  4. Saving to Tom Tom mydrive
14 Posts 6 Posters 2.9k Views 2 Watching
  • Tony 13undefined Offline
    Tony 13
    Saving a route to Tom Tom MyDrive is accessed from the "save as" menu when a route is displayed.
    Quite often I am saving 7-14 routes at time and it gets a bit labourious.
    Couple of suggestions:
    Include your Tom Tom account email address in Profile details so this box just populates.
    Add access from the 3 dot menu in your list of routes. There is a "save as" function here but it does not include saving to MyDrive
    regards
    Tony
    • Tony 13undefined Tony 13
      regards
      Tony
      Drabslabundefined Offline
      @Tony-13
      Which TomTom device are you using?
      Two weeks ago I downloaded 13 routes from the Myroute planner to a TomTom rider 400 in less than 2 minutes using a simple USB cable.
      Hence, I am a bit puzzled why you need TomTOm mydrive?
      Dave J 0undefined Mike Simpsonundefined 2 Replies Last reply
      • Drabslabundefined Drabslab
        @Tony-13
        Dave J 0undefined Offline
        @Drabslab if you are using the mobile apps then you need to load routes into My drive and enable sync to see these routes under 'My Routes'. I would support @Tony-13 having the MyDrive login details stored for when I need to load to My drive. I use the TomTom mobile app as a back up to Next.
        Ducati Multistrada V4 Rally
        iPhone 15 Pro
        CHIGEE AIO-6 LTE
          @Tony-13
          Mike Simpsonundefined Offline
          Mike Simpson
          @Drabslab I find saving to TomTom Mydrive useful as it shows if my planned route is affected by road closures or is going to be delayed due to roadworks.
            Tony 13
            Sorry been away
            I am using a Rider 550. This does not allow a direct conncection like the Rider 400. You have to go through mydrive
              Sorry been away
              @Tony-13 said in Saving to Tom Tom mydrive:
              Sorry been away
              You can have a direct connection to your PC via the supplied TomTom USB cable.
              First of all save all of the routes that you want to transfer to your 550 to your PC, save them using the top option GPX 1.1 (Route, track, POI)
              Connect your 550 to your PC with the supplied cable, TomToms can be fussy about the cable that is used.
              When your TomTom fires up, touch the Import routes option on the TomTom screen. This makes your TT visible in Windows Explorer as a separate drive.
              Now find your routes (highlight them all) and drag and drop them into your TomTom.
              There is no need to use TT MyDrive.
                Tony 13
                I really did not expect that import over a USB cable to work, thought i had tried before but probably gave up too soon. Yes I had to go and find the original cable, and it had to be plugged in directly to my laptop (not a USB-C multiport)
                It has given me two versions of each file, one suffixed track and the other not, but both identical tracks when i open them
                  @Tony-13 If you want a route with visible route points, save the route as an .itn file and upload it to your TT the same way.
                    Stanisławundefined Offline
                    @Nick-Carthew IMHO you can simply use connector app and export function, it works correctly via USB to TT550, I don't have to save routes on the disk first.
                    Staszek
                      @Stanisław said in Saving to Tom Tom mydrive:
                      Correct, but the original question for this topic was about loading several routes and saving time, with the connector you can only load one route at a time.
                        @Nick-Carthew I see, anyway saving as GPX is also possible only one by one, so the same time needed, right?
                        Staszek
                          No, you can save multiple .gpx files by dragging and dropping them to your TomTom too.
                            @Nick-Carthew Dragging from your local disc, agree, but first you have to save them to the disc from MRA planner one by one. For me it is easier to export them to TT directly one by one but any way is good 🙂
                            Staszek
                              Tony 13
                              this is turning out even more useful
                              Thanks for the tip on.itn files. Thought I would never see a way point on my Tom Tom again.
                              Also that the connector app actually does work! Again I guess I stupidly never tried it using the TT supplied USB cable. My techy knowledge stops at - "its digital, how can a cable make a difference"
                              Dave J 0undefined
                              Tony 13undefined
                              Tony 13
                              Stanisławundefined
                              Drabslabundefined
                              Mike Simpson
                                PieterGundefined
                                PieterG
                              • route from Amsterdam to Amalfi coast please
                                Lex.Kloet.RXundefined
                                Lex.Kloet.RX
                              • MyRoute-app wedding
                                LE DIZES Freddyundefined
                                LE DIZES Freddy
                              • 1richtingsweg staat verkeerom in de App
                              • Adding Toilets as a POI
                              • MyRouteApp eigen gemaakte Route 2x langs afgesloten weg ???
                                Marcel Versluisundefined
                                Marcel Versluis
                              • Update Afsluitingen Nederland
                                Herman Veldhuizenundefined
                                1.1k
