  4. No vocal instructions
16 Posts 4 Posters 3.9k Views
    @Montorsi-Paolo-0 if you go to the Options / audio, is voice instructions enabled? Do you hear anything if you change the volume level?
    Montorsi Paolo 0
    Montorsi Paolo 0
    Montorsi Paolo 0
    @Doug-Robinson said in No vocal instructions:
    Volume: max
    TTS engine: the same of your image but i tried talso the COM.SAMSUNG.SMT
    Voice: tried a couple of italian and english also
    Voice prompt: ON
    Number of voice prompt: 4 (tried 2 and 3)
    Waypoint notifications: All, tried also Via
    Speed warning: All
    I can't ear nothing, but if I press the test play button on the TTS engine menu It works perfectly, also with the samsung TTS engine.
    • richtea999 richtea999
      @Montorsi-Paolo-0 said in No vocal instructions:
      In the App i was playing a Route with several waypoint and shape point.
      'Playing' (as in preview and watch the route being traversed) or actually riding / driving the route?
      (I think you mean riding / driving, but just checking)
      Montorsi Paolo 0
      Montorsi Paolo 0
      Montorsi Paolo 0
      @richtea999 said in No vocal instructions:
      Nothing at all.
      Just drived an A to B route, no sound at all.
      • Montorsi Paolo 0 Montorsi Paolo 0
        Volume: max
        Voice prompt: ON
        Speed warning: All
        @Montorsi-Paolo-0, If you toggle between the max and mid volume setting, do you hear a voice telling that voice prompts are enabled? If not, press the volume-up hardware button on your phone a few times immediately after toggling. Remember that you need to toggle between mid and max, because pressing max, while max is already on, it will not generate a voice prompt. Maybe that's something that can be changed, @Corjan-Meijerink ? πŸ˜‰
        Montorsi Paolo 0 1 Reply Last reply
          Montorsi Paolo 0
          Montorsi Paolo 0
          Montorsi Paolo 0
          @Con-Hennekens said in No vocal instructions:
          Yes I can hear it.
            Yes I can hear it.
            Montorsi Paolo 0
            Montorsi Paolo 0
            Montorsi Paolo 0
            @Montorsi-Paolo-0
            Just to know.
            if I start a route on Google Maps I immediately hear the voice commands.
            Is it the same on MRA Navigation App?
            Thanks
            Montorsi Paolo 0 MotoCon 2 Replies Last reply
              @Montorsi-Paolo-0
              Just to know.
              Thanks
              Montorsi Paolo 0
              Montorsi Paolo 0
              Montorsi Paolo 0
              @Montorsi-Paolo-0
              After uninstall and re-install the vocals commands works
                @Montorsi-Paolo-0
                Just to know.
                Thanks
                No it is not the same. MRA only gives voice instructions when they are relevant for your position. So, sitting at home on the couch starting a route MRA will usually not say anything. If this is how you were testing, I assume it was working fine all along πŸ˜‰
                  Montorsi Paolo 0
                  Montorsi Paolo 0
                  Montorsi Paolo 0
                  No, the first try was on the road, I drove a route with my car, with via Point and shaping point, second was again in the road with an A to B route. No talking.
                  After reinstall seems works well, I tried only an A to B route. But I imagine now it will work also for more complex route.
                    Montorsi Paolo 0
                    Montorsi Paolo 0
                    Montorsi Paolo 0
                    @Montorsi-Paolo-0
                    Funny.
                    Despite I can ear that the vocal commands are enabled toggling on the volume level, during the navigation on the road the Vocal command does't work.
                    Again.
                      @Montorsi-Paolo-0
                      Funny.
                      Again.
                      @Montorsi-Paolo-0, What's your setup? Are you connected to your bike/car by Bluetooth connection. Do you hear the volume toggle when connected through this BT connection? If you disable the BT connection, do you hear the voice then?
                        Montorsi Paolo 0
                        Montorsi Paolo 0
                        Montorsi Paolo 0
                        Thanks for your replay.
                        The first tries I have made I was in my car.
                        Then I have installed againg the App, tried and It was working but I was in my wife's car.
                        Then I tried again in my car and again was not working.
                        When I read your replay, I immediately understood why sometimes it works and sometimes it doesn't.
                        My SP i paired with my car and not with my wife's car, obviously.
                        So I switched off the bluetooth connection, on the SP, with my car and vocal instructions are working now.
                        Now I have to investigate why I can't ear the instruction on my car, even if i will use the App on my motorbike
                        Thanks
                        Montorsi Paolo 0
                        Montorsi Paolo 0
                          MartinW
                          MartinW
                        • BΓ©ta to no-bΓ©ta
                          Cleo
                          Cleo
                          Rob Draaisma 0
                          Rob Draaisma 0
