  4. Route not fully loaded v3.2.9
6 Posts 3 Posters 92 Views 1 Watching
  • kleijr76gmail.com
    kleijr76gmail.com
    kleijr76gmail.com
    I created a new route with POI, when I open the route you can se how the route go's from poi 7 / 8 / 9 and 10
    When I push the start button you can se than not the complete route is load
    I use now a iphone 14 pro, whit the beta v3.2.9
    • kleijr76gmail.com kleijr76gmail.com
      @Ronald-2k It's not that the route isn't fully loaded, it's that the navigation calculates the route differently. Did you plan the route using the HERE map?
      kleijr76gmail.com 1 Reply Last reply
        kleijr76gmail.com
        kleijr76gmail.com
        kleijr76gmail.com
        @Herko-ter-Horst
        I used the OSM map
        I just use the HERE map and now he calcelate the route differently but stil not correct.
        The navi has now calculated the route further to the end point, the route from point 7 not as I had made it
        So there is a difference in which MAP you use?
        Herko ter Horst Steve Lynch 2 Replies Last reply
          @Herko-ter-Horst
          I used the OSM map
          @Ronald-2k It's very much recommended to plan routes using the same map as you will be using during navigation (MRA Navigation uses HERE maps exclusively), so differences are minimised. If you need to plan for multiple navigation systems, you may need to add additional waypoints to ensure the route is the same for all systems (MRA Routeplanner has a "compare" function for this purpose).
          Earlier, the route was also calculated to the end, just using a different trajectory (going "back" from point 10 over a section of road already used).
          Why the route still doesn't match between 7 and 8, I don't know. There used to be an issue with the HERE map in the planner not being the same version as in the Navigation app, but as far as I know, that has been resolved, so it should be the same map. One thing that could cause issues in the current beta, is that route calculation settings, such as curviness, avoid highways, etc. are not (yet) taken into account by the Navigation Beta app.
            @Herko-ter-Horst
            I used the OSM map
            Steve Lynch
            Steve Lynch
            Steve Lynch
            @Ronald-2k
            I would advise that you try moving Waypoint 8 further up the Road as below.
            • Steve Lynch Steve Lynch
              @Ronald-2k
              kleijr76gmail.com
              kleijr76gmail.com
              kleijr76gmail.com
              @Steve-Lynch
              I add a point as you tolt and the route is is perfect 👍🏼
              Steve Lynch
              Steve Lynch
              kleijr76gmail.com
              kleijr76gmail.com
              • Strange translation
                martin-phogel.de
                martin-phogel.de
                10.5k
              • Undo/Redo tool is hidden
              • Crazy routing
              • Shared toggle switch
              • Which route is shown?
