  4. Navigation to POI not possible offline
13 Posts 5 Posters 128 Views 1 Watching
  • Arno 0
    Arno 0
    Arno 0
    Maybe you should also activate the "ofline navigation" switch in the Functional - Navigation settings?
    Calibos 1 Reply Last reply
    • Arno 0 Arno 0
      Calibos
      Calibos
      Calibos
      @Arno-0 I tried with and without it's the same thing
      Arno 0 1 Reply Last reply
      • Calibos
        Calibos
        Calibos
        does this work for you?
        RetiredWingMan Arno 0 2 Replies Last reply
        • Calibos Calibos
          Arno 0
          Arno 0
          Arno 0
          @Calibos I have no problems and it works on both my Android and iOS smartphones.
          • Calibos Calibos
            @Calibos works for me, both offline and online with no Internet. Android and next v 4.0.2 202
            • Calibos Calibos
              Arno 0
              Arno 0
              Arno 0
              @Calibos By the way, do you use the latest 4.0.2 version which is build 202?
              • Calibos
                Calibos
                Calibos
                yes last version too, I have to retest tomorrow
                • Calibos Calibos
                  impossible de faire fonctionner la navigation hors ligne vers un POI.
                  1-Phone in airplane mode
                  2-select POI ok
                  3-Navigate...impossible
                  does this work for anyone? I couldn't get it to work
                  ATLast
                  ATLast
                  ATLast
                  @Calibos Airplane mode may also disable the Gps, thus no way to route somewhere.
                  Try turning off wifi and datas only, and try again
                  • ATLast ATLast
                    @ATLast airplane mode does not disable location services. I was driving a route today. My phone overheated and shut down all apps. After it cooled down and I tried to restart the route it failed. I eventually had to enable offline to get the route planned for navigation. Yesterday I was testing on my tablet and thought it worked with offline enabled or not. Today I confirmed that is not correct. For a downloaded route and no Internet offline must be enabled. However, it appears that navigating o a favourite does not need to be offline.
                    • Calibos
                      Calibos
                      Calibos
                      Good that's it I found the reason for my problem. I installed the application on my smartphone and on my tablet for motorcycle navigation but I only downloaded the offline maps for the tablet which it has an SD card to hold the maps.
                      so I tested this morning with the tablet and there miracle it works too wel!!😳
                      Great feature.
                      Kudos to the developers👍
                      ATLast
                      ATLast
                      Arno 0
                      Arno 0
                      Calibos
                      Calibos
                        1.5k
                        1.4k
                        2.3k
                      • MRA 6.0.0 (515) Menu black no function /// Menü schwarz keine Funktion
