  4. unable to calculate route
27 Posts 3 Posters 9.5k Views 2 Watching
    @Patrick-33 did you actively deny the requested location permissions or were they never prompted?
    Please check the location permissions of the app and allow them πŸ™‚
    Then report back to see if the issue is resolved. I see a lot of error messages stating that the location could not be retrieved.
    Patrick 33
    Patrick 33
    Patrick 33
    The authorization was set to "only allow if the app is used". I put "always allow"
    I restarted the app, but still the same message.
    I send a new log file
    • Patrick 33 Patrick 33
      @Patrick-33 now it's interesting πŸ™‚
      Thanks for the quick cooperation.
      I unfortunately don't see an obvious issue in the logs 😞
      Will research this a bit more later on.
      Patrick 33 4 Replies Last reply
        Patrick 33
        Patrick 33
        Patrick 33
        @Corjan-Meijerink Thank you for your help
          Patrick 33
          Patrick 33
          Patrick 33
          There is also the problem that I cannot download the maps offline. If it helps...
            Patrick 33
            Patrick 33
            Patrick 33
            If it helps, in the "Download" and "Downloads" menus I don't have any files while on the phone, they are present.
            I feel like I'm always offline on the tablet...
              Patrick 33
              Patrick 33
              Patrick 33
              @Corjan-Meijerink Good morning, For your information, I just reset the tablet settings and everything works again on the myroute application.
              MotoCon Corjan Meijerink 2 Replies Last reply
                @Patrick-33, thanks for reporting back. Did you have any security, anti-virus or, privacy apps installed previously by any chance?
                Patrick 33 1 Reply Last reply
                  @Patrick-33 great! πŸ™‚
                    Patrick 33
                    Patrick 33
                    Patrick 33
                    @Con-Hennekens said in unable to calculate route:
                    Yes, it has BitDefender on it.
                      @Patrick-33, I think it will be mighty interesting if you reinstalled Bitdefender after resetting your tablet, and if your testing was done prior of after that. Bitdefender probably has some code that could intervene with access to the HERE servers. For DuckDuckGo this has already been proven less or more...
                        Patrick 33
                        Patrick 33
                        Patrick 33
                        wrote on last edited by Patrick 33
                        #24
                        I uninstalled and reinstalled BitDefender and yes, it is the problem.
                        Unable to calculate route.
                        I'm uninstalling Bit defenbder at the moment.
                        Edit : And it's persistent because even after uninstalling BitDefender, I still have to reset the settings.
                          @Patrick-33 said in unable to calculate route:
                          Thanks for trying and reporting. If you want to keep using BitDefender on your device, I assume there are methods for whitelisting specific apps in some controlpanel. You might get some help with that through their customer support or forum.
                          @Corjan-Meijerink, Looks like we have another culprit to add to the list πŸ˜‰ . Maybe it is wise to check of the HERE (or MRA?) servers are on some blacklist that is used by some of the AV or privacy software companies?
                            Patrick 33
                            Patrick 33
                            Patrick 33
                            #26
                            Yes I think it is possible to configure BitDefender, but at the moment we are traveling and don't really want to play around with the configurations. Too much need for MRA at the moment.
                            We will do without BitDefender.
                              @Patrick-33, sure, keep it for another time πŸ˜‰ Enjoy!
                              Patrick 33
                              Patrick 33
                              • BΓ©ta to no-bΓ©ta
                                Cleo
                                Cleo
