  3. [App-Beta] Announcements
  4. Updated Beta! (v4.0.2)
30 Posts 12 Posters 408 Views 4 Watching
    @Dave-J-0 If you long press a random point on the map in the home screen, you should immediately be redirected to the HERE routing screen (like you see when starting the navigation / selecting a favorite while offline).
    While offline you should never get to see the route generator settings (where you can select the curviness) 🙂
    @Corjan-Meijerink brill. Get it now and it works as you say. Sorry for my confusion.
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    Google Pixel 6 Pro
    • Dave J 0 Dave J 0
      @Dave-J-0 no worries! Happy you asked
      wilfried Baars 1 Reply Last reply
        Hey everyone! 👋
        Last week we announced a new Beta: https://forum.myrouteapp.com/topic/4731/new-beta-v4-0-2
        The new 4.0.2 Beta version has build number 202 and will be available somewhere later today. You need to update from the Play Store / TestFlight as usual.
        This week we've updated the Beta for you all. The changes as mentioned in the previous announcement still apply.
        @Corjan-Meijerink said in New Beta! (v4.0.2):
        In preparation for facilitating offline search
        Preparation has been completed and this updated Beta now includes offline searching! 🎉 If you do not have internet and start searching, you will get results 😏 Obviously you do need to have offline maps downloaded to ensure this is possible.
        The following search functionalities now work offline:
        • Favorites (typing in the search bar as opening from the favorites page)
        • Quick & easy POI search
        • Address search
        • Long press on the map
        I'd say: download the update, refresh your favorites, download offline maps, turn off your internet and be amazed! 🎉
        Furthermore we've updated the menu to prevent confusing users with what functionalities are native within the app and what part is within the website 🙂
        We are really looking forward to your feedback about this Beta! 🙂
        Cheers,
        Corjan
        @Corjan-Meijerink well done (again) 😘
          wilfried Baars
          wilfried Baars
          wilfried Baars
          @Corjan-Meijerink Is there a change that affects the functionality of Barbuttons?
          In keymap 1 I suddenly have a problem that buttons 1 and 2 (zoom in and zoom out) no longer work. The LED indicating that a command has been sent on the bar button does light up and everything else seems to work normally.
          • wilfried Baars wilfried Baars
            @wilfried-Baars if you’ve got default / BarButtons selected everything should work as expected! What firmware are you using?
            Please verify if the current production version / previous Beta (4.0.1) does work how you expect! 🙂
              wilfried Baars
              wilfried Baars
              wilfried Baars
              @Corjan-Meijerink It is solved. Joost helped me very well.
              Thanks for reply and of course Joost for help.
                @wilfried-Baars if you got any info relevant for MRA, do share 🙂
                  Hey everyone! 👋
                  • Address search
                  Cheers,
                  Corjan
                    [[topic:post-is-deleted]]
                    @Doug-Robinson done automatically every time you open the favorites while connected to internet
                    • Dave J 0
                      @Corjan-Meijerink there appears to be a different app reaction between iOS and Android when you select a route and you have no internet and you then 'start' the selected route.
                      Both iOS and Android show the 'downloads' option if no internet and you select 'routes' from the menu. Selecting 'downloads' then correctly takes me to my downloaded files area and selection of one of these routes then shows the route overview with start and route options. Same route used on both devices. All good so far - great work.
                      With iOS, selecting 'start' then initiates nav correctly with the offline icon showing. I have not had to go to nav settings at all. Brilliant.
                      With Android, selection of start brings up the 'something went wrong' prompt and I have to manually turn on offline navigation in the settings.
                      However and separately, if I long press on the map to use the new search feature to navigate to a point then the navigation initiates correctly with no error prompt and the offline icon is showing correctly. I have not had to turn offline on at all in this instance. selecting from my 'Favourites' also work correctly.
                      Just appears to be a problem with the route approach initiating offline when no internet. Furthermore, if you have already selected a point and favourite rpruor to a route then the app is already offline and there is no issue.
                      Hope this all makes sense.
                      iPhone 18 Pro
                      CHIGEE AIO-6 LTE
                      Google Pixel 6 Pro
                      • Dave J 0 Dave J 0
                        @Dave-J-0 Thanks for sharing!
                        As the error on Android does not indicate it's related to internet, can you check if the issue persists with all your routes? If I had to take a guess from behind my pc - the route you are trying to load on Android passes a region you haven't downloaded offline.
                        Obviously something can indeed be wrong but I'm very sure the implementation on Android & iOS is the same so therefore I'm guessing it's related to the offline maps.
                        Dave J 0 1 Reply Last reply
                          #22
                          @Corjan-Meijerink I deliberately chose a route that maps were downloaded although I do go from England into Wales - I do this a lot because I am 30 mins from mid-Wales (awesome riding).
                          No problem with iOS just Android when I have selected a route at the start to navigate. Same thing happens with my other downloaded routes on Android which are just in England and local to me.
                          iPhone 18 Pro
                          CHIGEE AIO-6 LTE
                          Google Pixel 6 Pro
                          DerRoteBlitz 1 Reply Last reply
                          • Dave J 0 Dave J 0
                            DerRoteBlitz
                            DerRoteBlitz
                            DerRoteBlitz
                            @Dave-J-0 I have had the same issue with my Android Pixel. I have deleted the maps and downloaded again. After that it works.
                            • DerRoteBlitz DerRoteBlitz
                              #24
                              @DerRoteBlitz Tried that and still the same problem. Thank you for the suggestion. 😀
                              iPhone 18 Pro
                              CHIGEE AIO-6 LTE
                              Google Pixel 6 Pro
                              • MotoCon
                                When having no internet, clicking the routes button shows the message "Something went wrong" and the Downloads button is presented. It would be great if that text would change into "You have no online connection, click Downloads for offline routes".
                                Then if you go to Downloads and start a route, The same massage appears, with the sub text "Can't calculate route". Why not throw a question "would you like to go offline and try again?". Especially if offline maps are present.
                                  #26
                                  @Con-Hennekens I could go with the suggestion. However, the current flow is brilliant on iOS and I would like the same on Android. It is just this one glitch that would be great if it could be solved. I like the fact that offline happens automatically and that I can see that I am offline by the icon.
                                  iPhone 18 Pro
                                  CHIGEE AIO-6 LTE
                                  Google Pixel 6 Pro
                                  Arno 0 MotoCon 2 Replies Last reply
                                  • Dave J 0 Dave J 0
                                    Arno 0
                                    Arno 0
                                    Arno 0
                                    wrote on last edited by Arno 0
                                    #27
                                    @Dave-J-0 I agree with you because today I encountered this problem on Android. You only receive the message that something went wrong and then you self have to think what went wrong and how can I solve that. On iOS it gives you the solution and a button you need to click on to make it work.
                                    • Dave J 0 Dave J 0
                                      @Dave-J-0, I was not aware that there is a different workflow on IOS. In that case they should be made equal indeed.
                                        @Con-Hennekens The iOS workflow works brilliantly and Android should be the same apart from the glitch I encountered. The flow causes an error (when no internet) in not switching automatically to offline to allow calculation from the downloaded route and map like iOS does with the last build 202.
                                        iPhone 18 Pro
                                        CHIGEE AIO-6 LTE
                                        Google Pixel 6 Pro
                                          @Peter-Schiefer @Edwin_M This update has not improved anything related to the offline maps download stability. If you experience issues or it's stuck / corrupted, reinstalling might be the only solution.
                                          @Edwin_M Thanks for sharing the stuck notification 😉 From the top of my head I'm not sure what the expected behavior is.
                                          Edwin_M
                                          Edwin_M
                                          Edwin_M
                                          @Corjan-Meijerink just did another Download , and now the message was ok: regions downloaded and I was able to swipe it away.
                                          Edwin_M
                                          Edwin_M
                                          Arno 0
                                          Arno 0
                                          Dikke Wim
                                          Dikke Wim
                                          DerRoteBlitz
                                          DerRoteBlitz
                                          wilfried Baars
                                          wilfried Baars
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
