  4. unable to calculate route
27 Posts 3 Posters 4.6k Views 2 Watching
  • Patrick 33undefined Patrick 33
    @Corjan-Meijerink Thanks for your help.
    No, no VPN, The tablet is connected to a Netgear router or to the phone's wifi.
    The app works on the phone.
    @Patrick-33 thanks for the reply!
    Maybe open the offline maps and see if there is an update available? πŸ™‚
    Just thinking along. Otherwise a clean install could be good idea.
    What Android version is your tablet on? Is that different than the version on your phone?
    Patrick 33undefined 1 Reply Last reply
      Patrick 33undefined Offline
      Patrick 33
      I already tried uninstalling and reinstalling, but I still had the problem.
      Concerning the maps, I had downloaded the offline maps before my departure, but in the offline maps menu, I have this message... see image (maybe a clue...)
      Message "unable to retrieve the latest map update information"
      La version android de la tablette est la 13 sur One UI 5.1.1
      La version android du tΓ©lΓ©phone est la14 sur One UI 6
        @Patrick-33 thanks for sharing!
        On your tablet, could you go the the account page, scroll down to the version number, long press this and share the displayed file with me?
        You can email it to corjan@myrouteapp.com πŸ™‚
          Patrick 33
          File sent
          I tried a new reinstallation just before generating the info file
          Corjan Meijerinkundefined Con Hennekensundefined 3 Replies Last reply
            File sent
            @Patrick-33 Awesome!
              File sent
              @Patrick-33 said in unable to calculate route:
              I think you need to regenerate the error first, else it will not be in the logfile after a re-install.
                File sent
                @Patrick-33 due to the clean install, the logs are not containing all the information πŸ˜‰
                Could you at least go to the offline maps section (where you saw the error) - then attempt to start a route again - then share the logs with me again? πŸ˜ƒ
                Patrick 33undefined 2 Replies Last reply
                  Patrick 33
                  @Corjan-Meijerink ok
                    Patrick 33
                    @Corjan-Meijerink File returned after error
                      @Patrick-33 did you actively deny the requested location permissions or were they never prompted?
                      Please check the location permissions of the app and allow them πŸ™‚
                      Then report back to see if the issue is resolved. I see a lot of error messages stating that the location could not be retrieved.
                        Patrick 33
                        The authorization was set to "only allow if the app is used". I put "always allow"
                        I restarted the app, but still the same message.
                        I send a new log file
                          @Patrick-33 now it's interesting πŸ™‚
                          Thanks for the quick cooperation.
                          I unfortunately don't see an obvious issue in the logs 😞
                          Will research this a bit more later on.
                          Patrick 33undefined 4 Replies Last reply
                            Patrick 33
                            @Corjan-Meijerink Thank you for your help
                              Patrick 33
                              There is also the problem that I cannot download the maps offline. If it helps...
                                Patrick 33
                                If it helps, in the "Download" and "Downloads" menus I don't have any files while on the phone, they are present.
                                I feel like I'm always offline on the tablet...
                                  Patrick 33
                                  @Corjan-Meijerink Good morning, For your information, I just reset the tablet settings and everything works again on the myroute application.
                                  Con Hennekensundefined Corjan Meijerinkundefined 2 Replies Last reply
                                    @Patrick-33, thanks for reporting back. Did you have any security, anti-virus or, privacy apps installed previously by any chance?
                                      @Patrick-33 great! πŸ™‚
                                        Patrick 33
                                        @Con-Hennekens said in unable to calculate route:
                                        Yes, it has BitDefender on it.
                                          @Patrick-33, I think it will be mighty interesting if you reinstalled Bitdefender after resetting your tablet, and if your testing was done prior of after that. Bitdefender probably has some code that could intervene with access to the HERE servers. For DuckDuckGo this has already been proven less or more...
                                          Patrick 33undefined
                                          Patrick 33
                                          • using GPS coordinates for planning not always correct
                                          • Audio cuttet via Bluetooth
                                            Haugundefined
                                            Haug
                                            1.8k
                                          • I don't need AA to run the app on a phone, right?
                                          • MENU OBSTRUCTING THE MAP
                                          • CarPlay and app not showing route
                                          • Imported GPX file Waypoint Names
                                          • Bijna feilloos werken met MRA
                                            9.6k
                                          • (afwijkende) pauze tijd wordt niet meegenomen in de planner
                                            CD130undefined
