  3. [App-Beta] Announcements
  4. New Beta! (v4.1.0) Android Auto / CarPlay revamp
87 Posts 25 Posters 919 Views 11 Watching
    @Jack-van-Tilburg after reading your findings, I tested the latest version with my Elebest as well. I can not see the same issues.
    When I press skip WP I see shortly a message "calculation".
    And when I press move map, I see the zoom +/- buttons.
    What Elebest device do you have?
    @Jörgen seems I'm missing something...where is the skip waypoint button located on the CarPlay screen?
    Jörgen 1 Reply Last reply
    • GT JWR GT JWR
      @GT-JWR
      GT JWR 1 Reply Last reply
        @Jörgen said in New Beta! (v4.1.0) Android Auto / CarPlay revamp:
        Elebest Motorrad-Navi 7 Zoll CarPlay C750
          @GT-JWR
          @Jörgen ah, ok, thanks. It just wasn't showing on your snipit above....I recall seeing it before.
            #72
            I am now sitting on my chair trying to remove it again and I indeed see this image. But so terribly short that I'm amazed as to how you can take a screenshot of it.
            But I really don't remember seeing this this afternoon.
            It is also a different image than when you perform this action in the app.
              @Lynchy67 266 should be available now for Android, that is the latest. Upgrade should go as expected without issues 🙂
              All good now thank you.
              • richtea999 richtea999
                @Lynchy67 said in New Beta! (v4.1.0) Android Auto / CarPlay revamp:
                Seems I'm late to the update party.
                I seeing 4.1.0 - 263, is that the latest for Android?
                I have no routes in my downloads but I have hundreds of routes in the planner.
                Do I have to manually put all my routes back into the downloads folder???
                Was there an issue with this update???
                Keep up lad / lass! 😀
                There was initially an issue with 4.0.8 -> 4.1.0 - a white screen.
                The (very temporary) solution to seeing the white screen was to uninstall and reinstall. That's what the extra releases were trying to resolve.
                If you didn't see a white screen and didn't uninstall/reinstall then you're OK. All setting and maps will be preserved.
                Any uninstall/reinstall means re-setting up the app and any re-downloading lost maps/offline routes.
                @richtea999
                Lad not Lass.
                • Lynchy67 Lynchy67
                  #75
                  I do not assume you always need all 100's of routes to be available offline all the time? There is an option in the settings that enables all started routes to be downloaded for offline use automatically. I have a habit of starting al routes in the app once, before I leave home, just to check them on the device itself. This way, I do not need to think about downloading them manually.
                  Dave J 0 Lynchy67 2 Replies Last reply
                    #76
                    @Con-Hennekens That is how I work. Love the feature to do this. Makes life really easy.
                    All stable so far with the latest Android and iOS versions - 4.1.0 - 266.
                    Ducati Multistrada V4 Rally
                    iPhone 18 Pro
                    CHIGEE AIO-6 LTE
                    Google Pixel 6 Pro
                      Yes, maybe you are correct in your thinking.
                      I do have a list of favourite routes in the downloads that I use often, but maybe it would be prudent to limit the list somewhat.
                      • Lynchy67 Lynchy67
                        @Lynchy67, do you not have any internet connection at the moment you start such a route? Picking a route the usual way (routes menu) works just fine, as long as you have a live connection, even though the app is in offline mode. As soon as you start a route it will be offline, and no bandwidth is being used.
                        Together with the option "download routes for offline use automatically", I seldomly need to download anything manually.
                        Lynchy67 1 Reply Last reply
                          #79
                          The issue with the downloads was due to one of the earlier updates that basically wiped out my downloaded routes in the Downloads folder.
                          I did have to manually put them all back.
                          I went out for a ride today and MRA worked wonderfully. 👍
                            @Stephen-Rowland please let me know if 266 works! Should be there for you now 🙂
                            Stephen Rowland
                            Stephen Rowland
                            Stephen Rowland
                            @Corjan-Meijerink Works very well now thanks
                              Maybe it was a fix in a previous version but i noticed something else.
                              Because i deleted everything before i updated to the new version. I needed to download the offline maps again.
                              This time downloading the maps went pretty quick.
                                @M-Schrijver it seems that downloading maps is very dependant in Internet traffic and how busy the Here servers are. Sometimes it goes very quickly and other times it feels like we're back in dialup days.😊
                                  Offcourse you're right. But in the past there were many complaints about the slow download speeds of the offline maps. This was something i noticed too. But this time is was completly different.
                                  I have also TomTom GO. This uses offline map too. But in case of TomRom GO the downloadspeed is always reliable.
                                    @M-Schrijver, When you download maps, the app checks the data it already has. This way an interrupted download does not need to redownload the whole thing again. I guess the data was still present, but the app lost its reference to it. The very quick "download" (probably faster than even possible over wifi?) indicates it merely reindexed the existing maps.
                                      I did clear all data before deleting the app. Maybe you're right.
                                      In the past even updating the maps did not go this fast.
                                        @M-Schrijver said in New Beta! (v4.1.0) Android Auto / CarPlay revamp:
                                        In that case of course your download was completely new 😉 Clearing the data withing the Android system app settings does not leave a trace of the maps.
                                        • Dikke Wim
                                          Dikke Wim
                                          Dikke Wim
                                          #87
                                          With the latest beta update (version 4.1.0. (272) I encounter several problems:
                                          • in Apple CarPlay the program does not update the card
                                          • in Apple Carplay the program does not update the navigation instructions
                                          • in Apple CarPlay the map is not alway shown
                                          • after using Apple CarPlay, the MRA app crashes
                                          Hopefully this is fixed in the next beta update.
                                          Keep up the good work!
                                          • 4
                                          • 5
                                          Edwin_M
                                          Edwin_M
                                          Vince Hyde
                                          Vince Hyde
                                          Arno 0
                                          Arno 0
                                          Gary Clark
                                          Gary Clark
                                          Stephen Rowland
                                          Stephen Rowland
                                          Andre Muller
                                          Andre Muller
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
