  4. Navigation to POI not possible offline
13 Posts 5 Posters 128 Views 1 Watching
  • Calibos Calibos
    impossible de faire fonctionner la navigation hors ligne vers un POI.
    1-Phone in airplane mode
    2-select POI ok
    3-Navigate...impossible
    does this work for anyone? I couldn't get it to work
    @Calibos Silly question: but do you have the offline map for your region installed?
    Calibos 1 Reply Last reply
      Calibos
      Calibos
      Calibos
      @StefanHummelink
      yes all the cards are up to date and installed for europe
      • Arno 0
        Arno 0
        Arno 0
        Maybe you should also activate the "ofline navigation" switch in the Functional - Navigation settings?
        • Arno 0 Arno 0
          Calibos
          Calibos
          Calibos
          @Arno-0 I tried with and without it's the same thing
          Arno 0 1 Reply Last reply
          • Calibos
            Calibos
            Calibos
            does this work for you?
            RetiredWingMan Arno 0 2 Replies Last reply
            • Calibos Calibos
              Arno 0
              Arno 0
              Arno 0
              @Calibos I have no problems and it works on both my Android and iOS smartphones.
              • Calibos Calibos
                @Calibos works for me, both offline and online with no Internet. Android and next v 4.0.2 202
                • Calibos Calibos
                  Arno 0
                  Arno 0
                  Arno 0
                  @Calibos By the way, do you use the latest 4.0.2 version which is build 202?
                  • Calibos
                    Calibos
                    Calibos
                    yes last version too, I have to retest tomorrow
                    • Calibos Calibos
                      2-select POI ok
                      ATLast
                      ATLast
                      ATLast
                      @Calibos Airplane mode may also disable the Gps, thus no way to route somewhere.
                      Try turning off wifi and datas only, and try again
                      • ATLast ATLast
                        @ATLast airplane mode does not disable location services. I was driving a route today. My phone overheated and shut down all apps. After it cooled down and I tried to restart the route it failed. I eventually had to enable offline to get the route planned for navigation. Yesterday I was testing on my tablet and thought it worked with offline enabled or not. Today I confirmed that is not correct. For a downloaded route and no Internet offline must be enabled. However, it appears that navigating o a favourite does not need to be offline.
                        • Calibos
                          Calibos
                          Calibos
                          Good that's it I found the reason for my problem. I installed the application on my smartphone and on my tablet for motorcycle navigation but I only downloaded the offline maps for the tablet which it has an SD card to hold the maps.
                          so I tested this morning with the tablet and there miracle it works too wel!!😳
                          Great feature.
                          Kudos to the developers👍
                          Arno 0
                          Arno 0
                          ATLast
                          ATLast
                          Calibos
                          Calibos
                            Axel Lange
                            Axel Lange
                          • In het kort......
                          • Route probleem
                            Jack 13
                            Jack 13
