  4. Query when setting waypoint
22 Posts 8 Posters 8.4k Views 2 Watching
    @Jure-Sirena-0, Why? I think you are using the wrong format then.
    Jure Sirena 0undefined Offline
    Jure Sirena 0
    @Con-Hennekens not myroute issue, its garmin issue, believe me we tried 1.2 with shaping points, 1.1 with waypoints….the only way it always imports gpx correctly (XT2) and routes correctly is to use 1.1 and waypoints only
    Hans van de Ven MR.MRAundefined Con Hennekensundefined 2 Replies Last reply
    • Jure Sirena 0undefined Jure Sirena 0
      @Jure-Sirena-0
      gpx 1.2 is a route-track with via points, the route-track is converted into a route by the XT(2), so you have a route as planned with only the via points in it.
      You must have included some via points in your route outside the start and end points. Transferring with the connector or with the Garmanin Drive app works well. The Garmin Tread app cannot handle routes and produces a discrepancy. The Track is processed well by the Tread App and Garmin Explore.
      Jure Sirena 0undefined 1 Reply Last reply
        @Jure-Sirena-0, so, if I understand correctly:
        • if you want to drive a route, use GPX1.1
        • if you want to drive a track, use GPX1.1
        • if you want to drive a track that includes the viapoints, use GPX 1.2
        So instead of mass-enabling viapoints, just use GPX1.1 instead.
        Is that correct @Hans-van-de-Ven-MRA-Master ?
        Jure Sirena 0undefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
          Jure Sirena 0
          @Con-Hennekens i never drive a track, just route. Its why we use 1.1 and waypoints.
          If we use 1.2 it happens that some waypoints or shaping points are not imported at all (its xT2 tread app issue)
          So by being able to choose waypoint / shaping point on the fly it helps
            @Jure-Sirena-0
            Jure Sirena 0
            As mentioned in previous post, it happens some gets lost when using shapping and waypoints. There is even a case that i had only start and finish and nothing in between.
            Its why its safer to use 1.1 and waypoints only.
            When preparing several XTs and XT2 for group touristic rides under same gpx / same process you see wierd things.
            Again we import over tread app - there is share function for all devices. To ise exporter device per device or similar for 20-30 devices its a bit too much
            Hans van de Ven MR.MRAundefined Lynchy67undefined 2 Replies Last reply
              @Con-Hennekens said in Query when setting waypoint:
              gpx 1.2 is a route-track with viapoints, the route-track will be converted to a route in your XT(2)
                @Jure-Sirena-0
                If you only have a start and end point, you have the track.
                If you compose the route properly, a GPX 1.2 also works perfectly, I don't use anything else.
                If you use the connector, a GPX 1.2 will also work well in an XT2
                If you use the Tread app, it is best to use the GPX 1.1 and its track, because the Tread app and the Garmin Explore website cannot yet process route files properly. A track is processed properly.
                  Lynchy67undefined Offline
                  @Jure-Sirena-0
                  I also have the XT2.
                  You can do it using the Connector or Garmin Express with GPX 1.2
                  Happy to provide a step by step if you need it?
                  Green Flag is the Start, Checkered Flag is the Finish, Orange Flags are the Intermediate Via Points that @Hans-van-de-Ven-MRA-Master mentions in his posts.
                  Screenshot below shows the Track and the 6 Via Points in the XT2.
                  Corjan Meijerinkundefined Jure Sirena 0undefined Hans van de Ven MR.MRAundefined 3 Replies Last reply
                  • Lynchy67undefined Lynchy67
                    @Jure-Sirena-0
                    @Lynchy67 I wanna drive that loop on my Tiger now! 🙂
                      I reckon it would love it, 90% country lanes, you know, the ones with the grass/moss in the middle.
                      Whilst it wasn't raining today there must have been a lot of rain overnight, the Tiger1200 Rally Pro got a bit dirty, as it should.
                      I ran the route with MyRoute-App not the XT2 which is my back up.
                      Haven't had to use the XT2 once yet. 👍
                        @Jure-Sirena-0
                        Jure Sirena 0
                        @Lynchy67 guys thanks for help but we cant use connector in moto tour company….10-20 devices sometimes need to be managed on the fly and then all synced asap. i know how to use connector.
                        As said all is well I adapt some things and use only 1.1
                        But its all about original post not about files and connectors - it would really help to have this option.
                          @Jure-Sirena-0
                          @Lynchy67
                          And here the gpx 1.2 route, Track and via points
                          Black = Track
                            @Lynchy67
                            Black = Track
                            #21
                            As the XT2 is my back up (I use MyRoute-App on Android as my main device with the full Quadlock set up) I never really bothered with the Track before.
                            I guess I should add the Track for those unforeseen blockages that require me to go off route and then re-join further ahead.
                            Thanks for the reminder. 👍
                              @Lynchy67
                              The XT2 is my BackUp too.
                              Richard 18undefined
                              Richard 18
                              Lynchy67undefined
                              Jure Sirena 0
                                1.2k
                              • Ebbe from Sweden.
                              • Exporting to Garmin Zumo XT2.
                              • Radar
                                Marko 3undefined
                                Marko 3
                              • Android 9: no tracklogs
                              • GPS positie freeze
                                Aiello antoninoundefined
                                1.1k
                              • Zoom Out in north Up view
                              • Full View (hole Route)
