  4. Navigation to POI not possible offline
13 Posts 5 Posters 128 Views 1 Watching
  • Calibosundefined Offline
    Calibos
    impossible de faire fonctionner la navigation hors ligne vers un POI.
    1-Phone in airplane mode
    2-select POI ok
    3-Navigate...impossible
    does this work for anyone? I couldn't get it to work
    Stefan Hummelinkundefined ATLastundefined 2 Replies Last reply
    • Calibosundefined Calibos
      2-select POI ok
      @Calibos Silly question: but do you have the offline map for your region installed?
      Calibosundefined 1 Reply Last reply
        Calibos
        @StefanHummelink
        yes all the cards are up to date and installed for europe
        • Arno 0undefined Offline
          Arno 0
          Maybe you should also activate the "ofline navigation" switch in the Functional - Navigation settings?
          • Arno 0undefined Arno 0
            Calibos
            @Arno-0 I tried with and without it's the same thing
            Arno 0undefined 1 Reply Last reply
              Calibos
              does this work for you?
              RetiredWingManundefined Arno 0undefined 2 Replies Last reply
                Arno 0
                @Calibos I have no problems and it works on both my Android and iOS smartphones.
                  @Calibos works for me, both offline and online with no Internet. Android and next v 4.0.2 202
                    Arno 0
                    @Calibos By the way, do you use the latest 4.0.2 version which is build 202?
                      Calibos
                      yes last version too, I have to retest tomorrow
                        2-select POI ok
                        ATLastundefined Offline
                        ATLast
                        @Calibos Airplane mode may also disable the Gps, thus no way to route somewhere.
                        Try turning off wifi and datas only, and try again
                        • ATLastundefined ATLast
                          @ATLast airplane mode does not disable location services. I was driving a route today. My phone overheated and shut down all apps. After it cooled down and I tried to restart the route it failed. I eventually had to enable offline to get the route planned for navigation. Yesterday I was testing on my tablet and thought it worked with offline enabled or not. Today I confirmed that is not correct. For a downloaded route and no Internet offline must be enabled. However, it appears that navigating o a favourite does not need to be offline.
                            Calibos
                            Good that's it I found the reason for my problem. I installed the application on my smartphone and on my tablet for motorcycle navigation but I only downloaded the offline maps for the tablet which it has an SD card to hold the maps.
                            so I tested this morning with the tablet and there miracle it works too wel!!😳
                            Great feature.
                            Kudos to the developers👍
                            ATLastundefined
                            ATLast
                            Arno 0undefined
                            Arno 0
                            Calibosundefined
                            Calibos
                            • Spoken streetnames
                              GT JWRundefined
                              supergundefined
                            • Am I using it wrong?
                              Kerry Lebelundefined
                              Kerry Lebel
                            • RX routes
                              Gos Kuusundefined
                              Gos Kuus
                              1.6k
                              Steve Jarrellundefined
                              Steve Jarrell
                              1.4k
