  4. Four day test
Four day test
20 Posts 8 Posters 227 Views 1 Watching
  • ferrand24gmail.com
    ferrand24gmail.com
    ferrand24gmail.com
    I have just returned from a four day trip to the Pyrenees using Navigation Next for the first time.
    Overall the experience was very good, the maps were clear and the voice prompts were clear and well timed.
    There were one or two issues which may be in part, due to my inexperience in using the app. When deviating from the planned route the app was sometimes very slow to adapt to the change of route but on other occasions the correction was immediate.
    I downloaded and saved for use offline the five routes I had planned but from time to time when the phone signal was lost the navigation stopped working. maybe I am missing a trick here but if it doesn't work in the absence of a phone signal it rather limits its use as many of the routes I use are somewhat remote and mountainous.
    I look forwards to learning from your comments!
    Dikke Wim Corjan Meijerink 2 Replies Last reply
    • ferrand24gmail.com ferrand24gmail.com
      Dikke Wim
      Dikke Wim
      Dikke Wim
      @Roger-Doidge I'm curious too. In June I want to go to Scotland and I'm planning to navigate with offline route like jou did. (Roaming in Scotland is very expensive).
      Hopefully, someone has good comments about 'missing a trick'.
      G.Grote Ganseij 1 Reply Last reply
      • RetiredWingMan
        Did you load the route from the Downloads section?
        Dikke Wim GT JWR 2 Replies Last reply
          Dikke Wim
          Dikke Wim
          Dikke Wim
          @Doug-Robinson Not yet. I have to make the routes first 😀 Today I had problems downloading my maps.... Grrr. This is still not working correctly.
          • Dikke Wim Dikke Wim
            @Dikke-Wim, Yes, that's a general frustration for many.
              @Roger-Doidge Sounds good! 🙂
              Offline navigation (using downloaded maps) might have solved that issue. If you've got a bad reception, we ask if you want to switch to the offline mode.
              The corrections should be almost immediately.
              Offline available routes can be found in the downloads as @Doug-Robinson mentioned. In the coming update we made some improvements regarding the flow of finding them there 😉
              Dikke Wim 1 Reply Last reply
                Dikke Wim
                Dikke Wim
                Dikke Wim
                @Corjan-Meijerink Without the "Download update" for previously downloaded maps I cannot download new Maps/countries. Tried more than 10x the update without success. Hopefully the next update will cover this.
                I know you are all working very hard to cover many bugs and to add new features. Keep up the good work.
                  @Dikke-Wim I know for sure the next update won't fix this 😉 Most likely we'll work on it after that one.
                    @Doug-Robinson I have not yet had to use offlline , however, a fast approaching 9 day adventure to the Appalacian Mountains is just around the corner and I anticipate areas of no internet connection - and the offline seems a bit confusing (or I am making it that way!)..
                    To use it, is it not simply just having the Offline Navigation turned on in the Navigation Settings - Functionial tab? My understanding is that if you are on an active route with this enabled, and internet is lost for whatever reason, the route continues?
                    Or do the routes also have to be downloaded - obvioulsy when connected to the internet?
                    • GT JWR GT JWR
                      @GT-JWR Yes you need to download the route.
                      Open the route and click the download button.
                      Scroll to the last option - Make offline available.
                      When you need to use it, open the Download tab in the Navigation menu and click on your route to use it.
                      GT JWR 1 Reply Last reply
                        @Nick-Carthew very good, thanks!
                          ferrand24gmail.com
                          ferrand24gmail.com
                          I have exactly followed the instructions for using a downloaded route and it just doesn't work. I created a short route and "made available for offline use". I then selected this route from my "downloads" as soon as I tried to start navigation it said "something went wrong, unable to calculate route".
                          Am I doing something wrong?
                            @Roger-Doidge said in Four day test:
                            Difficult to say if you’re doing anything wrong without seeing your route. Can you share it please.
                            ferrand24gmail.com 1 Reply Last reply
                              ferrand24gmail.com
                              ferrand24gmail.com
                              ferrand24gmail.com
                              @Nick-Carthew
                              Excuse my ineptitude, how do I share the route?
                                @Nick-Carthew
                                @Nick-Carthew
                                Firstly, make sure that the privacy of the route is set to public. Then copy the url (web address) and paste it in your reply.
                                  @Nick-Carthew
                                  ferrand24gmail.com
                                  ferrand24gmail.com
                                  ferrand24gmail.com
                                  @Nick-Carthew
                                  Nick, here is the url myrouteapp.com/route/open/7470383
                                  I see from your profile that you are a Devon boy. Until we moved to France 20 years ago I lived in Plymouth and walked on Dartmoor regularly. I still miss the moor.
                                    @Nick-Carthew
                                    @Roger-Doidge Cream on First 😊
                                    Move route point one onto the road, that should fix it.
                                    Corjan Meijerink ferrand24gmail.com 2 Replies Last reply
                                      @Nick-Carthew hahaha, people who put jam on first are also allowed to exist 😉
                                        ferrand24gmail.com
                                        ferrand24gmail.com
                                        ferrand24gmail.com
                                        @Nick-Carthew Thanks, I'll try that.
                                        Which first, jam or cream?
                                          G.Grote Ganseij
                                          G.Grote Ganseij
                                          G.Grote Ganseij
                                          @Dikke-Wim ik ben de afgelopen 10 dagen er geweest heb daar 10 routes gereden allemaal offline, eerst bij je hotel de route laden je kunt deze met de instelling offline laden en dan gewoon rijden, het voordeel van de laatste update is automatisch punten overslaan dat dit werkt. ik heb na deze update geen problemen gehad met het rijden van routes, wordt alleen maar beter.
                                          Dikke Wim
                                          Dikke Wim
                                          G.Grote Ganseij
                                          G.Grote Ganseij
                                          ferrand24gmail.com
                                          ferrand24gmail.com
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
