  2. Announcements
  3. Seasonal closure issue solved
23 Posts 13 Posters 13.3k Views 2 Watching
    Hi everyone! πŸ‘‹
    Quite some time ago (February) we identified an issue with the seasonal closures: https://forum.myrouteapp.com/topic/3343/here-issue-regarding-seasonal-closures
    Unfortunately the issue affected a lot of routes, created by many users over quite a long time 😞 We were (and still are) very sorry for the inconvenience this caused. As stated in the forum post above, it however wasn't an issue from our side.
    Today I've received confirmation from HERE that we are able to use a temporary workaround while their internal development team starts working on a more permanent solution (finally).
    As of now, the website is updated to use the temporary workaround! πŸŽ‰
    If we take the following mountain pass as example, you would always be routed the long way around the mountain. Regardless of your seasonal closure setting
    If you turn off the seasonal closures using the toolkit, the route now does what you expect! 😏
    I'm happy with the solution we now have and once again, sorry for the inconvenience.
    Best,
    Team MRA ❀
    Hubert Thoringundefined MarcMundefined Bill Hoxworthundefined 3 Replies Last reply
      Hi everyone! πŸ‘‹
      Best,
      Team MRA ❀
      @Corjan-Meijerink Danke fΓΌr die Info !!
      • Gary Franceundefined Offline
        Gary France
        Thank you for finding a solution. Those of us who plan routes through mountains have been waiting for this and now we are grateful!
          Hi everyone! πŸ‘‹
          Best,
          Team MRA ❀
          MarcMundefined Offline
          MarcM
          @Corjan-Meijerink Good Job !!!!πŸ‘
            Hi everyone! πŸ‘‹
            Best,
            Team MRA ❀
            Bill Hoxworthundefined Offline
            Bill Hoxworth
            @Corjan-Meijerink Many thanks for your efforts, I did realise from the very first problem, the issue was with HERE and not yourselves. Once again, thanks for your efforts and time, much appreciated.
            • Paul French 0undefined Offline
              Paul French 0
              I had suspected my problem with ferry crossings was due to seasonal closures, but now I am not so sure. I used the suggestion to avoid season closures, but still the HERE route takes the long way round. See image showing HERE route compared with TomTom (in red) which takes the ferry.
              Here is the setting:-
              Is there a way to force the route to use ferries in HERE maps?
              Thank you,
              Paul
              • Paul French 0undefined Paul French 0
                Thank you,
                Paul
                @Paul-French-0 Position route points 3 and 4 close to the ferry departure and arrival points and choose the skip option for route point 4.
                Paul French 0undefined 1 Reply Last reply
                  Paul French 0
                  @Nick-Carthew Thank you - that worked perfectly.
                    @Paul-French-0 You’re welcome
                    Bart 4undefined 1 Reply Last reply
                      Bart 4undefined Offline
                      Bart 4
                      @Nick-Carthew How will be the result if you send this route to the zumo XT version 1.2? Will this work right this way?
                      • Bart 4undefined Bart 4
                        @Bart-4 When you arrive on the other side of the ferry crossing the route will continue from there.
                        • paul69undefined Offline
                          good afternoon @Corjan-Meijerink
                          for clarity and the avoidance of doubt, I am going to ask this with the risk of looking foolish.
                          @Corjan-Meijerink said in Seasonal closure issue solved:
                          may I ask, when one turns off seasonal closures what does this action do, and do we,
                          1. put a tick next to "disable seasonal closures, or,
                          2. NOT put a tick next to "disable seasonal closures"
                          sometimes wording can be slightly confusing.
                          i.e.
                          on some websites you get,
                          if you do not want to receive correspondence do not put a tick in the box, aarrrrggghhhh 😲
                          K1600 GTL
                          Oukitel RT3
                          iPhone 13 Pro, carpuride 702b
                          • paul69undefined paul69
                            i.e.
                            @paul-69, The disabling of Seasonal closures is enabled when ticked. If ticked, you can plan routes over passes that are momentarily closed. I understand your confusion πŸ˜‰
                            paul69undefined 1 Reply Last reply
                              hi @Con-Hennekens said in Seasonal closure issue solved:
                              hi @Con-Hennekens, thanks very much for your reply.
                              the reason I asked the embarrassing question is,
                              I planned some routes around the mountain passes earlier in the year for a trip is summer.
                              I DID have the tick next to "disable seasonal closures" however, no matter how much I tried, in some circumstances it would not allow me to route over a pass, at the time I used HERE map to plan.
                              this is for info only, and in no way a contradiction.
                              thanks again.
                              K1600 GTL
                              Oukitel RT3
                                thanks again.
                                @paul-69, Don't be embarrassed πŸ˜‰ Actually there have been some problems with that option, introduced by HERE. But they were solved some time ago.
                                • Mark sadzundefined Offline
                                  Mark sadz
                                  Still doesn't work!
                                  • Mark sadzundefined Mark sadz
                                    Still doesn't work!
                                    @Mark-sadz Try adding some more route points to force the HERE map to follow your desired route.
                                    Mark sadzundefined 1 Reply Last reply
                                      Mark sadz
                                      @Nick-Carthew I've tried nick it still routes around the wrong way, driving me nuts!!
                                        @Mark-sadz Share your route on here and we might be able to offer a solution or workaround.
                                        • Tom Grzelinskiundefined Offline
                                          Tom Grzelinski
                                          Hi, I am new here, so please be gentle! I have been using myroute for a few months and have now bought the lifetime package.
                                          I cannot find the 'Disable seasonal closures' option anywhere. It is not in my Toolkit drop down menu. BUT, I am sure it was there a few months ago when I started using myroute.
                                          I am on a Mac and have tried Safari and Chrome browsers, but both are the same.
                                          Can someone tell me where this feature is?
                                          Do I need to switch it on, on my iPhone app? Or is it 'embedded' in the route when you make it on the website?
                                          Thank you for any help.
                                          Tom
                                          Porsche 911 and VW Transporter T6.1 running CarPlay.
                                          iPhone 17 Pro running Waze and MRA.
                                          MRA Routeplanner on web via Mac
                                          richtea999undefined
                                          paul69undefined
                                          MarcMundefined
                                          MarcM
                                          Tom Grzelinski
                                          Gary France
                                          Bart 4undefined
                                          Bart 4
                                          Mark sadzundefined
                                          Mark sadz
                                          Paul French 0
                                          Bill Hoxworth
                                            JoshuaMurray 0undefined
                                            JoshuaMurray 0
                                          • seizoen afsluitingen
                                          • Poi's per rit op meerdaagse reizen
                                          • nav 6 route problem
                                            jan tomassenundefined
                                            jan tomassen
                                            36.4k
                                          • Tracklog datapoints [Local time, speed, altitude, export CSV]
                                            John Matthews 0undefined
                                            John Matthews 0
