  4. Four day test
Four day test
20 Posts 8 Posters 227 Views 1 Watching
    @Corjan-Meijerink Without the "Download update" for previously downloaded maps I cannot download new Maps/countries. Tried more than 10x the update without success. Hopefully the next update will cover this.
    I know you are all working very hard to cover many bugs and to add new features. Keep up the good work.
    @Dikke-Wim I know for sure the next update won't fix this 😉 Most likely we'll work on it after that one.
      Did you load the route from the Downloads section?
      GT JWRundefined Offline
      @Doug-Robinson I have not yet had to use offlline , however, a fast approaching 9 day adventure to the Appalacian Mountains is just around the corner and I anticipate areas of no internet connection - and the offline seems a bit confusing (or I am making it that way!)..
      To use it, is it not simply just having the Offline Navigation turned on in the Navigation Settings - Functionial tab? My understanding is that if you are on an active route with this enabled, and internet is lost for whatever reason, the route continues?
      Or do the routes also have to be downloaded - obvioulsy when connected to the internet?
      • GT JWRundefined GT JWR
        @GT-JWR Yes you need to download the route.
        Open the route and click the download button.
        Scroll to the last option - Make offline available.
        When you need to use it, open the Download tab in the Navigation menu and click on your route to use it.
          @Nick-Carthew very good, thanks!
          • ferrand24gmail.comundefined Offline
            ferrand24gmail.com
            I have exactly followed the instructions for using a downloaded route and it just doesn't work. I created a short route and "made available for offline use". I then selected this route from my "downloads" as soon as I tried to start navigation it said "something went wrong, unable to calculate route".
            Am I doing something wrong?
            • ferrand24gmail.comundefined ferrand24gmail.com
              @Roger-Doidge said in Four day test:
              Difficult to say if you’re doing anything wrong without seeing your route. Can you share it please.
              ferrand24gmail.comundefined 1 Reply Last reply
                ferrand24gmail.com
                @Nick-Carthew
                Excuse my ineptitude, how do I share the route?
                  @Nick-Carthew
                  @Nick-Carthew
                  Firstly, make sure that the privacy of the route is set to public. Then copy the url (web address) and paste it in your reply.
                    @Nick-Carthew
                    ferrand24gmail.com
                    @Nick-Carthew
                    Nick, here is the url myrouteapp.com/route/open/7470383
                    I see from your profile that you are a Devon boy. Until we moved to France 20 years ago I lived in Plymouth and walked on Dartmoor regularly. I still miss the moor.
                      @Nick-Carthew
                      @Roger-Doidge Cream on First 😊
                      Move route point one onto the road, that should fix it.
                      Corjan Meijerinkundefined ferrand24gmail.comundefined 2 Replies Last reply
                        @Nick-Carthew hahaha, people who put jam on first are also allowed to exist 😉
                          ferrand24gmail.com
                          @Nick-Carthew Thanks, I'll try that.
                          Which first, jam or cream?
                            @Roger-Doidge I'm curious too. In June I want to go to Scotland and I'm planning to navigate with offline route like jou did. (Roaming in Scotland is very expensive).
                            Hopefully, someone has good comments about 'missing a trick'.
                            G.Grote Ganseijundefined Offline
                            G.Grote Ganseij
                            @Dikke-Wim ik ben de afgelopen 10 dagen er geweest heb daar 10 routes gereden allemaal offline, eerst bij je hotel de route laden je kunt deze met de instelling offline laden en dan gewoon rijden, het voordeel van de laatste update is automatisch punten overslaan dat dit werkt. ik heb na deze update geen problemen gehad met het rijden van routes, wordt alleen maar beter.
                            RetiredWingManundefined
                            GT JWRundefined
                            ferrand24gmail.com
                            G.Grote Ganseij
                            Dikke Wimundefined
                            Dikke Wim
                            • Te veel problemen
                              Lex.Kloet.RXundefined
                              Lex.Kloet.RX
                            • Track prefix name when exporting through web or andorid MyRouteApp
                            • Geuploade gpx file "Kan route niet berekenen"
                              Richard Blaauwundefined
                              Richard Blaauw
                            • Exporting MRA Planned Routes to a Garmin XT3
                            • BDR Route GPX Support
                            • Raul from Argentina
                            • Zu viele Wegpunkte?
                              Frank Schefflerundefined
                              Frank Scheffler
                            • Motorhotel in de eiffel?
