  4. Tablet kan geen route berekenen met offline kaarten.
38 Posts 8 Posters 17.2k Views 2 Watching
  • Leike Lodiers Leike Lodiers
    Ik heb de kaarten gedownload voor offline gebruik op mijn carpe iter v4b. Als ik nu een track of route download voor offline gebruik! En ik klik op navigeren vraagt mra om online te gaan omdat hij geen route kan berekenen met de offline kaarten... 🥺🥺
    I downloaded the maps for offline use on my carpe iter v4b. Now when I download a track or route for offline use! And I click on navigate, MRA asks to go online because he cannot calculate a route with the offline maps...
    @Lei-Lodiers put in a clip of the problem
    https://photos.app.goo.gl/Mvb8DmodxYxp4ypv5
      I see what you mean. But i cannot replicate it.
      I am also on "Offline" navigation. But i can select my route from my online collection. That is one big difference. Even with WIFI of i can select a route from my online collectiom
      When i selected a route from my "downloads" folder (for offline navigation) i can still navigate.
      I also did a test where i disabled WIFI and Mobile data. In this case i was, just like you, diverted to the downloads folder. Here i select a route. Pressed on Navigate and the route did start on my phone
        @M-Schrijver on my phone it's the same problem.. I don't now why it won't work.... Reset all deleted and re-installed the app bud stil the same problem acurs.. Even did the duck duck go uninstall I did read about.
          Did you check if the offline maps really are downloaded?
            @M-Schrijver where can i check this? The app says they are..
              @Lei-Lodiers go to offline maps and scroll to the maps for NL and make sure there is a checkmark beside it.
              • Bouke Ent
                #26
                i did test it on my phone with 305 build, no internet offline maps for NL, DE and BEL. in setting use offline navigation. did download route and store it in downloads and started route as a route and not as a track. i have gold MRA and MRA Next.
                it works with me.
                  @RetiredWingMan all maps are there the strange thing is it happens on my carpe iter tablet and on my samsun s21 ultra. So I think there's something wrong with my account...
                    @Leike-Lodiers just bought the gold and next lifetime membership. Re installed the app and maps. Problem remains .
                      @Lei-Lodiers No, your 14 day free trial should give you full access to everything
                      @Nick-Carthew upgraded to gold lifetime still the same problem.
                        jpgoderis
                        jpgoderis
                        jpgoderis
                        @Leike-Lodiers ik heb hetzelfde probleem hier met mijn CI tab.
                        Ik kan zelfs geen offline kaarten downloaden op de tab. Als ik een route wil navigeren lukt het ook niet zelfs verbonden via wifi met het net.
                        Ik heb een ticket aangemaakt en gechat met Corjan en hij ging het probleem doorgeven.
                          @Leike-Lodiers I would create a new ticket in the Support section of MRA. There is obviously a problem.
                            @Nick-Carthew already did. Thnx for the support.
                              @Leike-Lodiers,
                              Er is een simpele reden hiervoor: Je "route" is geen route maar een routetrack. Tracks kunnen ALLEEN online worden gestart.
                              The simple reason is this: the "route" is no route but a routetrack. Tracks can ONLY be started online.
                                @Leike-Lodiers,
                                @Con-Hennekens kan ik hiervan wel een route maken met route lab.
                                Can I make a route from this track with route lab
                                GT JWR 1 Reply Last reply
                                  @Leike-Lodiers yes, you can. When you open a route in the route planner, wheter it be a track or a route-track (the one in the pic is a route-track), click the icon circled in red...your then off to the races.
                                  • GT JWR GT JWR
                                    @GT-JWR that did the job alle routes even omgezet van track naat route met route lab. Nu werkt de offline navigate wel. thnx item kan gesloten worden........
                                    that did the job all tracks rewritten to routes with route lab now i can navigate offline..
                                      @Leike-Lodiers, Fijn dat het werkt. Het omzetten van de track in een route vereist wel enige controle na het omzetten. Zet de waypoints OP de weg, en ver genoeg af van kruisingen, afritten, rotondes en dergelijke. De routine heeft de neiging op waypoints op een "knik" te zetten, en dat is meestal niet de beste plek 😉
                                      Een andere oplossing kan zijn om je track te starten MET een werkende internetverbinding. Als die eenmaal loopt gaat het meestal goed, ook als je de verbinding kwijt raakt. Zolang je de track volgt is er geen herberekening nodig, en dus ook geen internet.
                                      Maar een route is altijd beter, maar kost ook wat meer tijd en voorbereiding natuurlijk.
                                        @Con-Hennekens yep gemerkt alles gecontroleerd en de glitches eruit gehaald. Nu routes nog een rijden en vullen met info en foto's.....
                                        jpgoderis
                                        jpgoderis
                                        • Béta to no-béta
                                          Cleo
                                          Cleo
