  4. Newbie needs help opening HERE map in app...
24 Posts 6 Posters 9.8k Views 2 Watching
    @Tom-Grzelinski Okay, I do find it quite interesting! However, if you create the route in OSM and then open it for navigation, you will receive a warning that the route may deviate because the navigation module only uses the Here map. In that case, I don't find it strange that something went wrong as per the notification you receive! Somewhere along the route, the app simply cannot calculate a route. Always create the route you want to navigate in the Here map, or if you export to TomTom, use the TomTom map.
    Tom Grzelinski Offline
    Tom Grzelinski
    @Rob-Verhoeff
    Hi Rob, v5 (mk5) was created in HERE map and avoids the navigation changes... I just can't open it in the app!
    Porsche 911 and VW Transporter T6.1 running CarPlay.
    iPhone 17 Pro running Waze and MRA.
    MRA Routeplanner on web via Mac
    • Tom Grzelinski Tom Grzelinski
      @Rob-Verhoeff
      Hi Rob,
      I am doing this in 14 days this September! It makes (and made) sense to me to do it all as one route so that I had the totals, but also it is all one big trip and I can see the whole route together.
      No offence either, but MRA copes perfectly well with this. The route we are talking about is my v5 route. v1-4 use OpenStreetMap and open perfectly and navigate perfectly in the App.
      I only changed v5 to HERE map to avoid the seasonal closures, but maybe that was a bad idea. Maybe I should stick with the OpenStreetMap version.
      Rob Verhoeff Offline
      @Tom-Grzelinski Some of your waypoints are also located very far from the road! Always make sure they are right on top of the route line. Otherwise, you do indeed run the risk of the navigation not being able to calculate the route because a waypoint simply cannot be found.
      Tom Grzelinski 1 Reply Last reply
        Is @Tom-Grzelinski even using the actual (paid) navigation module I wonder, or just "follow the line" navigation in the free part of the app?
        Tom Grzelinski
        @Herko-ter-Horst
        Hi Herko, I have been using MRA for about 4 months, building this trip. I purchased the Lifetime package last week, hence I am trying to get the route to work on the App... before I leave on the trip in September!!!
          @Rob-Verhoeff
          @Tom-Grzelinski Take for example waypoint 27:
          This is yours:
          I would do it like this:
            Tom Grzelinski
            @Rob-Verhoeff
            Thanks Rob. All the waypoints were made through MRA web, searching for locations. I thought they were all on road locations. I will take a close look again.
            P.S. as a new user I am limited to only being able to post every 120 seconds... which is frustrating! Sorry for the delays in replying πŸ˜†
              @Rob-Verhoeff
              @Tom-Grzelinski That delay will pass. I strongly advise you to still break down the route into manageable segments and make sure all waypoints are placed precisely on top of the route line. I wouldn't have much confidence in your approach otherwise. Also, take a look at the support section for a guide on creating a multi-day trip. By the way, there are very helpful videos on this topic circulating on YouTube. Good luck!
                Tom Grzelinski
                @Rob-Verhoeff
                Again, thanks Rob, I will look at multi-day trips.
                richtea999 RetiredWingMan 3 Replies Last reply
                  @Rob-Verhoeff
                  richtea999 Offline
                  richtea999 Offline
                  @Tom-Grzelinski said in Newbie needs help opening HERE map in app...:
                  @Rob-Verhoeff
                  There's a 'Split' option available to Gold users - it's in the Toolkit menu. A lifesaver after putting all that effort in!
                  All you have to do is select the waypoints where you want to split the route up. It won't overwrite your existing route, so you can experiment without risk.
                    @Rob-Verhoeff
                    RetiredWingMan Offline
                    @Tom-Grzelinski I tried splitting your route in half and then half again. In each case the route loads but failed when attempting to navigate. I took a look at the last section of your route, the Waypoints are generally fine but it appears you may be dealing with closed roads. See below red sections. I had the traffic layer turned on.
                      @Rob-Verhoeff
                      @Tom-Grzelinski I did a little more testing. I'm not able to open the entire map but I split the map into two half's and I'm able to open each half. I'm also able to start navigation as long as I quickly turn off the option to navigate from current location (can't navigate from Canada 😊 ). So the end result is that I don't know why the app can't open the entire route ... other than it is simply too large. I had a similar problem when planning a 2 week trip. Once I was finished planning on the Web site I split into separate routes for each day. Good luck.
                      • richtea999 richtea999
                        @Rob-Verhoeff
                        Tom Grzelinski
                        @richtea999
                        Hi Rich, THANK YOU. This worked perfectly πŸ‘
                        Tom
                          Tom Grzelinski
                          @Doug-Robinson
                          Doug, thank you so much. I successfully SPLIT my route in to 13 days and each one opens perfectly in the iPhone app.
                          I am indeed navigating a lot of Apline passes that are often closed. I am hoping that going in September will mean I can do all the passes I intend to, but I have seen photos that there is already snow on the Grossglockner Pass!
                          Tom
                          • Tom Grzelinski Offline
                            Tom Grzelinski
                            The more I use MRA, the more impressed I am. Well done to the team MRA πŸ‘
                              Corjan Meijerink Offline
                              @Tom-Grzelinski we keep pushing πŸ’ͺ
                              Tom Grzelinski
                              Tom Grzelinski
                              • Offline kaarten downloaden
                              • Rondrit maken lukt niet
                                Rob Vonk
                                Rob Vonk
                              • The most important rule: all content is to be posted in English πŸ‡¬πŸ‡§ unless the post is made in the language specific area in the Self Support forum.
                              • Questions and suggestions
                                Mike wiruth
                                Mike wiruth
