  4. Incorrect navigation information
24 Posts 7 Posters 188 Views 2 Watching
  • RetiredWingMan
    First, I love that waypoints have been removed from the next navigation instruction. I ran into a strange problem today. The next instruction was a turn in 14 km. The second instruction showed a turn in 7 kms! At first I thought the distance was after the next instruction.. but no. Both distances continued to count down. I think the second instruction may have been showing the distance to the next WP. When the second instruction reached zero, the app did a quick recalculate and everything was fine again. I tried to take a screen shot but it would not work with gloves on.
      @Doug-Robinson great you love it! Thanks for sharing 🙂
      RetiredWingMan 2 Replies Last reply
        @Corjan-Meijerink since I always have problems taking screen shots, I don't suppose you would consider, (on the Beta app), adding a button or something that would make taking a screen shot quick and easy? Perhaps someone knows of an Android app that would do this.
        Lynchy67 Dave J 0 2 Replies Last reply
          @Doug-Robinson
          On my Samsung S21+ a screenshot can be taken by simultaneously pressing the Unlock button and the Volume Down button.
          Marinus van Deudekom RetiredWingMan 2 Replies Last reply
          • Lynchy67 Lynchy67
            @Doug-Robinson
            @Lynchy67 or Swipe with your hand over the screen from right to left
            Lynchy67 RetiredWingMan 2 Replies Last reply
              @Marinus-van-Deudekom
              In this instance I think @Doug-Robinson is specifically looking to screenshot the Navigation Next screen so I don’t think the hand swipe will work in this instance as it will move the Next screen.
                @Doug-Robinson as well as the option suggested by @Lynchy67 you can use the app overview button if you have 3-button navigation enabled as opposed to gesture navigation.
                Then the screenshot option is available:
                As I use my Android device predominantly on the bike, button navigation is great with gloves as I have the buttons on the left in landscape.
                Ducati Multistrada V4 Rally
                iPhone 18 Pro
                CHIGEE AIO-6 LTE
                • Lynchy67 Lynchy67
                  @Doug-Robinson
                  @Lynchy67 difficult to do while riding with gloves on.
                    @Marinus-van-Deudekom does not work with gloves on.
                    • Dave J 0 Dave J 0
                      @Dave-J-0 the screen shot above looks interesting. How do you get the screenshot option on the bottom of the screen?
                      Dave J 0 Marinus van Deudekom 2 Replies Last reply
                        @Doug-Robinson select the square button (app overview). I can do this with gloves on as well. You should be able to enable 3 button option in settings. Search for button navigation.
                        iPhone 18 Pro
                        CHIGEE AIO-6 LTE
                          @Doug-Robinson
                          Example from a Swipe from my Samsung S20FE
                          • Dave J 0 Dave J 0
                            @Dave-J-0 I do have 3 button turned on . But how do you get the screenshot option to show up?
                            Dave J 0 1 Reply Last reply
                              @Doug-Robinson
                              @Marinus-van-Deudekom yes, I enabled the swipe for screenshot but it does not work with gloves on.
                                @Doug-Robinson my phone is a Google Pixel 6 Pro and there must be a difference with the screenshot option. I believe the option was reinstated with Android 12. Have a look here: https://support.google.com/assistant/answer/9402361?hl=en&co=GENIE.Platform%3DAndroid#zippy=%2Cother-android-phones
                                There is this also: https://youtu.be/l6Aj2K5MkrU
                                This is my first Android phone so still learning.
                                iPhone 18 Pro
                                CHIGEE AIO-6 LTE
                                  @Corjan-Meijerink had another occurrence of the issue with the second nav instruction. I pulled over and got a screenshot. You can see the second nav instruction is closer than the next nav. The distance is the save as the next waypoint. Once the distance had counted down to zero the app reset and everything was fine.
                                  Dave J 0 Nick Carthew 2 Replies Last reply
                                    @Doug-Robinson not sure I understand. The second turn distance is 1.1km after the first turn distance. Go 7 2km turn then 1.1km then turn. Thi is working as it is meant to from what I can see. 😄
                                    iPhone 18 Pro
                                    CHIGEE AIO-6 LTE
                                      @Doug-Robinson I agree with @Dave-J-0 Your next shaping point is in 1.1 km, your next turn is in 7.2 km and the turn after that is 1.1 km. Just a coincidence that the shaping point and second turn are the same distance.
                                      It’s all working as it should.
                                      • Dave J 0 Dave J 0
                                        @Dave-J-0 said in Incorrect navigation information:
                                        I am not so sure it works that way. I think it was established earlier on the forum that both numbers are counting down, so they are both measured from the current position. To be honest, I don't pay much attention to the second turn, I rather keep my eyes on the road more.
                                        @Nick-Carthew said in Incorrect navigation information:
                                        Yes that's a coïncidence, and not what is meant here by @Doug-Robinson I think.
                                          @Con-Hennekens said in Incorrect navigation information:
                                          The distance to the second turn is measured from after the first turn. The most sensible distance to show in my opinion.
                                          I’m hoping that when I get my new varifocal glasses next week I’ll be able to read it a little easier 🤓
                                          • Strange translation
                                            martin-phogel.de
                                            martin-phogel.de
                                            10.9k
                                          • Undo/Redo tool is hidden
                                          • Shared toggle switch
                                          • Crazy routing
