  4. BMW Connected Ride Navigator not importing waypoints
41 Posts 7 Posters 27.0k Views 4 Watching
  • Philip Goh Philip Goh
    @paul69 I imported the route. However there is little difference in the route vs track when it comes to support points. Importing the waypoints alone gives me just a straight line between the start and the end.
    @Philip-Goh
    i have downloaded the same route as the one you used, i do not seem to be having the issue that you have
    as you can see i have something similar to you except my route only shows 32 support points.
    i have added a capital A to the name just for reference.
    this was in the mRA app on my iPhone.
    the route saved in my routes on the website,
    MRA app>click route> click download as 1.1gpx>then click export>click connected app>this gives the above page>select route to import.
    K1600 GTL
    iPhone 13 Pro, carpuride 702b
    • Dikke Wim Dikke Wim
      @Philip-Goh
      This is also what I see when exporting from MRA to the Connect Ride app on my iPhone WHEN I EXPORT the route as a GPX1.2 file. When exporting as a GPX1.1 file, the number of point in the route are always below 50.
      Like the Track, also the route with the many points (sometimes >3000) can be used by the CRN!
      Philip Goh
      Philip Goh
      Philip Goh
      @Dikke-Wim This was it!! I was always using GPX 1.2 and that seems to generate files that are 2x the size of the GPX 1.1 files. When I switch to using GPX 1.1, then it works as expected!
      GPX 1.1 is the way to go for BMW’s connected ride app and navigator.
      Dikke Wim 1 Reply Last reply
        Dikke Wim
        Dikke Wim
        Dikke Wim
        @Philip-Goh said in BMW Connected Ride Navigator not importing waypoints:
        Exctually, I'm not sure yet that GPX1.1 is the best option. If I look at the ROUTE in the pictures above, I see differences between the route and the Track.
        A good check is to:
        • make the track visible (e.g. in the color black instead of the default white color)
        • then start the route with the fewer waypoints (<50)
        • compare the route with the tack on the map.
        • differences are easily seen when the blue line (route) deviates from the black line (track).
        I'm curious about the result.
        Please let me know the outcome!
        Philip Goh 1 Reply Last reply
          A good check is to:
          Philip Goh
          Philip Goh
          Philip Goh
          @Dikke-Wim you have to do what Hans suggested above, which is to take the route, convert it to a set of waypoints and then the route looks very similar to the track. Much better than what was in the screenshot.
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Philip-Goh
            Thanks for adding this information. Very useful.
            Indeed, the route becomes much better and similar to the track after calculating the routepoints in de Connect Ride App on the smartphone. Once inside the Connect Ride Next it looks good!
            So the small image of the route in de App is misleading.
            paul69 1 Reply Last reply
              @Philip-Goh
              @Dikke-Wim said in BMW Connected Ride Navigator not importing waypoints:
              and that is exactly the information given in the link i posted at the beginning of this thread.
              K1600 GTL
              • paul69 paul69
                Dikke Wim
                Dikke Wim
                Dikke Wim
                @paul69
                Sometimes I'm hard learning... 🙂
                  @paul69
                  hi
                  did you look at the thread I inserted. although it's a different forum.
                  I have actually copied into pdf doc and have easy access to it, for when i forget how to do it.
                  K1600 GTL
                  • paul69 paul69
                    hi
                    Dikke Wim
                    Dikke Wim
                    Dikke Wim
                    @paul69
                    Could you upload the pdf file here?
                    That would be nice.
                      @Topcat502
                      Use the TomTom map, use max 50 shaping points. Then send it to the connected app, choose the track and route with 50 points.
                      Then in the route file tick on the 3 dots in the upper right corner and choose convert to route with points. The 50 points will be visible.
                      Choose that route on the CRN and you can also make the track visible on the CRN
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      @Hans-van-de-Ven-MR-MRA
                      Hans, I'm curious. Why would you use the route with the waypoints visible? There is no difference between VIA-points and FORM-points. For me it would make sense if you could maken only the VIA-point visible (lunch stops, coffee breaks, castles, etc.). When do you use these waypoints that are visible in the CRN as balloons?
                      Maybe I miss it but wat is the advantage of seeing all waypoints? The route without the waypoints is the same.
                      The only thing I can think of is that you can REMEMBER that e.g. waypoint 20 is a coffee break.
                      A workaround is to add favourites by hand (one by one) in the CRN. These points are visible as a balloon with an asterisk.
                      Hope te hear from you!
                        @paul69
                        That would be nice.
                        @Dikke-Wim
                        hi,
                        not sure it's possible to upload files
                        K1600 GTL
                        • paul69 paul69
                          @Dikke-Wim
                          hi,
                          Dikke Wim
                          Dikke Wim
                          Dikke Wim
                          @paul69
                          I don't see an option either. No problem. I think I have enough information already.
                            @Dikke-Wim
                            The CRN sees all points as injured points, if you change the name of the points, you will see the name in the CRN at a point, for example Coffee or lunch.
                            You will not receive a notification from the CRN, but you can see them. Or indeed remember the number where you want to stop.
                              @paul69
                              hi @Dikke-Wim
                              when i found the thread regarding this process (at the beginning of this thread), i just copied the whole explanation into a word doc, then formatted it to make it more readable and then exported to pdf. i am no computer wizard.
                              incidentally @Topcat502 who started this topic, i hope all these replies have helped you with your query.
                              K1600 GTL
                              • Topcat502
                                Topcat502
                                Topcat502
                                wrote on last edited by Topcat502
                                #27
                                Hi all. Really appreciate the help from all, but what an absolute faff!! It looks like MRA and CRN doesn't play well together and hopefully MRA will rectify this in the future. Other GPX files we have downloaded from other bike sites have worked fine. We ride to planned routes so need the waypoints/shaping points, always have. Sadly, regretting buying MRA/CRN at present. Fingers crossed on future updates.
                                • Topcat502 Topcat502
                                  @Topcat502
                                  So what doesn't work? Can you share some screenshots of what you see in the CRN of other gpx files and not of an MRA file.
                                  Topcat502 1 Reply Last reply
                                    @Dikke-Wim
                                    Dikke Wim
                                    Dikke Wim
                                    Dikke Wim
                                    Ik probeer de namen van de punten in de Connect Ride App te veranderen nadat ik een route vanuit MRA heb geëxporteerd als GPX 1.1 file en heb omgezet naar route met waypoints.
                                    Helaas kan ik dan geen namen van de routepunten aanpassen.
                                    Hooguit kan in in MRA de namen veranderen (bv. Lunch, koffie, etc.), maar die namen komen niet terug in de Connect Ride app op mijn iPhone. Ook niet op de CRN zelf.
                                    Hoe kun jij de namen veranderen zodat ze uiteindelijk op de CRN zichtbaar worden?
                                    Ik hoor graag van je Hans!
                                      @Topcat502
                                      Topcat502
                                      Topcat502
                                      Topcat502
                                      @Hans-van-de-Ven-MR-MRA !
                                      I'm not saying it doesn't work, but it just seems very strange to need these workarounds when previously technology has worked fine.
                                      The top route is a gpx file showing a route made in Basecamp. As you can see it has the waypoints already set up as per the gpx file created. This can be imported directly into the CRN.
                                      This shows the same route created in MRA and exported as GPX 1.1
                                      As you can see the CRA shows them as support points and as you have explained, the route has to be converted to waypoints in the app, you then have to export this to the CRN (because you don't have the option to convert in the CRN. )
                                      Other points to note are that, unlike our previous NAV5, there isn't the option to "fix" your route. Therefore, if you're like us and ride to planned routes (either from mags or ones we've created) we have to add more waypoints than previously added because it doesn't recognise shaping points and is more likely to take you off your route. We have to add them in after junctions so that it sticks to the route as much as possible, but then if needed we can skip them due to traffic/road closure etc. Therefore, the 50 max waypoints doesn't help and we have to break up our tours into smaller chunks. I understand this isn't an MRA issue and hopefully the CRN will provide further updates from everyone's feedback as it's still relatively new.
                                      As I say it's not impossible, but for us, using Basecamp and the NAV5 was straight forward to plan, export and ride our routes compared to MRA/CRA/CRN set up.
                                        @Topcat502
                                        Different technology.
                                        BMW Nav 5 and Basecamp = Garmin
                                        BMW Connected App and the CRN = TomTom
                                        Jez 0 1 Reply Last reply
                                        • Topcat502
                                          Topcat502
                                          Topcat502
                                          A further update to this
                                          We've now done a ride where we have converted to waypoints through the Connected Ride App and then used the CRN to navigate. It doesn't recognise the difference between a destination and a waypoint, as the navigation display shows ETA for the next waypoint and the destination as the same. It also removes the waypoint from the route on the map as you go along. It doesn't alert you to the name of the waypoint either, it just tells you (sometimes) that you have reached your destination.
                                          Dikke Wim
                                          Dikke Wim
                                          Jez 0
                                          Jez 0
                                          Kenneth de Miranda
                                          Kenneth de Miranda
                                          Philip Goh
                                          Philip Goh
                                          Topcat502
                                          Topcat502
                                            Rene van Maanen
                                            Rene van Maanen
                                            Helmut h
                                            Helmut h
                                            Òscar
                                            Òscar
