  4. Karte nicht sichtbar
29 Posts 11 Posters 412 Views 5 Watching
  • Axel Marschel
    Axel Marschel
    Axel Marschel
    Hallo Jörgen,
    danke für den Tipp.
    Ja die App ist auf Android 9 installiert.
    Habe Speicher, Cache und Programm gelöscht und wieder neu installiert. Leider ohne Erfolg.
    Es werden immer noch keine Karten angezeigt.
    • Axel Marschel Axel Marschel
      Hallo Jörgen,
      danke für den Tipp.
      @Marschel Android 9 is not supported anymore since 2 years ago. Can I ask what phone you are using?
      • Axel Marschel
        Axel Marschel
        Axel Marschel
        Hello Corian,
        I have a Motorola, moto g6 plus. Until the last two updates everything worked perfectly.
          Hello Corian,
          @Marschel Are you able to use another Android phone and confirm it works for you there? Can you update your phone to a newer Android version?
            @Corjan-Meijerink this subject has come up before without a resolution as far as I have seen. Is there an official statement somewhere that shows what is or is not supported?
            • Axel Marschel
              Axel Marschel
              Axel Marschel
              Hello Corjan,
              I now tested the app again on another cell phone with Android 12 and the maps were visible and everything worked.
              But why is Android version 6 or higher specified as the required operating system for this app in the Google Play Store and not a higher version?
                @RetiredWingMan as indicated by the App / Play store. If you cannot download the app, your phone is not supported.
                However, besides the specific Android version or minimum requirements there are some other demands such as graphic rendering engines (for the map). Sometimes our dependencies are updated and things break for very old devices 🙂
                @Marschel that is why the Play store indicates it can be downloaded but after downloading, a specific component shows issues. Another phone with Android 6 might work just fine.
                However, we know the issue is not strictly related to (old) Android versions. I am therefore researching the issue and hope to come up with a solution.
                Reinhard Punz 1 Reply Last reply
                • Axel Marschel
                  Axel Marschel
                  Axel Marschel
                  Hello Corjan,
                  Thanks for your quick answers.
                  Then I'm probably very lucky to have an old cell phone that no longer works with the Android version.😢
                  Ok, then after 7 years it's probably time for a new cell phone.😀
                    Hello Corjan,
                    @Marschel After 7 years, I'd consider the phone to have served you well! 🙂
                    All jokes aside, I am still researching the issue to see if we can fix the issue. It seems to have a higher chance of occurring on older devices but is not strictly limited to them 😞
                      @Corjan-Meijerink thank you for looking into the issue. I use my old S7 Android 8 phone as a backup to my S20 Android 13. Cheers!
                      • Axel Marschel
                        Axel Marschel
                        Axel Marschel
                        Hello Corjan
                        Now I have a new cell phone, again a Motorola, the g84 5G model with Android 13.
                        The cards are now visible again😎
                        Now the maps are visible again and I was able to test the navigation for the first time.
                        In short, I'm thrilled and will continue testing.
                          Reinhard Punz
                          Reinhard Punz
                          Reinhard Punz
                          @Corjan-Meijerink ja, das wäre schön. Mein Blackview BV9100 ist jetzt leider auch betroffen. Vor dem 15. März 2024 hat alles normal funktioniert. Jetzt das Phänomen mit den nicht sichtbaren Karte. Android 9. Ich hoffe auf eine Lösung und, dass ich mir deshalb kein neues Handy kaufen muss.
                          Christian S. 1 Reply Last reply
                          • Reinhard Punz Reinhard Punz
                            Christian S.
                            Christian S.
                            Christian S.
                            Hallo,
                            bei mir das gleiche bei beiden Telefonen die ich rein als Navi nutze, beide Android 9.
                            Schöne Überraschung zu Saisonbeginn.
                            Kann das gefixt werden oder sind wir wirklich gezwungen, nun neue Telefone zu kaufen?
                            • Christian S. Christian S.
                              Hallo,
                              @Christian-Schrenk we are working on some improvements regarding backwards compatibility. Expecting a beta version this week!
                              Christian S. Reinhard Punz Eric Minschart RetiredWingMan Ronni 5 Replies Last reply
                                Christian S.
                                Christian S.
                                Christian S.
                                Hello Corjan,
                                thanks for the info. If there is a solution please let me know.
                                  Reinhard Punz
                                  Reinhard Punz
                                  Reinhard Punz
                                  @Corjan-Meijerink Ich habe das Update auf meinem BV9100 installiert - leider ohne Erfolg. Auch Deinstallation und neu installieren hat nicht geholfen. Cache löschen ebenfalls nicht.
                                    Eric Minschart
                                    Eric Minschart
                                    Eric Minschart
                                    Same problem here. Galaxy active tab 2, Android 9. Fully equipped on my bike with Brodit holder, Carpe Iter controller. Completely useless at the moment. Hope there wil come a solution soon. Is there a possibility to install an older version?
                                    Br, Eric
                                      @Corjan-Meijerink my Samsung S7 Android 8 does not show the maps.
                                        Update for Android is available! This solves the issue that older versions were not loading maps 🙂
                                        Christian S. Reinhard Punz Bouke Ent Ronni 4 Replies Last reply
                                          Christian S.
                                          Christian S.
                                          Christian S.
                                          you are the best! works again on my both devices with Android 9.
                                          Thank you so much for quickly fixing the problem.👍
                                          Reinhard Punz
                                          Reinhard Punz
                                          Axel Marschel
                                          Axel Marschel
                                          Christian S.
                                          Christian S.
                                          Ronni
                                          Ronni
                                          Eric Minschart
                                          Eric Minschart
                                            Michael 2v
                                            Michael 2v
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                          • Bollard trouble
