  3. Circular route, changing starting point
3 Posts 2 Posters 810 Views 2 Watching
  • Tony 13 Offline
    Tony 13 Offline
    Tony 13
    I have just picked up a circular route from the library which has 73 waypoints.
    Rather than starting at point 1 (why would I?) I would like to start near point 50.
    Is there a quick way to re-order all the waypoints?
    In the past I manually moved each one - which worked in the end
    Tony
    • Tony 13 Tony 13
      Tony
      Jack van Tilburg Offline
      Jack van Tilburg
      @Tony-13
      Make a copy of the route to work with.
      Select the waypoint you want to start at and open the properties. Click on the flag to make this point your starting point. Correct any other waypoints as necessary.
      • Nick Carthew Nick Carthew moved this topic from [Web] Suggestions and Discussion on
      • Tony 13 Offline
        Tony 13 Offline
        Tony 13
        Easy! Thank you. I wondered what that icon did.
        Tony 13
        Tony 13
        Jack van Tilburg
        Jack van Tilburg
        • Welke instelling
          1.1k
          Thomas Schäfer
          Thomas Schäfer
        • opslaan naar plantomtom
          chris 18
          chris 18
        • Seizoen sluitingen wegen
          PAT62
          PAT62
        • App loopt vast
        • Rejoining routes
          Sytze van der Laan
          Sytze van der Laan
