  • fbarr47gmail.comundefined Offline
    fbarr47gmail.com
    I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
    thanks!
    Nick Carthewundefined Reinhard-32undefined 3 Replies Last reply
    • fbarr47gmail.comundefined fbarr47gmail.com
      thanks!
      @FRANCISCO-BARRENA Click the title of the column in your library to change the order. Name, Type, Change etc click it again to reverse the order.
      MRA Navigation Next and SilverFox B8J bar buttons.
      Quadlock wireless mount for IPhone 11.
      Cardo Scala Packtalk Bold.
      TomTom Rider 500. (In the cupboard now)
      fbarr47gmail.comundefined 1 Reply Last reply
      • Rob Veermanundefined Offline
        Renaming your routes by giving them a letter, number (by date or whatever). They will then be sorted in that new order.
          fbarr47gmail.com
          @Nick-Carthew sorry but that not work like this. If CLICK the title , OPEN the file... I want place in order. I want go down 2 places more down. I can't mark the file and drag it to another position?? that would be simple.
          Rob Veermanundefined Marinus van Deudekomundefined 2 Replies Last reply
            @FRANCISCO-BARRENA As I wrote, rename the files. Something like 240601, 240602, 240603 and your files will be sorted that way.
            • Rob Veermanundefined Rob Veerman
              fbarr47gmail.com
              @Rob-Veerman but I don,t want rename the files... I prefer the files with the name of the route.. Not is possible to drag the files to another position????
                @FRANCISCO-BARRENA what you want is impossible. You like Nick said you can sort them by clicking on the column's title. By name date etc. Changing the order in witch they appear can't be done without changing the titles like Rob said
                Samsung S20FE mounted on a Quadlock and using Android Auto in my car
                  thanks!
                  Reinhard-32undefined Offline
                  Reinhard-32
                  @FRANCISCO-BARRENA said in Move routes of position:
                  thanks!
                  You can add a number at first as beginning of the route name.
                  Kindly regards
                  Reinhard
                  TomOnTourundefined fbarr47gmail.comundefined 2 Replies Last reply
                    thanks!
                    TomOnTourundefined Offline
                    TomOnTour
                    @Reinhard-32 said in Move routes of position:
                    thanks!
                    That is exactly how I do it with my routes. 🙂
                    Works perfect for me.
                    Greetings
                    Thomas
                    MyRoute-APP Navigation Next Lifetime (4.3.9)
                    iPhone 12 Pro (iOS 18.5)
                    on KTM 1290 Super Adventure R (model 2022)
                    using iPad Pro (iPadOS 18.5) and Macbook Air (macOS 15.5)
                    Erdnaundefined 1 Reply Last reply
                      thanks!
                      Greetings
                      Thomas
                      Erdnaundefined Offline
                      Erdna
                      @TomOnTour said in Move routes of position:
                      thanks!
                      Greetings
                      Thomas
                      Same here.
                        thanks!
                        fbarr47gmail.com
                        @Reinhard-32 yes, like this I have done in my routes and not work properly. The route num 3 not in position
                        Reinhard-32undefined 1 Reply Last reply
                          Reinhard-32
                          @FRANCISCO-BARRENA That is strange. I can see there are dots in your route names and after the route numbers. Remove them could be helpful. It is often not a good idea use special characters in file names.
                          Kindly regards
                          Reinhard
                            GT JWRundefined Offline
                            @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
                            • GT JWRundefined GT JWR
                              Reinhard-32
                              @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
                              Kindly regards
                              Reinhard
                                fbarr47gmail.com
                                I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
                                  Reinhard-32
                                  @FRANCISCO-BARRENA
                                  No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
                                  You could temporarily rename route no. 3 to something like 15 or so.
                                  BTW: The sort order goes from left to right and from numbers to letters.
                                  If you have more than 9 routes it is recommended to use 2 digits like this:
                                  01
                                  02
                                  09
                                  Otherwise you will get:
                                  Kindly regards
                                  Reinhard
                                    @FRANCISCO-BARRENA
                                    01
                                    02
                                    09
                                    @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
                                    Herko ter Horstundefined Con Hennekensundefined 2 Replies Last reply
                                      @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
                                        @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                                          @Marinus-van-Deudekom said in Move routes of position:
                                          In that case Route 8 would be sticking out 😉
                                          But no, the name column is selected.
                                          Reinhard-32
                                          GT JWRundefined
                                          Erdnaundefined
                                          Erdna
                                          TomOnTourundefined
                                          TomOnTour
                                          BFGundefined
                                          BFG
                                          fbarr47gmail.com
                                          • First point is often ignored
                                            Herman Veldhuizenundefined
                                          • Snelwegen vermijden
                                            Lex.Kloet.RXundefined
                                            Lex.Kloet.RX
                                          • New update! (4.4.0)
                                          • Scrolling Through Waypoints
                                            JP dundefined
                                            JP d
                                          • MyRoute Navigation Next (Samsung Active5 tablet) Review
                                            Lex.Kloet.RX
                                          • In app route generator not close to desired distance
                                            Stefan Hummelinkundefined
                                          • Positief bericht
                                            Mzokkundefined
                                          • Die App kann keine kurvenreiche Route über 300 KM erstellen?
