  4. What happens if you start a planned route in the middle?
30 Posts 8 Posters 4.5k Views 4 Watching
  • Thomas Scharrerundefined Offline
    Thomas Scharrer
    This is just a technical question.
    What happens or how will MRA react in case you would start a planned route maybe from the middle?
    I am asking this because there can be several reasons for such a case for example an app crash once you have started your route or if you have planned a several day route and you start the next day from the middle etc.
    In such a case will MRA recognise this and skipp all the previous waypoints from the earlier part of the route or will it try to navigate you back to the start?
    I had such a situation once before the last update and then it was quite a disaster I would say because MRA tried to navigate me to the beginning all the time.
    GT JWRundefined Marinus van Deudekomundefined 2 Replies Last reply
    • Thomas Scharrerundefined Thomas Scharrer
      GT JWRundefined Offline
      @Thomas-Scharrer that has been my experience as well. You will have to manually delete the waypoints prior. It can be done one by one, or if you know the next waypoint, long press it, say yes, and it will start where you are.
      Con Hennekensundefined abowenundefined 2 Replies Last reply
        @Thomas-Scharrer That depends on what you are doing at that time. If you realy start the route in the middle it will take you back to the start. Solution push on the next shapingpoint near to you and hold it. The app will then take you there skipping the previous ones.
        I you stop half way ( or any other point) and shut down your phone on the restart it will guide you to the next shaping point.
        Last saterday I did just that en it never failed.
        Thomas Scharrerundefined 1 Reply Last reply
          Thomas Scharrer
          @Marinus-van-Deudekom @GT-JWR
          thanks a lot for the information, good to know
          • GT JWRundefined GT JWR
            @GT-JWR said in What happens if you start a planned route in the middle?:
            I am happy to say this is of course entirely not true.
            You can start your route from any waypoint you like simply by tapping and holding it for a second.
              Thomas Scharrer
              Thanks, that sounds even better
                M. Schrijverundefined Offline
                All the tools are already available in MRA but how they works is a bit odd. That's why my prefered choice isn't possible.
                This option could have a better use it should be used now.
                If enabled like in the screenshot. The route should start at current position and navigate you to the nearest upcoming waypoint. And if possible just follow the original route.
                I think this what most people want and what @Thomas-Scharrer is looking for.
                If disabled. You must go the startpoint of the route.
                And offcourse. What already mentioned pressing a waypoint of your choice.
                I think this one is too complex for a quick restart. Because you need to scroll along the route to search for the waypoint of choice.
                Con Hennekensundefined Thomas Scharrerundefined 2 Replies Last reply
                  @M-Schrijver said in What happens if you start a planned route in the middle?:
                  If you are halfway your route, the app already shows your position. You just have to zoom out a bit to see the closest waypoint. Let's not make a mountain out of a molehill.
                    I don't. I could be easier. It must be easier.
                    Less user input is always better. Software should be more "intelligent". I told it more than once before. Other software prove this is possible.
                      Thomas Scharrer
                      @M-Schrijver
                      What is shown in your screenshot is very interesting but unfortunately I cannot find this function.
                      I agree that the whole system with skipping waypoints manually by pressing them etc is no problem in a car but that is exactly my problem on motor bike because I cannot operate the phone all the time and that makes this somewhat more difficult but not impossible of course because you can always stop to do it quickly.
                        Exact. You prove my point.
                        You mus recognize the "start" button. Because it is there everytime.
                        Slide the black menu upwards and you will see more options.
                          Thomas Scharrer
                          @M-Schrijver
                          Thanks a lot I got it now ๐Ÿ™‚
                            @M-Schrijver
                            Thomas Scharrer
                            @M-Schrijver
                            Have tried this now and I can see the the functions or navigation options in the menu below the start button are not saved permanently so you need enable/ disable them every time..... thats also good to know, not just to to press start but first choose the options you want each time
                              @M-Schrijver
                              @Thomas-Scharrer the options are the ones you activated saving the route. Calculating from this point is default on. So I think thereโ€™s no need to make this menu bigger by default
                                abowenundefined Offline
                                abowen
                                @GT-JWR Hello, does anyone know if this functionality exists in the CarPlay version of the Navigation app? Is it possible to find the waypoint you wish to begin with and long press it (or equivalent) to begin a route in the middle? Thanks.
                                • abowenundefined abowen
                                  @Alan-Bowen if it is in CarPlay, I haven't been able to find it/make it work...I do it from the app.
                                    No it is not available. Some improvements are still needed
                                      @M-Schrijver correct!
                                      Things like this are not very trivial for CarPlay / Android Auto ๐Ÿ™‚
                                        Not very trivial?
                                        The question in the first post is very trivial for AA and ACP.
                                        MRA Next asks too much during the day when riding a route. Answering these questions is not possible in AA and ACP. MRA Next should asked nothing. It only must do the thing it is build for. Guides you when riding a preplanned route.
                                          Not very trivial?
                                          @M-Schrijver resuming navigation is possible from Android Auto, resulting in the route resuming exactly from where you stopped it.
                                          Waypoints can be skipped directly from Android Auto one by one.
                                          Skipping a lot of waypoints in one go is only possible directly from your phone. In the future that will be possible from Android Auto too ๐Ÿ™‚
                                          GT JWRundefined
                                          Thomas Scharrer
                                          abowenundefined
                                          abowen
                                          Leike Lodiersundefined
                                          • construction of a path without logic and different from Maps
                                            Giuseppe Marinoundefined
                                            Giuseppe Marino
                                          • Harley Davidson Skyline OS for 2024/25 model Street and Road Glides.
                                          • Please add additional waypoint icons for car or campervan
                                            Inge Bakermansundefined
                                            Inge Bakermans
                                          • After upoad from Zumo 590: Tracklog "current(1) is not identical with the single tracklogs.
                                          • Do I need Next with a Gold subscription?
                                            Lex.Kloet.RXundefined
                                            Lex.Kloet.RX
                                          • Automatically Skipping (shaping) Waypoints in Apple Carplay
                                          • Skyline OS IFCU Harley
                                            Rob Lindsayundefined
                                            Rob Lindsay
                                          • Weather overview
