  4. Karte nicht sichtbar
29 Posts 11 Posters 412 Views 5 Watching
    @Christian-Schrenk we are working on some improvements regarding backwards compatibility. Expecting a beta version this week!
    Eric Minschart
    Eric Minschart
    Eric Minschart
    Same problem here. Galaxy active tab 2, Android 9. Fully equipped on my bike with Brodit holder, Carpe Iter controller. Completely useless at the moment. Hope there wil come a solution soon. Is there a possibility to install an older version?
    Br, Eric
      @Corjan-Meijerink my Samsung S7 Android 8 does not show the maps.
        Update for Android is available! This solves the issue that older versions were not loading maps 🙂
        Christian S. Reinhard Punz Bouke Ent Ronni 4 Replies Last reply
          Christian S.
          Christian S.
          Christian S.
          you are the best! works again on my both devices with Android 9.
          Thank you so much for quickly fixing the problem.👍
            Ronni
            Ronni
            Ronni
            @Corjan-Meijerink YES YES YES My old Samsung S8 with Android 9 and One UI Version 1.0 is running Again.
            Thanks a lot, Corjan.
            Greetings
            Ronni
            Samsung Galaxy A56 5G
            Android 16
            One UI Vers. 8.0
            Carpuride W712D
            Silverfox BT Cntroller H1+
              @Christian-Schrenk @Ronni thanks for the update! 🙂
                @Corjan-Meijerink, no, thank YOU for the update... 🤣
                  @Con-Hennekens hahahah, thanks 😉
                    Reinhard Punz
                    Reinhard Punz
                    Reinhard Punz
                    @Corjan-Meijerink Vielen Dank, auch mein BV9100 zeigt die Karten nun wieder an! 👍
                      @Corjan-Meijerink said in Karte nicht sichtbar:
                      what is now minimum android version ? i am using samsung active 2 and get feeling support will end soon.
                        Ronni
                        Ronni
                        Ronni
                        Yeah, Yeah, Yeah,
                        Hey Superman, I've to inform you, that you have managed to bring my 7 year old Samsung bone
                        Galaxy A 320
                        on Android 8
                        with Samsung Exp. Version 9.0
                        and a "Sicherheits/security" Patch dated 01.11.2020
                        back to life.
                        He shows me the cards and navigates the routes, it takes a while, as if he can't believe what he's doing, but he does. Brilliant.
                        You saved him from the trash can and he can now let the wind blow around his nose for a little while on the handlebars.
                        Again again again (No, not Quo)
                        Thanks for your outstanding job.
                        Greetings
                        Ronni
                        Android 16
                        One UI Vers. 8.0
                        Carpuride W712D
                        Reinhard Punz
                        Reinhard Punz
                        Axel Marschel
                        Axel Marschel
                        Christian S.
                        Christian S.
                        Ronni
                        Ronni
                        Eric Minschart
                        Eric Minschart
                          Michael 2v
                          Michael 2v
                        • Hide warnings on the map
                        • Map Layers
                          Martin White
                          Martin White
                        • Bollard trouble
