  3. [App-Beta] Announcements
  4. New Beta! (v3.2.14)
New Beta! (v3.2.14)
55 Posts 24 Posters 851 Views 7 Watching
    We're back everybody! 🎉
    This week we've got another great update for you! 😊
    Lots of cool new features and improvements to the app.
    Resume navigation
    We've all encountered the situation where you stop for a coffee and you stop the navigation / close the app.
    When you want to continue driving you then have to go through some steps first. Open the route you were driving, calculate the actual route, skip some waypoints and that's it.
    We just want you to focus on driving and leave the smart stuff to us 😉
    When you stop the Navigation, close the app on purpose or encountered a crash we will simply ask you if you want to continue where you left off! 🎉
    Easy as that! We will simply resume the last navigation session exactly where you stopped it.
    Skip waypoints automatically
    Finally! 😄 One more functional navigation setting has been implemented and unlocked!
    When driving a route and you miss a waypoint, you can skip it using multiple options:
    • Tap or long press the displayed upcoming waypoint
    • Long press the waypoint on the map
    • Long press the waypoint in the waypoint list
    However, sometimes you just want to continue driving or can't use your phone.
    We've now implemented an algorithm to skip those waypoints for you. It's very similar to the one you are used to in MyRoute-app Navigation.
    If you don't want waypoints to be skipped automatically, turn it off in Navigation settings > Functional.
    Note: you might need to turn this setting on first 😉
    Some factors you as tester have influence over are the parameters of the algorithm. No, we won't make all parameters configurable.
    So what can you provide us feedback about?
    • The algorithm will always skip a waypoint after more than 4 recalculations (the count resets after you've passed a waypoint, skipped a waypoint or chose a new waypoint to route to).
    • The first recalculation won't ever automatically skip a waypoint.
    • If you are within 250 meters of a waypoint and you have a recalculation, we will always skip that waypoint (regardless if it is the first recalculation).
    Obviously, viapoints are never skipped. Only shapingpoints are allowed to be skipped automatically.
    After the app skips a waypoint automatically, it will always inform you about this.
    Clicking revert (or anywhere on the popup to be correct) will undo the automatic skip action and the app will reroute you to the original waypoint.
    Changed landscape UI
    The depth of field and the visual clutter in landscape mode has always been a discussion.
    We've moved some stuff around, changed the size of some items and improved the alignment of your position in landscape mode.
    Please let us know how you like it 😊
    Note: some minor portrait mode UI changes are also visible
    Position indicator sizing
    There are phones (big & small), tablets (big & enormous) and now also CarPlay displays ranging from small to colossal resolutions.
    We've attempted to improve the sizing of the position indicator across all resolutions.
    Battery usage when app was inactive (iOS)
    Some iOS users mentioned that the OS indicated that the app would still use battery even when the app wasn't being used.
    We've worked on a solution and are curious if you now don't experience this anymore.
    Incorrect CarPlay position indicator
    Your position indicator in CarPlay would often not work correctly 😞
    It wouldn't show at all, not update your position correctly or sometimes CarPlay would even display multiple position indicators! We've resolved this issue.
    Incorrect location when starting the navigation
    Some users would appear to be in Berlin (HERE HQ) when they started the navigation. This should now also be fixed!
    Android stability
    The general stability of the Android app has been an issue for quite some time and was luckily fixed last update! 😊
    In this update, we've further improved the stability.
    Orientation change broken after taking a photo / opening the browser
    A very annoying issue. If you were using the app in landscape mode and you would take a photo, the app would not appear in landscape mode anymore. Now it does 😉
    What's next?
    Well, we got some exciting news for you! Android Auto will be the next update 😮 😮 🎉 💪 💣 🚀
    Not quite sure when that will be exactly but it will be the next one and it will be within the next 2 weeks.
    Furthermore we will continue working on the known big issues:
    • Battery usage navigation
    • Position delay
    Other critical items:
    • Voice instructions stability & configuration
    • Offline maps managements (especially related to updates)
    And much more community feedback! For which we are very thankful ❤
    That's it for now. We're looking forward to all your feedback already.
    Best,
    Team MRA
    @Corjan-Meijerink Any idea within what timeframe the position delay can be resolved?
    Corjan Meijerink Stefan Hummelink 2 Replies Last reply
    • Bart De Medts Bart De Medts
      @Bart-DM no, but before release. Requires cooperation with HERE 🙂
        #37
        @Corjan-Meijerink I managed to screenshot the track being in front of the cursor. I imagine you have seen this yourself as well, obviously, but yet, I did not want to keep this from you. 🙂
        My sincere apologies if I'm simply re-stating the obvious here.
          @Corjan-Meijerink ok thx 🙏
            @willem-l said in New Beta! (v3.2.14):
            hoe krijg ik de app zoals de fotos hierboven, ja ik ben beta tester en heb versie 3.2.4-144
            krijg het niet voor elkaar zoals de app van de navigatie hierboven getoond worden.
            If you have the latest version you should see the same as above. Please provide a screenshot.
            willem l
            willem l
            willem l
            @Nick-Carthew
            Screenshot_20230512_060127.jpg Screenshot_20230512_060241.jpg Screenshot_20230512_060455_Navigation.jpg
            • willem l willem l
              @Nick-Carthew
              @willem-l Your screenshots 1 and 2 show the MRA Mobile app without the navigation module added.
              You may need to wait a little longer for your application to be processed.
              Screenshot 3 shows the original MRA Navigation app this has nothing to do with the BETA app
              • AlexM
                AlexM
                AlexM
                Hello! how do i get the new beta version on my phone? I still have version 3.2.4. I've already written an email to de support. unfortunately I haven't received an answer yet.
                • Rob Verhoeff
                  Even een veer steken daar waar geen licht komt 😇
                  Vandaag een kort rondje door de bollenvelden gereden (geen bollen meer).
                  Ik kan wel zeggen dat ik niet zo'n veeleisende gebruiker ben. Hij moet de route tonen en niet crashen. En dat gaat prima! Als het na-ijlen van de positie bepaler is opgelost dan vind ik de app perfect. Ik gebruik geen stemaanwijzingen maar kijk alleen naar mijn scherm. Ik heb diverse routepunten automatisch overgeslagen, pauzes genomen, de app afgesloten en weer gestart. Foto's ingevoegd, oh ja en nog lekker gereden ook!
                  Ik ga met vertrouwen de Alpen in met de pinksterdagen. Team MRA bedankt. Ik kijk met vol vertrouwen naar de toekomst 👍
                    @Rob-Verhoeff Dat zijn de dingen die ik graag hoor! Geniet van je tocht door de Alpen 😃
                    • AlexM
                      AlexM
                      AlexM
                      Hello! Unfortunately I haven't received any confirmation yet. I would like to test but unfortunately I can't. Unfortunately I still don't have the latest version above. So the 3.2.14. Is it easy to change the email address in MRA without any problems?
                      thank you
                      • AlexM AlexM
                        thank you
                        @AMGT Please contact our support department for these issues. https://www.myrouteapp.com/support
                        • AlexM
                          AlexM
                          AlexM
                          Hello! I did this last week and today.
                          Dave J 0 1 Reply Last reply
                          • AlexM AlexM
                            @AMGT Did you raise a support ticket? You should get an acknowledgement straight away that it is on the system. I have tried before using the email and got no response. Try this email as well: support@myrouteapp.freshdesk.com
                            Ducati Multistrada V4 Rally
                            iPhone 18 Pro
                            CHIGEE AIO-6 LTE
                            Google Pixel 6 Pro
                            • AlexM
                              AlexM
                              AlexM
                              • AlexM
                                AlexM
                                AlexM
                                • AlexM
                                  AlexM
                                  AlexM
                                  Dear alexander. morre,
                                  We would like to acknowledge that we have received your request and a ticket has been created.
                                  A support representative will be reviewing your request and will send you a personal response.
                                  Comments and attachments can be added by replying to this email.
                                  Thank you for your patience.
                                  Sincerely,
                                  MyRouteApp B.V. Support Team
                                  I have now received this email
                                  • Stanisław Stanisław
                                    @Nick-Carthew Yes, but this is hard to predict during planning the route when we will need it. That's why adding a via point to the route ad-hoc, during the navigation, would be also good solution - for example to add the nearest gas station.
                                    #51
                                    @Stanisław said in New Beta! (v3.2.14):
                                    You'll need need it when you run out of petrol/battery, right?
                                    How about allowing users to add their vehicle range to their personal information and then let the route planner suggest petrol stations xx Km from that distance. Way too clever? Post-launch!
                                    • richtea999 richtea999
                                      @richtea-0 and next on long trips you will want to specify daily range and have the app suggest a hotel/B&B to stay overnight ... and then suggest a location for breakfast, lunch and dinner 😀 😀
                                      • TorqueRider
                                        • TorqueRider TorqueRider
                                          [[topic:post-is-deleted]]
                                          Richard 18
                                          Richard 18
                                          Steve Lynch
                                          Steve Lynch
                                          Ian foster 0
                                          Ian foster 0
                                          Koen VH
                                          Koen VH
                                          Pete Fredette
                                          Pete Fredette
                                          AlexM
                                          AlexM
                                          willem l
                                          willem l
                                          Antonio Antunes
                                          Antonio Antunes
                                          Meirion Towell
                                          Meirion Towell
                                          Peter Clauws
                                          Peter Clauws
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
                                          • Library: Folders at the Top of the Menu
