  4. MAP downloads continue to be a problem
26 Posts 9 Posters 331 Views 3 Watching
    Okay, okay, I understand. I don't think I was understood correctly. 😧
    My last 6-8 Tours where also without any problems, I am just cautious.
    Nick Hodge 1 Reply Last reply
    • Rod Sydenham Rod Sydenham
      I can download some maps but as soon as I try to download any California maps, the app quits working. It simply reverts back to the home page. I have uninstalled/reinstalled, etc and nothing has any impact on the situation.
      @Rod-Sydenham If California consistently gives issue we can look into that 🙂
        Nick Hodge
        Nick Hodge
        Nick Hodge
        @Jörgen Jorgen. I understood. If something is labelled 'beta'. Have a backup, files, device, plan.
        Never a reflection on any development but appreciate it's in a testing phase and may have issues not yet identified/addressed
        • Rod Sydenham
          Rod Sydenham
          Rod Sydenham
          Yes, it is California that consistently gives the problem. Whenever I try to download any map of that state, the app quits working.
          • Rod Sydenham
            Rod Sydenham
            Rod Sydenham
            Something I have noticed.
            I just tried to download the Texas map and the same thing happened.
            It appears the issue is with maps that have multiple "sub" map areas. eg. California has 8, Texas has several as well.
            Any map that only has 1 map area seems to download correctly.
            Con Hennekens Nick Carthew 2 Replies Last reply
              @Rod-Sydenham, Germany consists of 16 sub-maps, and that poses no problem on my side.
                @Rod-Sydenham I know this doesn’t help your situation, but I thought that I would try downloading California myself, just to check that the map downloads ok. I’m pleased to report that it does.
                • Rod Sydenham
                  Rod Sydenham
                  Rod Sydenham
                  I am able to download the whole map of California. What I was attempting is to download just the area that I needed (in an effort to conserve storage space on my device).
                  When you select "California", it gives the possibility of 2 major areas; north and south. Selecting either then gives more options for narrowing the download area.
                  As soon as I selected a "sub area" to download the app would quit working.
                  Perhaps the downloading of a map "subset" is not possible and you need to download the whole map of the area. If that is the case, then perhaps the display of possible downloadable subset areas be removed to avoid the confusion.
                    @Rod-Sydenham I think that you are attempting to download maps in the original navigation app. This has North and South California to choose from. This forum is for the BETA app. The BETA app has only one option, all of California. My previous screenshots are from the BETA app, the screenshot below is from the original navigation app.
                    • Rod Sydenham
                      Rod Sydenham
                      Rod Sydenham
                      Hmmmm.
                      When I go to the Google play store and download the Beta version of the Myroute - Navigation (the one with the blue arrow on a white background) the one that opens appears to be the old version. ie. White arrow in a white circle on a dark blue background.
                      This is what it says I am downloading
                      What shows up when I open it is
                        Hmmmm.
                        @Rod-Sydenham
                        Old version on left new version on the right.
                        • Rod Sydenham
                          Rod Sydenham
                          Rod Sydenham
                          When you go to the Google Play store this is what is displayed for "navigation"
                          Maybe that should be changed so that a person doesn't think that it is linked to the Beta version of Myroute-App?
                            @Rod-Sydenham when I search Google Play Store I see the followingScreenshot_20230509-132758_Google Play Store.jpg
                            • Rod Sydenham
                              Rod Sydenham
                              Rod Sydenham
                              I apologize for not having devoted enough time to have learned all there is to know about the new app. I get (thanks to you) that it is the old navigation app that was initially giving me difficulty. However, as you can see, it is not hard to imagine that this could be the "navigation" part of the new app. It is designated as "Beta" and I am identified as a beta tester. Even the icon is new (as compared to the "old" version hiding behind it.
                              All I am suggesting is that its appearance in the Google Play store be changed to reflect reality so that others do not make the same mistake I did.
                              Dave J 0 1 Reply Last reply
                                @Rod-Sydenham it is a feature of the Play Store where you can ask to be a beta tester for some apps and the Play Store (Google) approves this for the Store and shows you as a tester. However, it can still be down to the developer to further allow you to test beta versions of the app. . You should also be able to withdraw yourself from being a beta tester for the old app from within the app within your 'Manage Apps' within the Play Store. Screenshot_20230509-220435.png
                                I am new to Android and learning these kind of things as I go along. This is very different to how iOS Test Flight works.
                                Ducati Multistrada V4 Rally
                                iPhone 15 Pro
                                CHIGEE AIO-6 LTE
                                • Dave J 0 Dave J 0
                                  @Dave-J-0 correct! Android is way different. You can literally become Beta tester for almost every app there is 🙂 This is “open testing” which happens directly in the Play Store
                                  iOS manages Beta builds exclusively using a separate app store so to say: TestFlight.
                                  • Rod Sydenham
                                    Rod Sydenham
                                    Rod Sydenham
                                    I did not apply to be a beta tester for the "navigation" app. That was done by MyRoute.
                                    My issue is NOT that I am a beta tester. The issue is the app is identified as the Beta version which is confusing/misleading if nothing else.
                                    Let's move on. There are some real issues that are keeping the Navigation portion from the app being acceptable. Especially in offline mode. Let's concentrate on that rather than my insignificant issue.
                                    Nick Hodge
                                    Nick Hodge
                                    Rod Sydenham
                                    Rod Sydenham
                                      1.7k
                                      1.5k
                                    • MRA 6.0.0 (515) Map Detail at Zoom Levels - CarPlay
