  3. Quad lock versus SP to protect your mounted smartphone
22 Posts 12 Posters 4.3k Views 3 Watching
    Here is what QuadLock say about their wireless charger. QuadLock Wireless Charger
    • Lynchy67undefined Lynchy67
      Not if you have a QC3.0 Din Plug Charger for Samsung phones.
      Even when I’m recording my screen when using the beta on the road, the percentage will always be creeping slowly upwards.
      I never use navigation voice prompts or have any music on the phone and only have the Next App running.
      Also Samsung Phones, in my experience, are renowned for falsely reporting moisture ingress when charging directly with a USB lead, particularly on a motorbike.
      Edwin_Mundefined Offline
      Edwin_M
      @Lynchy67 i don't understand this, Quad lock says
      : Please Note:
      Apple devices charge at a maximum of 7.5W.
      The Galaxy S22, S21, S20 and Note20 ranges will charge wirelessly at a maximum of 5W.
      QC3is up to 36w , but the charging head will never do that.
      Also following cause I had some charging issue in rain , phone complained about moisture in port. So would like to switch to wireless but don't know if it will keep up...
      Lynchy67undefined 2 Replies Last reply
      • Edwin_Mundefined Edwin_M
        : Please Note:
        Lynchy67undefined Offline
        @Edwin_M
        If you have 5 minutes then watch the video below which is sped up 6x.
        This is the video from last week that had the Waypoints numbers jumping ahead.
        Power Source is a £13 QC3.0 Din Plug from Amazon.
        Keep your eye on the Phone Percentage.
        No Drain whatsoever.
        Bare in mind that I was also screen recording on the phone.
        https://youtu.be/EPRw-3p_Dqw
          : Please Note:
          @Edwin_M
          The S21+ can do Super Fast Charging and Fast Wireless Charging.
          Fast Wireless Charging is what QC3.0 provides.
          They claim it is up to 4 times faster?
          Edwin_Mundefined 1 Reply Last reply
            @Edwin_M
            Edwin_M
            @Lynchy67 My issue is that the information on the quadlock (website) is a bit confusing. What is the poweroutput/capability of the wireless head.
            it says fast charging supported, but also says the limitation power output on some devices.
            So I am a bit lost there 😞 . Even if you would have a QC3 power in to the wireless head, that will not be passed through by the wireless head, as that limits the output. 😕
            (I am using a spigen tough armor case now, and is the drop protection of quadlock as good as that.) It is a lot of money for those Quadlock and SP setups.... so a wireless RAM universal grip could also be an option.
              I'm wondering if someone has experience with the wireless charging version of Quad Lock and/or SP.
              And of course, what would be the beste choice tb buy.
              As I understand, both Quad Lock and SP have wireless charging options and have optional dempeners, two reasons why I consider buying one of these.
              All tips are welcome!
              Corné Voogtundefined Offline
              Corné Voogt
              wrote on last edited by Corné Voogt
              @Dikke-Wim
              I have the RAM−HOL−UN14WB, RAM Tough−Charge Quick−Grip, and this holds my iPhone XS (6.1”) very well. Especially with the extra rubber band (supplied ). It charges with 5V USB so that should provide 5W I guess.
              I have used it on a 1 hour ride with MRA NEXT Beta 3.2.15 and the battery went DOWN from 76 to 56%! So that sucks.
              I can’t use MRA on an all day ride if power consumption is not improved. ( Like in time for my upcoming Norway trip next month).
              On the return ride I killed the MRA app and left all other apps (like music) on and the battery % stayed at the exact same level.
              In other words, MRA Next 3.2.15 drains the battery faster than it can be charged with QI charger.
              Edwin_Mundefined Con Hennekensundefined 2 Replies Last reply
              • Corné Voogtundefined Corné Voogt
                @Dikke-Wim
                Edwin_M
                @Corné-Voogt Tough-Charge should be 10W (on RAM site , I was new ones that should go up to 15W). But then an additional issue may occur? overheating?
                according to motormount.nl RAM-HOL-UN14WB-V7M-1 should go up to 15W
                  @Dikke-Wim
                  @Corné-Voogt said in Quad lock versus SP to protect your mounted smartphone:
                  I think if this happens, it is not only MRA draining your battery.
                  • Neil Bartlettundefined Offline
                    Neil Bartlett
                    A little background for context. I do food delivery of up to ten hours a day, rain or shine. I have used the SP and Quad lock. In the beginning SP had better hardware (metal) and the Quad lock was plastic. SP also had wireless charging. So I went with SP. Fantastic hardware, poor electronic changing. My unit was replaced three times. IN NZ the distributor had so many claims they stopped supplying the product. Got a new iPhone 14 Pro Max, so changed to Quad lock system. That hurt, LOL. Currently can buy metal parts so good quality now. Wireless charging and vibration damper is great. Lock is OK but more fiddly than SP. I remove phone from bike twice every delivery so SP was better/quicker. Quad have a great Glass stick-on screen protector to fit a ph in their case, which works with standard magnetic charger as well as QL charger without removing case. Case also seems more water proof with no leakage into back of ph through camera holes. Over all, the QL is better in may opinion.
                    R1200RS, Nav VI, Zumo XT2, iPhone. — Plot the Track, Go the Distance
                    • Neil Bartlettundefined Neil Bartlett
                      I have a Quad Lock vibration dampener with wireless charger and am very satisfied with it.
                      🏍️ Tiger: DMD-T665 + SilverFox controller
                      • Dikke Wimundefined Offline
                        Dikke Wim
                        I now see that for Quad Lock there is a 'poncho' available to prevent clicks on your smartphone by raindrops.
                        Maybe THE solution for the rain problems discussed above.
                        See: YouTube: Quad Lock poncho
                          #21
                          @Dikke-Wim
                          I’m not a fan of the Quad Lock Poncho to be honest as its so thick you can’t actually interact with the screen when its on.
                          It’s nothing more than a rain cover.
                            @Dikke-Wim
                            @Lynchy67 I just use a zip lock bag. 😊
                            richtea999undefined
                            Dave J 0undefined
                            Edwin_Mundefined
                            Edwin_M
                            Neil Bartlett
                            MarcMundefined
                            MarcM
                            Dikke Wimundefined
                            Dikke Wim
                            Lynchy67undefined
                            Corné Voogt
                              Martin Wilckeundefined
                              Martin Wilcke
                              guenniguenzelsenundefined
                              guenniguenzelsen
                            • Preview
                              Iain Cochrane 0undefined
                              Iain Cochrane 0
                            • batterij verbruik
                            • Carpuride
                            • What is this symbol?
                              Aiello antoninoundefined
