  4. No vocal instructions
16 Posts 4 Posters 2.6k Views
  • Montorsi Paolo 0undefined Offline
    Montorsi Paolo 0
    wrote on last edited by Montorsi Paolo 0
    Hi
    Yesterday first try with the navigation app on Android 13.
    I can't have any vocal instruction.
    At the first try, I had the following configuration on the App:
    TTS Engine = COM.SAMSUNG.SMT
    Voice = ITA , VOICE 1
    Volume = MAX
    Number of vocal Instruction = 4
    Waypoint notification = All
    Speed warning Sound = All
    On the route setting, Vocal message and sound warning are on.
    (the parameter name are translated by myself from Italian to English, maybe they could be named differently in the English App version)
    Smartphone volume = max
    NO sound come from the smartphone but if I press the test play button on the: TTS-> COM.SAMSUNG.SMT I can hear clearly the test vocal command
    Tried to change the TTS to COM.GOOGLE.ANDROID.TTS and select the Italian voice 1.
    Same story. I cant ear any vocal message but if I press the test play button on the COM.GOOGLE.ANDROID.TTS I can hear clearly the test vocal command
    In the App i was playing a Route with several waypoint and shape point.
    Any suggestion?
    Thanks
    Paolo
    Con Hennekensundefined richtea999undefined 2 Replies Last reply
    • Montorsi Paolo 0undefined Montorsi Paolo 0
      Hi
      Volume = MAX
      Any suggestion?
      Thanks
      Paolo
      @Montorsi-Paolo-0, I don't know if this could be your issue, but it is know that voice-instructions are silenced when your waypoints are close to a turn. If that is not the case, maybe a restart of your phone could fix it.
      Montorsi Paolo 0undefined 1 Reply Last reply
        Montorsi Paolo 0
        The App doesn't speak at all, non only close or in waypoints proximity.
        I had waypoints also away from turning point.
        Restart already done, several time (I am an old computer programmer, ;-))
        Google map, BMW Connected App, Osmand, their vocal command has no problem in my smartphone.
        This just to say that the problem seems to be in te MRA Navigation App rather then in the outside of it.
          @Montorsi-Paolo-0 if you go to the Options / audio, is voice instructions enabled? Do you hear anything if you change the volume level?
            Hi
            Volume = MAX
            Any suggestion?
            Thanks
            Paolo
            richtea999undefined Offline
            @Montorsi-Paolo-0 said in No vocal instructions:
            'Playing' (as in preview and watch the route being traversed) or actually riding / driving the route?
            (I think you mean riding / driving, but just checking)
              Montorsi Paolo 0
              @Doug-Robinson said in No vocal instructions:
              Volume: max
              TTS engine: the same of your image but i tried talso the COM.SAMSUNG.SMT
              Voice: tried a couple of italian and english also
              Voice prompt: ON
              Number of voice prompt: 4 (tried 2 and 3)
              Waypoint notifications: All, tried also Via
              Speed warning: All
              I can't ear nothing, but if I press the test play button on the TTS engine menu It works perfectly, also with the samsung TTS engine.
                Montorsi Paolo 0
                @richtea999 said in No vocal instructions:
                Nothing at all.
                Just drived an A to B route, no sound at all.
                  Volume: max
                  Voice prompt: ON
                  Speed warning: All
                  @Montorsi-Paolo-0, If you toggle between the max and mid volume setting, do you hear a voice telling that voice prompts are enabled? If not, press the volume-up hardware button on your phone a few times immediately after toggling. Remember that you need to toggle between mid and max, because pressing max, while max is already on, it will not generate a voice prompt. Maybe that's something that can be changed, @Corjan-Meijerink ? 😉
                    Montorsi Paolo 0
                    @Con-Hennekens said in No vocal instructions:
                    Yes I can hear it.
                      Yes I can hear it.
                      Montorsi Paolo 0
                      @Montorsi-Paolo-0
                      Just to know.
                      if I start a route on Google Maps I immediately hear the voice commands.
                      Is it the same on MRA Navigation App?
                      Thanks
                      Montorsi Paolo 0undefined Con Hennekensundefined 2 Replies Last reply
                        @Montorsi-Paolo-0
                        Just to know.
                        Thanks
                        Montorsi Paolo 0
                        @Montorsi-Paolo-0
                        After uninstall and re-install the vocals commands works
                          @Montorsi-Paolo-0
                          Just to know.
                          Thanks
                          No it is not the same. MRA only gives voice instructions when they are relevant for your position. So, sitting at home on the couch starting a route MRA will usually not say anything. If this is how you were testing, I assume it was working fine all along 😉
                            Montorsi Paolo 0
                            No, the first try was on the road, I drove a route with my car, with via Point and shaping point, second was again in the road with an A to B route. No talking.
                            After reinstall seems works well, I tried only an A to B route. But I imagine now it will work also for more complex route.
                              Montorsi Paolo 0
                              @Montorsi-Paolo-0
                              Funny.
                              Despite I can ear that the vocal commands are enabled toggling on the volume level, during the navigation on the road the Vocal command does't work.
                              Again.
                                @Montorsi-Paolo-0
                                Funny.
                                Again.
                                @Montorsi-Paolo-0, What's your setup? Are you connected to your bike/car by Bluetooth connection. Do you hear the volume toggle when connected through this BT connection? If you disable the BT connection, do you hear the voice then?
                                  Montorsi Paolo 0
                                  Thanks for your replay.
                                  The first tries I have made I was in my car.
                                  Then I have installed againg the App, tried and It was working but I was in my wife's car.
                                  Then I tried again in my car and again was not working.
                                  When I read your replay, I immediately understood why sometimes it works and sometimes it doesn't.
                                  My SP i paired with my car and not with my wife's car, obviously.
                                  So I switched off the bluetooth connection, on the SP, with my car and vocal instructions are working now.
                                  Now I have to investigate why I can't ear the instruction on my car, even if i will use the App on my motorbike
                                  Thanks
                                  richtea999undefined
                                  Montorsi Paolo 0
                                  • Imported POI files visible in App
                                    Keith Hofgartnerundefined
                                    Keith Hofgartner
                                  • How to exclude short time road blocks during navigation
                                    Axel Härtlundefined
                                    Axel Härtl
                                  • The route is planned to go the wrong way round the roundabout
                                  • Geen routeberekening
                                  • Onbegrijpelijke omweg
                                    Lex.Kloet.RXundefined
                                    Lex.Kloet.RX
                                  • Apple Carplay. MRA Navigation stops after re-calculating
                                  • Truck / Camper Dimensions
                                    Herman Veldhuizenundefined
                                    Steve 2vundefined
                                    Steve 2v
