  4. Karte nicht sichtbar
29 Posts 11 Posters 412 Views 5 Watching
    @Marschel After 7 years, I'd consider the phone to have served you well! 🙂
    All jokes aside, I am still researching the issue to see if we can fix the issue. It seems to have a higher chance of occurring on older devices but is not strictly limited to them 😞
    @Corjan-Meijerink thank you for looking into the issue. I use my old S7 Android 8 phone as a backup to my S20 Android 13. Cheers!
    • Axel Marschel
      Axel Marschel
      Axel Marschel
      Hello Corjan
      Now I have a new cell phone, again a Motorola, the g84 5G model with Android 13.
      The cards are now visible again😎
      Now the maps are visible again and I was able to test the navigation for the first time.
      In short, I'm thrilled and will continue testing.
        @RetiredWingMan as indicated by the App / Play store. If you cannot download the app, your phone is not supported.
        However, besides the specific Android version or minimum requirements there are some other demands such as graphic rendering engines (for the map). Sometimes our dependencies are updated and things break for very old devices 🙂
        @Marschel that is why the Play store indicates it can be downloaded but after downloading, a specific component shows issues. Another phone with Android 6 might work just fine.
        However, we know the issue is not strictly related to (old) Android versions. I am therefore researching the issue and hope to come up with a solution.
        Reinhard Punz
        Reinhard Punz
        Reinhard Punz
        @Corjan-Meijerink ja, das wäre schön. Mein Blackview BV9100 ist jetzt leider auch betroffen. Vor dem 15. März 2024 hat alles normal funktioniert. Jetzt das Phänomen mit den nicht sichtbaren Karte. Android 9. Ich hoffe auf eine Lösung und, dass ich mir deshalb kein neues Handy kaufen muss.
        Christian S. 1 Reply Last reply
        • Reinhard Punz Reinhard Punz
          Christian S.
          Christian S.
          Christian S.
          Hallo,
          bei mir das gleiche bei beiden Telefonen die ich rein als Navi nutze, beide Android 9.
          Schöne Überraschung zu Saisonbeginn.
          Kann das gefixt werden oder sind wir wirklich gezwungen, nun neue Telefone zu kaufen?
          • Christian S. Christian S.
            Hallo,
            @Christian-Schrenk we are working on some improvements regarding backwards compatibility. Expecting a beta version this week!
            Christian S. Reinhard Punz Eric Minschart RetiredWingMan Ronni 5 Replies Last reply
              Christian S.
              Christian S.
              Christian S.
              Hello Corjan,
              thanks for the info. If there is a solution please let me know.
                Reinhard Punz
                Reinhard Punz
                Reinhard Punz
                @Corjan-Meijerink Ich habe das Update auf meinem BV9100 installiert - leider ohne Erfolg. Auch Deinstallation und neu installieren hat nicht geholfen. Cache löschen ebenfalls nicht.
                  Eric Minschart
                  Eric Minschart
                  Eric Minschart
                  Same problem here. Galaxy active tab 2, Android 9. Fully equipped on my bike with Brodit holder, Carpe Iter controller. Completely useless at the moment. Hope there wil come a solution soon. Is there a possibility to install an older version?
                  Br, Eric
                    @Corjan-Meijerink my Samsung S7 Android 8 does not show the maps.
                      Update for Android is available! This solves the issue that older versions were not loading maps 🙂
                      Christian S. Reinhard Punz Bouke Ent Ronni 4 Replies Last reply
                        Christian S.
                        Christian S.
                        Christian S.
                        you are the best! works again on my both devices with Android 9.
                        Thank you so much for quickly fixing the problem.👍
                          Ronni
                          Ronni
                          Ronni
                          @Corjan-Meijerink YES YES YES My old Samsung S8 with Android 9 and One UI Version 1.0 is running Again.
                          Thanks a lot, Corjan.
                          Greetings
                          Ronni
                          Samsung Galaxy A56 5G
                          Android 16
                          One UI Vers. 8.0
                          Carpuride W712D
                          Silverfox BT Cntroller H1+
                            @Christian-Schrenk @Ronni thanks for the update! 🙂
                              @Corjan-Meijerink, no, thank YOU for the update... 🤣
                                @Con-Hennekens hahahah, thanks 😉
                                  Reinhard Punz
                                  Reinhard Punz
                                  Reinhard Punz
                                  @Corjan-Meijerink Vielen Dank, auch mein BV9100 zeigt die Karten nun wieder an! 👍
                                    @Corjan-Meijerink said in Karte nicht sichtbar:
                                    what is now minimum android version ? i am using samsung active 2 and get feeling support will end soon.
                                      Ronni
                                      Ronni
                                      Ronni
                                      Yeah, Yeah, Yeah,
                                      Hey Superman, I've to inform you, that you have managed to bring my 7 year old Samsung bone
                                      Galaxy A 320
                                      on Android 8
                                      with Samsung Exp. Version 9.0
                                      and a "Sicherheits/security" Patch dated 01.11.2020
                                      back to life.
                                      He shows me the cards and navigates the routes, it takes a while, as if he can't believe what he's doing, but he does. Brilliant.
                                      You saved him from the trash can and he can now let the wind blow around his nose for a little while on the handlebars.
                                      Again again again (No, not Quo)
                                      Thanks for your outstanding job.
                                      Greetings
                                      Ronni
                                      Android 16
                                      One UI Vers. 8.0
                                      Carpuride W712D
                                      Reinhard Punz
                                      Reinhard Punz
                                      Axel Marschel
                                      Axel Marschel
                                      Christian S.
                                      Christian S.
                                      Ronni
                                      Ronni
                                      Eric Minschart
                                      Eric Minschart
                                        Michael 2v
                                        Michael 2v
                                      • Hide warnings on the map
                                      • Map Layers
                                        Martin White
                                        Martin White
                                      • Bollard trouble
