  4. Stromverbrauch viel zu hoch!
23 Posts 8 Posters 11.2k Views 3 Watching
  • Drabslab Drabslab
    @Corjan-Meijerink grom, i don't like to read "lack of progress".
    If this is a HERE problem and they are not working (fast enough) on a solution, how realistic would it be to navigate using OSM?
    @Drabslab, that would be a complete rewrite of the app. Maybe even sperately for IOS and Android. But I don't think it could be as feature rich as the current platform.
    Drabslab 1 Reply Last reply
      @Con-Hennekens said in Stromverbrauch viel zu hoch!:
      Can't believe that unless the architecture of the app is really bad, and I do not believe that either ? 🙂
      • Drabslab Drabslab
        Well OSM doesn’t have a navigation tool (SDK) for our development platform (Flutter). So yeah, pretty impossible.
        As the battery usage is caused by the map rendering, we are looking into workarounds for that, but pretty complex too 😉
        I get another answer from HERE next week so I’ll just keep nagging them 🙂
        richtea999 1 Reply Last reply
        • Dave J 0 Dave J 0 referenced this topic on
          @Corjan-Meijerink said in Stromverbrauch viel zu hoch!:
          Do HERE state the difference between their pure Android/iOS API battery usage and their Flutter version? If they're all bad, no amount of tinkering will bring the Flutter version round.
          Another angle to investigate is whether their own app has the same battery problems:
          • https://play.google.com/store/apps/details?id=com.here.app.maps
          An hour or two's ride will confirm it's their problem, not just MRA's implementation.
          And finally - a long shot, but if things don't improve then a possible fallback:
          • https://pub.dev/packages/flutter_mapbox_navigation
          I've no doubt there are holes compared to HERE functionality (no offline maps/routing?), but then again it might render with lower battery usage.
          If nothing else it may act as a gentle lever/reminder for HERE to pull their finger out if you mention you're investigating alternatives.
          • richtea999 richtea999
            @richtea999 thanks for thinking along 😉
            Their app (especially the Flutter reference app) display similar high battery usage.
            • richtea999
              @Corjan-Meijerink Oh, that's both good and bad:
              Your code is good, Corjan!
              And theirs is just a little bit sh*t.
              They need a Flutter expert. And it's not me.
              If they added it to pub.dev and made the API/interface open source on GitHub, they'd get some free feedback, possibly some fixes, and some publicity/sales, since it's the backend that makes them money.
              Good luck discussing that with them!
              • hawebo
                hawebo
                hawebo
                Habe heute eine ca. 50 km Vergleichsfahrt gemacht, um die Akkunutzung zu testen. Auf dem Hinweg habe ich mit HERE WeGo navigiert, auf dem Rückweg mit MyRouteApp.
                Die Akkunutzung unterscheidet sich gerade einmal um 3% zu Lasten vom MRA, siehe Screenshots.
                Anzumerken ist noch, das HERE WeGo während der Navigation 8 Mal abgestürtzt ist und MRA 1 Mal in den Offlinmodus gewechselt ist.
                Gruß hawebo
                Navigation: Gigaset GX4 PRO, Android 14
                BackUp: Google Pixel 7a, Android 17
                • hawebo hawebo
                  Gruß hawebo
                  @hawebo exactly! Thanks for confirming this 🙂
                  The root cause really is originating from the HERE map rendering. Quite frustrating.
                  Drabslab hawebo Dave J 0 3 Replies Last reply
                    Considering that this long standign issue is hindering the further development of MRA, and is annoying your user base, maybe you start negotiating a price reduction from HERE?
                    Usually, tyhat is a language they understand
                      hawebo
                      hawebo
                      hawebo
                      Könnte MRA in dem Fall nicht erwägen, auf die Kartendarstellung von TomTom zu wechseln?
                      Damit wäre die Planung von kurven- bzw höhenreichen Routen einfach und keine anschließende Übertragung/Speicherung nach HERE mehr erforderlich.
                        @Corjan-Meijerink Just for your info, the change in the last SDK appears to have made the power consumption problem very much worse for me with no change in my installation setup and/or use. With the previous SDK, my Google 6 Pro would slowly charge up to 100% and that is why the last change in version to 4.0.6 232 (with SDK change) appears to have drastically changed the power consumption for the worse with me losing 80% of my battery over 4 hours whilst charging yesterday. Other nav apps allow the battery to charge on the same setup. Thought this might help with feedback to HERE and to maybe help you.
                        Ducati Multistrada V4 Rally
                        iPhone 18 Pro
                        CHIGEE AIO-6 LTE
                        Google Pixel 6 Pro
                        • hawebo hawebo
                          @hawebo said in Stromverbrauch viel zu hoch!:
                          Scroll up to the awnser of Corjan 👆
                          HERE is the only map provider that supports the Flutter design platform. Since this app is being developed on that platform, it is not possible to choose another map provider for the navigation engine.
                            @Rob-Verhoeff i understand. I also understand that i cannot use Next until this problem is solved.
                            hawebo
                            hawebo
                              MartinW
                              MartinW
                            • Béta to no-béta
                              Cleo
                              Cleo
                              Rob Draaisma 0
                              Rob Draaisma 0
